Jack Mayer Posted August 27, 2017 Report Share Posted August 27, 2017 10 hours ago, sushidog said: Here's their unfortunate experience with their LiFePo4s "Considering that our batteries are seemingly not on track to outlive an AGM bank as much as theory promised, our personal value calculation haven’t worked out nearly as well as we had hoped." Chip Your numbers seem accurate, although I'll admit I have not worked them through. But you are overlooking a few things. 1) since C&C put in their LFP bank things have changed a lot. Also, they were educating themselves as they did it. "Bleeding edge" activities can hurt.....and that is what they were doing at the time. Also the reason I did not recommend LFP at the TIME. You are aware of the issues due in part to their efforts. You would not do what they did. 2) The lifetime of the various lithium chemistries is pretty well demonstrated at this point. So I would not worry "too" much about it. 3) You should seriously consider used E-car battery sets. Which can be had in the 2-3K range. Yes, you will have to do some work on them, but you seem capable of that. It is not rocket science. 4)The biggest issue is still "environmental", but the facts are well known at this point, and can be managed. The BMS will not allow charging if it is not "happy". In the project I'm currently working on we are conditioning the battery/utility compartment. But that will not work for everyone. I recommend that anyone putting on solar put on the max that you can fit on the roof.....unless it is a total budget project. Then tradeoffs need consideration. But you can never have "too much" solar harvest. IMO. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
sushidog Posted August 27, 2017 Report Share Posted August 27, 2017 Thanks, Jack. I value your opinion. I looked at the Prius battery packs a couple years ago but learned that they are nickel metal hydride not lithium. Which Hybrid battery packs would you recommend I look at? Cracking into one and rewiring for 48 volts wouldn't be a problem as long as it wouldn't affect the BMS. Yes I understand that LiFePo4s are more temp sensitive and the fact that pioneers like C&C end up with more arrows in their backs than settlers, so I can learn from the mistakes of others - this is wisdom. I was pioneering an electric supercharger setup a few years back. I found out that as voltage increased, intake manifold pressure increased logarithmically. Long story short, I ended up overvolting and destroying a couple of high dollar rare earth magnet motors in my quest for boost. Heck, education costs money, no? Thanks for your advise, Chip Link to comment Share on other sites More sharing options...
TheLongWayHome Posted August 27, 2017 Report Share Posted August 27, 2017 34 minutes ago, sushidog said: Which Hybrid battery packs would you recommend I look at? Chip, A presentation from one of the members here:- http://eastcoasthdtrally.com/wp-content/uploads/2017/04/ECR-2017-Lithium-Battery-System.pdf Link to comment Share on other sites More sharing options...
sushidog Posted August 28, 2017 Report Share Posted August 28, 2017 Thanks, LongWay! He used the battery from a Fiat. Six of these http://www.ebay.com/itm/24V-64Ah-Fiat-500e-TESTED-Lithium-Ion-Golf-Cart-battery-/222419957522?hash=item33c9433712:g:EcgAAOSwbiFZUti9&vxp=mtr would be under $2,600 - about half the price of new. Now that's in the price range that makes it economically feasible.192 AH (153 useable) at 48v is perfect for my needs. I've got to learn a lot more about a BMS for it though. Chip Link to comment Share on other sites More sharing options...
TheLongWayHome Posted August 28, 2017 Report Share Posted August 28, 2017 6 hours ago, sushidog said: Thanks, LongWay! He used the battery from a Fiat. Six of these http://www.ebay.com/itm/24V-64Ah-Fiat-500e-TESTED-Lithium-Ion-Golf-Cart-battery-/222419957522?hash=item33c9433712:g:EcgAAOSwbiFZUti9&vxp=mtr would be under $2,600 - about half the price of new. Now that's in the price range that makes it economically feasible.192 AH (153 useable) at 48v is perfect for my needs. I've got to learn a lot more about a BMS for it though. Chip Chip, If you want to see it for real and talk with the designer/implementer, come to Hutchinson, KS from Oct 8-14 (Actually Monday 9th, afternoon for the Lithium Ion battery system!) for the National HDT Rally - http://nationalhdtrally.com/2017-national-hdt-rally-registration/ Sign up before Sept 1st and get a better price and a tee shirt!!! You don't need an HDT (I don't have one) to attend. There is also a presentation on a mini-split cooling system, which was the original OP subject matter, and is on the same afternoon. If you can only attend one day, that would be it. Then there is all those big shiny HDTs and RVs!!!!! If you can find the "right" salvage yard, you can cut out the ebay middle man and save some more money!! Gerry Link to comment Share on other sites More sharing options...
sushidog Posted August 29, 2017 Report Share Posted August 29, 2017 Thanks for the invite, Gerry. Unfortunately I will need to be working those dates at the Shrimp Fest in Gulf Shores, AL. If not, I would have liked to attend it. Chip Link to comment Share on other sites More sharing options...
