chuckbear Posted November 29, 2017 Author Report Share Posted November 29, 2017 Kirk and Dutch. I plan to add a snorkel higher up using PVC pipe. I found some posts online from someone that did this and it looks like a solid and permanent solution. I plan or working on this over the weekend since sudden and heavy downpours are quite common here in Florida, even this time of year. We have a trip planned for Christmas. Chuck Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
Pat & Pete Posted November 30, 2017 Report Share Posted November 30, 2017 9 hours ago, chuckbear said: As I understand the "fix" for this issue, including a Ford TSB that is no longer available, is to remove all the ground wires connected to the OBD connector and solder them to a new single ground. Then attaching that ground to a new clean connection to the firewall. As for the air filter, it isn't a matter of changing the filter, but modifying the air intake so I can drive if it's raining. Chuck You seem to want to substitute the On-board diagnostics (OBD) connector for the power-train control module ( PCM ) connector . Exactly why I said : PCM grounding is totally different than OBD . Make sure to fully understand . They are totally different systems . DO NOT change the grounds on the OBD . Read the Ford TSB , CAREFULLY , and change only the indicated grounds . Goes around , comes around . Link to comment Share on other sites More sharing options...
chuckbear Posted November 30, 2017 Author Report Share Posted November 30, 2017 You are correct. I was using the wrong terminology. I do understand the difference. Thanks. Chuck Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
Pat & Pete Posted November 30, 2017 Report Share Posted November 30, 2017 1 hour ago, chuckbear said: You are correct. I was using the wrong terminology. I do understand the difference. Thanks. Chuck Good you understand . I'd hate for you to make a mistake and possibly immobilize your rig because you thought reality was something it's not . Goes around , comes around . Link to comment Share on other sites More sharing options...
