johnschnee Posted July 27, 2017 Report Share Posted July 27, 2017 Our 2014 Bounder 35K's house batteries (OEM, 2 12 volt batteries) have recently been draining down significantly over just a few days, even when the "battery disconnect" switches are engaged! I nosed around a bit & was surprised to find that, even when I've got the "battery disconnect" switches engaged, the inside televisions were still drawing power, as signified by the small red "power" lights lit below the screen. I've started to unplug the TVs, but I'm STILL seeing a severe drain on the batteries! I have been careful to top off both batteries with distilled water each month as part of my regular "preventive maintenance" & I did recently notice quite a bit of corrosion on the metal attachments holing the batteries fast. After just 5-7 days in storage I haven't even got enough "juice" in the house batteries to start the generator, so I have to run the engine for 15-20 minutes to allow the generator to start so's I can get the batteries charged back up. I'm at a loss as to what's happening here to cause this: wondering if the batteries are just plumb "wore out" & need replacement, but after just 4 years of "1/2 -time use" that shouldn't be necessary? If anyone has any suggestion I'd be greatly appreciative! Thanks in advance! Link to comment Share on other sites More sharing options...
Chad Heiser Posted July 27, 2017 Report Share Posted July 27, 2017 If your televisions are still on and you are not plugged into shore power, then you have an inverter in your system. The inverter is drawing power from the batteries and inverting it to 120v AC power to power the TV's (assuming the TV's are not 12 volt models). If this is the case, that would be a significant draw on your batteries over time and is what is causinjg the issue. The 12 volt kill switch will not kill high draw 12 volt loads like inverters or slide motors or leveling jacks typically. Typically the 12 volt kill switch only kills power to the 12 volt distribution panel in the RV. The high draw 12 volt items like an inverter are wired directly to the batteries and don't go through the kill switch or the 12 volt distribution panel. If all this is the case, find your inverter and turn it off. It should solve your problem. Also, if you drew down your batteries significantly like you describe too many times, you could have significantly shortened their life and they could be suspect as well. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Kirk W Posted July 27, 2017 Report Share Posted July 27, 2017 6 hours ago, johnschnee said: After just 5-7 days in storage I haven't even got enough "juice" in the house batteries to start the generator, so I have to run the engine for 15-20 minutes to allow the generator to start so's I can get the batteries charged back up. If your two batteries are fully charged again after only 15-20 minutes they are in very poor condition as it should take several hours when they are down. Have you taken any specific gravity readings or at least a voltage reading with a good volt/ohm meter? If so, you can check the level against this charge level chart. As a simple test of the batteries, make sure that they are fully charged and once they are, remove the cables from the negative post of each battery, letting them sit this way for at least 24 hours and check the voltage again. You need to isolate the two as one battery bad will drain down the other that may yet be good. If they are suspect, take them to a battery shop and have them load tested. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
johnschnee Posted July 28, 2017 Author Report Share Posted July 28, 2017 Chad & Kirk: Thank you very much for your informative & helpful responses above! I will take a peek around for the "off switch" for my Bounder's inverter & I've made an appointment to have the batteries checked out next week. THANKS AGAIN! Link to comment Share on other sites More sharing options...
