DanBree
*SOLD* HDT 2010 Freightliner Cascadia
2010 Freightliner Cascadia with a 10 speed UltraShift (2 pedals, no clutch) with around 520,000 miles. My wife and I bought this truck from Heavymetal, with 512k miles on it, in November 2016 expecting to add a bed and upgrade our trailer to a 5th wheel trailer. We took the truck to the HDT ECR this past April with our current trailer and loved the room and power.  However, we have decided we wanted go to the single unit route instead of a truck/trailer combo, so we are looking at buying a used Showhauler or Haulmark type RV.  In order to do that, we have to sell our current truck and trailer.
The following are the specs on this truck, which is titled & registered as an RV in Minnesota...
DD 15 engine, 455hp, with electric engine block heater and 3 stage Jake brake, engine tuned & valve lashes adjusted on 8/22/2017
10 speed UltraShift (Eaton Fuller) transmission
2.64 rear diffs
Twin 100 gallon fuel tanks
Cruise control
Power windows & door locks
Power & heated mirrors
Thermo King Tri-Pac APU with a twin cylinder Yanmar diesel engine that operates a separate sleeper A/C, alternator feeding a 1500 watt inverter, and a diesel fired cab heater. Plus it circulates warm coolant through the main engine so it's ready to start on a cold mornings.
Shore power, 110V & 12V plugs, and dedicated A/C & Heater controls in the sleeper
Updated 30k Comfort ride hitch and 16k 2” receiver on removable bolt-on platform which fits between the frame rails
Jackalopee wiring box
2016 Cooper Road Masters drive tires
2016 Bridgestone steer tires
2016 Legacy Silver air ride seats
Centramatics for front wheels (installed on 8/22/2017)
3-axle alignment done in 2017
Crossfire tire air pressure balancers on both rear axles added in 2017
New Front axle and Cab Shocks
Removable, and adjustable, 4” driver's floor footrest and throttle & brake pedal extensions for shorter drivers
Electric brake controller
AM/FM/CD player, CB, & Sirius satellite radio dock
Additional 12V power plugs for dash cam, TPMS, phone chargers, etc.
The truck has Amsoil synthetic oil in the engine and transmission. New oil and fuel filters done this year.
I have all the maintenance records and receipts from Heavymetal plus the work I've done since I bought it.
This is a really nice truck with no rattles or squeaks inside the cab.  The truck is white with gray and tan interior.
Edited by DanBree
Share this post
Link to post
Nice looking truck.  Did you add the accessories yourself?  Off topic a bit but I am looking for the receiver hitch you have.  where did you get yours?  I'm trying to avoid hundreds in shipping costs, I hope to pass by a dealer on our travels.
Share this post
Link to post
Thanks!  Since I've had the truck, I've added the Crossfires, front axle & cab shocks, satellite radio dock, and additional 12V power outlets myself.  The removable pedal extensions were professionally installed.  The update to the ComfortRide hitch was done by the folks at ComfortRide.  The receiver hitch was installed by a local truck body shop here in Minnesota (Crysteel), and it is welded to the same removable platform that the ComfortRide hitch is bolted to.  They did a great job and have lots of options in that regard.  The ComfortRide hitch, Jackalopee and brake controller were installed by Heavymetal when I bought the truck.
Share this post
Link to post
4 minutes ago, Exile said:
Where is the truck located?
The truck is up here in Rosemount, Minnesota. A town south of the Twin Cities.
Edited by DanBree
Share this post
Link to post
Had the engine tuned-up today which included adjusting the valve lashes.  While they were doing that, I had them replace the fuel injector wiring harness replaced as it had a small oil leak, and replaced the turbo oil return drain tube  as it was leaking.  I also had them install the Centramatics onto the front wheels.  I updated the original description showing the Centramatics as being installed and the valve lashes being adjusted.
Share this post
Link to post
I am interested and have the $$.
Very important question. Are you smokers? Does the cab smell of smoker use from previous owners?
Thank you,
Lee
leeines@aol.com, 520 730 3402
Share this post
Link to post
Thank you,
Lee
My wife and I are non-smokers.  We bought our truck from Heavymetal, who did a treatment to eliminate the smoker smell when he bought the truck and did his conversion, including replacing the seats and mattress with new ones.  As far as smelling like stale smoker, no, the cab & sleeper doesn't smell like stale smoker.  We try to keep the truck's smells as neutral as we can due to my allergies.
Edited by DanBree
Share this post
Link to post
We will be at the upcoming HDT National Rally in Hutchinson with both our truck and trailer.  If you are interested in a test drive or ride along, please PM me and we can setup a time.
Share this post
Link to post
AGS Now Hiring
RV Pet Safety
Cummins Home Generators
Make Money and RV Logo