Steve from SoCal Posted August 29, 2017 Report Share Posted August 29, 2017 I was curious about DC mini splits and ran across this, http://www.hotspotenergy.com/DC-air-conditioner/DC-AC-Complete-Systems.php It is smaller than the truck unit but, a couple of these in an RV should be just fine, a truck is not as well insulated as an RV in general. One thing about the system above, there is no DC-AC-DC conversion loss. I use inverter drives on several machines, all my inverters are 3 phase because single phase is a poor starting point for DC rectification. I may try one of these in my truck with a battery bank, I have looked at window air units with an inverter as a cheap solution, lots of comments about vibration and longevity but, real cheap to replace? Steve 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
noteven Posted August 31, 2017 Report Share Posted August 31, 2017 Have you guys and gals seen my analog complete rig shade cloth deployment system? Wind has way less terror effect on shade cloth than solid tarp awnings. It's currently on file along with the radiant reflective heat barrier and double insulation, interior ventilation air exchanger, and low voltage hydronic heating and monocoque frameless trailer that encloses all systems inside the heated envelope. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
TheLongWayHome Posted August 31, 2017 Report Share Posted August 31, 2017 16 minutes ago, noteven said: Have you guys and gals seen my analog complete rig shade cloth deployment system? Wind has way less terror effect on shade cloth than solid tarp awnings. It's currently on file along with the radiant reflective heat barrier and double insulation, interior ventilation air exchanger, and low voltage hydronic heating and monocoque frameless trailer that encloses all systems inside the heated envelope. Got a link? Link to comment Share on other sites More sharing options...
sushidog Posted August 31, 2017 Report Share Posted August 31, 2017 On 8/28/2017 at 10:37 PM, Steve from SoCal said: I was curious about DC mini splits and ran across this, http://www.hotspotenergy.com/DC-air-conditioner/DC-AC-Complete-Systems.php It is smaller than the truck unit but, a couple of these in an RV should be just fine, a truck is not as well insulated as an RV in general. One thing about the system above, there is no DC-AC-DC conversion loss. I use inverter drives on several machines, all my inverters are 3 phase because single phase is a poor starting point for DC rectification. I may try one of these in my truck with a battery bank, I have looked at window air units with an inverter as a cheap solution, lots of comments about vibration and longevity but, real cheap to replace? Steve Yep, that's a pretty efficient AC, with an EER of 19.3 according to their spec sheet. http://www.hotspotenergy.com/DC-air-conditioner/Specs-DC48.pdf The unit I linked to is also a 48v DC heat pump with an EER of 21.43. http://www.geinnovations.net/HSAC_Productline.html Both are very similar units, but the higher the EER the better. Chip Link to comment Share on other sites More sharing options...
Dan Hannah Posted October 10, 2017 Report Share Posted October 10, 2017 My Prius has electric AC, I am told. It seems like it would be powerful enough for the just the bedroom of the RV while sleeping, and it definitely would be quieter than running the genny all night. Is there anything to this idea? Link to comment Share on other sites More sharing options...
Kirk W Posted October 10, 2017 Report Share Posted October 10, 2017 6 hours ago, Dan Hannah said: Is there anything to this idea? Your Prius has far larger battery capacity than most RVs and even then could you run it all night without the engine running? Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Al F Posted October 10, 2017 Report Share Posted October 10, 2017 The gas engine may run all the time the air conditioner is on. If the gas engine doesn't run all the time, the air conditioner discharging the battery faster than normal will cause the gas engine to run to keep the battery charged. Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
sandsys Posted October 11, 2017 Report Share Posted October 11, 2017 18 hours ago, Al F said: The gas engine may run all the time the air conditioner is on. If the gas engine doesn't run all the time, the air conditioner discharging the battery faster than normal will cause the gas engine to run to keep the battery charged. Suanne camps in her Prius for extended trips. She says with the A/C on the engine runs about 4 minutes out of every 35 minutes. Details here: http://www.cheaprvliving.com/other-conversions/living-prius/ Linda Sand Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Al F Posted October 11, 2017 Report Share Posted October 11, 2017 16 minutes ago, sandsys said: Suanne camps in her Prius for extended trips. She says with the A/C on the engine runs about 4 minutes out of every 35 minutes. Details here: http://www.cheaprvliving.com/other-conversions/living-prius/ Linda Sand That is amazingly efficient, the engine running less than 8 minutes an hour to charge the battery while running the A/C. Good to know. Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
Al F Posted October 11, 2017 Report Share Posted October 11, 2017 3 hours ago, sandsys said: Suanne camps in her Prius for extended trips. She says with the A/C on the engine runs about 4 minutes out of every 35 minutes. Details here: http://www.cheaprvliving.com/other-conversions/living-prius/ Linda Sand Linda, Thanks for the info and the link to an amazing way to travel in a very small RV. It is wonderful the different ways people find to travel this scenic country of ours on a very economical budget. We love to travel. What we love about RV'ing travel, especially when your RV is self contained with adequate battery power and solar panels, is the freedom you have to go where you want, when you want, stay as long as you wish and then move on. The skeptic in me, checked with our son who owns a Prius, about the A/C and engine running. He confirms that running the A/C overnight would indeed work very well. He has never tested how long the A/C would run before the engine would start, but felt very comfortable with 20-25 minutes between running. I take that as confirmation of the 4 minutes every 35 minutes. A lot depends on the outside temp, how cool you want the interior of Prius, etc. Al & Sharon 2006 Winnebago Journey 36G 2020 Chevy Colorado Toad San Antonio, TX http://downtheroadaroundthebend.blogspot.com/ Link to comment Share on other sites More sharing options...
sandsys Posted October 12, 2017 Report Share Posted October 12, 2017 5 hours ago, Al F said: Linda, Thanks for the info and the link to an amazing way to travel in a very small RV. It is wonderful the different ways people find to travel this scenic country of ours on a very economical budget. You're welcome. Sometime we stumble across something unique and can actually remember it later when someone asks. Linda Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Dan Hannah Posted October 19, 2017 Report Share Posted October 19, 2017 I see a project developing here.... Bedroom AC using a Prius compressor. I wonder how many volts the compressor takes? There are some EXTREMELY high voltages running around a Prius. Link to comment Share on other sites More sharing options...
lappir Posted October 19, 2017 Report Share Posted October 19, 2017 Following. White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
