leavingsoon Posted July 6, 2017 Report Share Posted July 6, 2017 Now that you guys have given me the brand names of hitches to consider, my next question is does it have to be installed directly over the rear axle?....or can it be installed behind the axle? I know I can't go too??? far back and take the weight off the front end, and don't want to be unsafe. I know there has to be a math formula out there to help make this decision but I can't find one on the internet. My truck has a short wheel base and I am trying to think thru what my options are with the space. The 2000 Freightliner FL60 truck wheelbase is 138"....front axle is 8k pounds.....rear axle is 12k pounds.....I have approx. 72" from the back of the cab to the center of the rear axle. I know I have limited space to carry anything between the front of the trailer and back of the cab, that's the reason I'm thinking if I can set the hitch back behind the axle it will allow me more choices with the remaining space. The Teton is 24k and approx. 5k pin Thanks, Phil 2000 American Coach Heritage 45' motorhome Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 7, 2017 Report Share Posted July 7, 2017 Hi Phil! Glad to see you made it over here! Yes, you can go behind the axle with the hitch. But remember that your dealing with a lever.... the further you go behind the axle the more you unload the front. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Chad Heiser Posted July 7, 2017 Report Share Posted July 7, 2017 Hit up Dolleytrolley here on the forum. He has a spreadsheet that will allow you to calculate how much your weights change based on loading and pin location, etc. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
noteven Posted July 7, 2017 Report Share Posted July 7, 2017 Yes it can, with good design . Dolleytrolly spreadsheet recommended. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
leavingsoon Posted July 7, 2017 Author Report Share Posted July 7, 2017 Thanks guys! 2000 American Coach Heritage 45' motorhome Link to comment Share on other sites More sharing options...
GlennWest Posted July 7, 2017 Report Share Posted July 7, 2017 I question how much you can carry on back of your truck. My Chevy dually had 10k axle and I was close to Max with my Teton. That was with a CM hauler bed. Your truck is heavier and only 2k more axle. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
leavingsoon Posted July 7, 2017 Author Report Share Posted July 7, 2017 Hi Glenn....I know I'm pretty maxed out already with just the Teton. Just trying to determine if I can get a small sleeper installed, or possibly some tool boxes. I don't really see trying to carry much additional weight when hooked to the trailer. This truck is going to be more of a work truck as opposed to towing the trailer alot. I think if we see ourselves moving around in the trailer alot in the future we will probably upgrade the truck then....get one of the big beast like you have 2000 American Coach Heritage 45' motorhome Link to comment Share on other sites More sharing options...
Hot Rod Posted July 18, 2017 Report Share Posted July 18, 2017 On my topkick I have a trailer saver 5th wheel hitch with the pin directly over the axle, and a goose neck ball mounted to the plate about 2' back from the fifth wheel pin. I can't give you a direct comparison as I tow different trailers on each, but I don't notice any difference in handling either way. If I did it again I would definitely move the fifth back for more deck space. if you are close on the weights you will have do do the math to see how much that lever affect will add weight to the rear axle and unload the front axle. In some cases that will improve your weight distribution as many of these trucks are heavy on the front axle and light on the rear. I know my truck rides a ton better with about 1000# in the cargo box, and better yet with the trailer hooked up. Link to comment Share on other sites More sharing options...
dlcarsonak Posted August 26, 2017 Report Share Posted August 26, 2017 All good advice. The lever comment is the best help. Weigh the truck with each axle separate is step one. Know the pin weight. Then figure the lever action. Neither axle should be less than 75% of the axle weight rating. That will give you how far you can move the 5th wheel behind the axle. Mine is 42" back. My WB is 245" Glyn (KL0PG) & Diane Carson2002 I-H 4400 Papa's Dream (Mama's Nightmare)2015 Space Craft V400Furkid Maxemail: dlcarsonak@hotmail.com Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted August 26, 2017 Report Share Posted August 26, 2017 Pretty simple math to figure it out. Take the distance behind the rear axle in inches x the pin weight in pounds / the wheelbase in inches = weight unloaded from front axle. In your case, if you move the pin to 18" behind the rear axle with your 5,000 pound pin and 138" wheelbase you would have (18x5000)/138 = 652 pounds unloaded from the front axle and transferred to the rear axle. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
leavingsoon Posted October 27, 2017 Author Report Share Posted October 27, 2017 On 8/26/2017 at 9:27 AM, GeorgiaHybrid said: Pretty simple math to figure it out. Take the distance behind the rear axle in inches x the pin weight in pounds / the wheelbase in inches = weight unloaded from front axle. In your case, if you move the pin to 18" behind the rear axle with your 5,000 pound pin and 138" wheelbase you would have (18x5000)/138 = 652 pounds unloaded from the front axle and transferred to the rear axle. Thanks GeorgiaHybrid!....I missed seeing your post earlier. This is the exact info I was hoping to find. The old service body has just been removed from the truck and now able to see the frame rails so I am finally getting closer to installing the hitch. Phil 2000 American Coach Heritage 45' motorhome Link to comment Share on other sites More sharing options...
