Lance A Lott Posted January 6, 2019 Report Share Posted January 6, 2019 On 1/3/2019 at 5:22 PM, RHeller1 said: My issue is now odd. If I am making a turn from a dead stop or under 20mph, the truck will have no throttle response until the steer wheels are close to straight again. I am thinking it has something to do with ESC, maybe thinking the rear end is sliding, when in actuality it is not. Once the steers are close to straight again, full power and all is well. No other codes besides MID136 SID69 FMI2. any help here is greatly appreciated. I did a Google search and this sounds like traction control. There should be a fuse if you pull it that will turn of traction control and then you will know. Link to comment Share on other sites More sharing options...
RHeller1 Posted January 6, 2019 Author Report Share Posted January 6, 2019 After reading a bit through the Bendix website, since they have the ESC,Traction control and ABS stuff in my truck, I found this: TRUCK CHASSIS MODIFICATIONS If the vehicle’s chassis components are altered (for example, a wheel base extension or reduction, tag axle addition or removal, a major body change such as conversion of a tractor into a truck, or an axle, suspension, or steering system component modification) the basic ABS functionality may continue to be used, but advanced ABS features, such as the Bendix® ESP® system, must be disabled. See the appropriate Service Data sheet for more information. My truck frame has been extended quite a bit, so I am going to see if the dealer can change my Bendix setup to basic rather than advanced, which should eliminate TCS,steering angle sensor and a few others. I will let you know how it turns out Link to comment Share on other sites More sharing options...
RHeller1 Posted March 30, 2019 Author Report Share Posted March 30, 2019 in case anyone is wondering. It ended up being the yaw sensor. Had it deleted at the dealer and all is good now! Link to comment Share on other sites More sharing options...
rickeieio Posted March 30, 2019 Report Share Posted March 30, 2019 Good deal. I love a happy ending. KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
DesertMiner Posted March 30, 2019 Report Share Posted March 30, 2019 43 minutes ago, RHeller1 said: in case anyone is wondering. It ended up being the yaw sensor. Had it deleted at the dealer and all is good now! Thanks for the follow-up! Sure wish more folks that post problems would let us know what fixed it! Link to comment Share on other sites More sharing options...
Darryl&Rita Posted March 30, 2019 Report Share Posted March 30, 2019 1 hour ago, DesertMiner said: Thanks for the follow-up! Sure wish more folks that post problems would let us know what fixed it! Agreed, it's a major benefit to future generations of technicians and owners. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
