MsChrissi
Volvo newer front fender mirrors
One thing we really dislike on Red Flyer is the chrome mirrors on the front fenders.
It makes the RV look old and dated.
We'd really like to remove those and install the new style aero mirrors used on current models, has anybody done this?
Share this post
Link to post
Haven't done it,     YET!
But since y'all know a little about composites, the new style mirrors should fit, but you may need to make a "Bed" for them to mate to so they have the right tilt to them.  I haven't ordered any yet but I want to do the same.
Share this post
Link to post
Sorry for the multiple postings, something wrong with the forum things that says it choked the first time when it actually did post it.
Yes, far as we can tell the hood looks the same, can't be sure though. We've looked at the kit of parts and they are not too expensive. Was thinking of adding several layers of bidirectional glass to the inside to stiffen things up in that area as well.
Share this post
Link to post
That's what I was going to do as well, reinforce the inside.  I want to remove the hood latches and back glass that area as well.  I can see stress cracks on both sides there.
I don't know how much adjustment is in the arms.  Looking at the new style though, the arms are horizontal to the ground.  I'd hate to mount a set to have them looking like....... well I did it!
My issue is most RV parks don't appreciate the sound of an air grinder on Saturday morning!
Share this post
Link to post
The new mirrors should fit the gen-1 hood just fine.  If you look at the newer hoods, there's nothing in the way of reinforcing for those mirrors.  If you don't want to pay dealer prices for the genuine Volvo part, Amazon and Advantage Truck Parts both have them.
Here's the Amazon link for the Volvo parts: http://amzn.to/2noH8yv
Link for aftermarket set: http://amzn.to/2noACYG
And here's the one from Advantage: http://www.advantagetruckparts.com/volvo-truck-parts/volvo-truck-hood-mirror-complete-set-black/
Share this post
Link to post
I'll have to dig for the link, but I've also put a camera pointed down from my hood mirror.  Most valuable camera I have...
Share this post
Link to post
3 minutes ago, Scrap said:
Guy around us did it a few years ago.  Looks good!
Scrap,
Something tells me that if there were a conversation on here about a one legged midget stripper, that you would have a photo....lol
Great work!!!
Share this post
Link to post
Wow! thank you! I looked for this about a year ago and it was difficult to track down even the factory mirrors, now all this. And instructions too! thanks.
Share this post
Link to post
Not trying to hijack the thread bit just had a question...
Are the aftermarket mirrors as good of quality as the real volvo ones, or is it better to just to bite the bullet and get them from the volvo dealer?
Edited by bluflame11
Share this post
Link to post
Will let you know, ordered a set of the $150 ones .
Share this post
Link to post
11 minutes ago, Jack Mayer said:
I bought the aftermarket 2009 ones that they also use on the Cascadia. They were the same quality. Fromm the same company.
Have you mounted them yet? If so, how did it come out? Do they vibrate?
I was hoping that there were some kind of reinforcing backing plate involved, looks like we will have to do that with several layers of composite reinforcement.
Share this post
Link to post
They come with a plate. But you can reinforce them better. I did not install them, and I don't think the new owner did them yet. I would reinforce them. They do not vibrate much, based on driving my new truck.
Edited by Jack Mayer
Share this post
Link to post
Thanks!
Share this post
Link to post
Just to be clear...the 2009 ones are different than the current ones. You will want the current ones, and it will require hood work to fill the holes.  They locate differently.
Share this post
Link to post
I did that as well.  Also put one in the mirror facing back down the passengers side.  it's a fairly wide scan so it allows you to come up to a stop sign at an angle and not try to look thru the passengers side sleeper window to see traffic.
Share this post
Link to post
Yes we assumed that we'd be filling in the old holes. We countersink from both sides, fill and put some touch up paint on it.
Share this post
Link to post
MsChrissi,
I would be interested in knowing how your new mirror's turn out. I have the old style mirror on the passenger side of my truck. It would be nice to have mirror's on both sides. If you could post a picture or too after you finished your project  that would be great.
This is just an idea for a backing plate. Why not use some 16 gauge steel or aluminum on the inside of the hood. Try to make this plate twice the size of the area that the mirror mounting plate is covering. That way you will spread the load out over a bigger area.
Good luck with your project,      Al
Share this post
Link to post
Alan, we don't have the mirrors here yet but we were hoping that they would come with a steel backing plate. From the pictures it appears you get a rubber gasket but not a plate. I believe the factory uses plates.
To spread the load out we'd prefer fiberglass. The glass we use is typically 0.010" per layer. So to get a 1/8" backing plate it would take 12 layers. The smallest layer would be 1" larger than the base all the way around, each additional layer would be about 1/2" larger. This would all get laid out on HD tin foil largest layer first, wet out as you go and pick up the whole wad and apply it foil included to the area then massaged from the center out to push out the bubbles. Peel off the foil and cover with an oversized layer of thin Dacron. When it cures pull off the Dacron (won't stick) and it will be clean and smooth inside the hood without edges or discontinuities. This technique gives a distributed load without hard points that would cause cracking.
Share this post
Link to post
That sounds like it isn't going to give a bit when you walk into the thing!  I think I whacked my head within 30 minutes of installing the mirror on my truck.
As for the aftermarket mirrors, the one I bought is just fine.  Not noticeably different than the Volvo version.
Share this post
Link to post
MsChrissi,
Can you please explain more to me about using built up fiberglass for a backing plate. I also want to add the new style mirrors to my truck. I would like to get the best way possible for mounting the mirrors to the truck. I am used to using steel or aluminum. I want to learn.
Thank you for any input,     Al
Share this post
Link to post
Alan, if you are going to be anywhere near Lakeland FL in the next two weeks, come to the Sun N Fun airshow and Randi who teaches composites techniques in the workshops will give you the complete rundown in detail. She loves to help people with their projects.  It's good stuff, we built an entire 4 passenger airplane out of this stuff.
Otherwise if you cannot make it to FL or to WI in  late July, you would want to go with epoxy resin (avoid polyester resin), bi-directional cloth and the techniques outlined above. The resin and hardener are available from marine dealers like West Marine who sell "West System" epoxy resin and hardener in quart cans with calibrated pump tops that make dispensing and measuring easy. The materials and techniques learned would be useful for repairing any of the composite components used on Volvos.
I suppose if we ever made it to a rally we could do a demo mirror install and teach this.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Rvonthego.com
