Sign in to follow this
Dale P
KwiKee Level Best Hydraulic Controller
These units work with the Hydraulic Leveling Systems on Class "A" Diesel Coaches. Model 3000.
These units work with the Hydraulic Leveling Systems.
Qty., 2, 906900404 Keypads Non Automatic leveling
Qty., 2, 906900406 Keypads Automatic leveling (Option)
Qty., 2, 906900404 Control boards. Housing fit 906900404 Keypad
Qty., 2, 906900407 Control boards. Housing fit 906900406 Keypad
The control boards are interchangeable, between the housings. All you have to do is change the jumper.
The automatic keypad will work with the non-automatic keypad, by changing the jumper. The automatic leveling feature will not operate. All other functions will work.
Contact me directly for further information on cost. I will sale these either as a complete unit or separately. The cost will be much lower than current online retailers.
Dale Prichard
gatorcqATgmail.com
Share this post
Link to post
I need to amend my first post. There is no automatic leveler.
The one I wrote as automatic is incorrect, what is has is a Led for Ignition and Brake. This item was used for Winnebago Industries part number 139643-02-000, and it is rectangle Vs square.
This keypad and controller board are interchangeable.
The controller board is the same for both keypads. There is a jumper that has to be moved.
See the link for what it looks like.
Share this post
Link to post
I just stumbled on your post about the Kwikee touch pad.  I need to replace the original Winnebago Level Best and need a reasonable solution.
It looked like you had one  for sale?
Share this post
Link to post
I need help with Kwikee Level Best touch pad replacement!
I have a 2004 Winnebago 27' class A and need to replace the leveler controls.  Does anyone know if there is another touch pad and circuit board that can replace the OEM touch pad that seems Winnebago specific?
Hunting for the exact replacement has been difficult at best and extremely expensive, $900-1,000+!
Edited by EmPeg
Share this post
Link to post
I am all out of control pads, have 2 boards left.
Contact by my email address, as I only monitor once a week,
gatorcq@gmail.com
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
