Winegard Trav'ler Issue
We have a Trav'ler with Dish network on 2016 FR Cedar Creek. We bought it last March and haven't had issues until this trip. We took our Hopper 2 from the house (no issues at home) and took off for the holidays. We made 3 different stops over 2 weeks and changed our service address each time.
The issue is we would lose a satellite on a regular basis and doing something would fix it. If we reset the Hopper it would be fine if we repointed the dish it would be fine so anything we did would resolve the problem temporarily. I did a switch check and it would fail on tuner 3.
I checked all the connections both at the Trav'ler and at the Hopper and nothing was overtly loose. We got home yesterday and I hooked the Hopper up at home and checked the switch again and it was fine.
Would y'all give me a direction to go from here. I don't have testing equipment nor do would I know how to use it if I had them.
So where should I begin?
2013 Newmar Dutchstar 4318
2019 F150 KR 4X4
BlueOx 10K Tow Bar
What is a Solo Node? What does it do?
Spoke to Winegard this morning and they said I would need one at the Trav'ler to run the Hopper 2. Found one on Amazon looks simple to get up there and install.
We only use the Hopper for extended trips and use a 211 for short weekend trips, will the Solo Node effect the 211?
2019 F150 KR 4X4
BlueOx 10K Tow Bar
The Solo Node combines two of the LNB output ports to support the three tuners on your H2. Your 211 will not work with the Solo Node, but you can use the third output port to feed it instead, leaving the Solo Node connected for the H2. You could even use both receivers at the same time if you wanted to, with one connected to a second TV. I'm not familiar with just how the Trav'ler control setup works, but hopefully someone that does will jump in and fill in the blanks. At least now you know why the third tuner on your H2 was not working.
Dutch
2001 GBM Landau 34' Class A
do not need a solo node just for the Hopper.
Press menu
select setting
select diagnostics
select system status
Line 'a' watch and wait till 100 %
Report on what you see
119 (green(, 110 (green), 129 (green)
line 'a' good
Susan & Dale
DaGirls Rv 2008 Alfa Gold SoLong ISL 425 Cummins
2015 Ford F-150 XLT Tow / Roadmaster Setup
1600W@45Vdc Magnum Inv/Chg&Solar
880AmpHr
DaGirlsRv Blog
Ok, why do you think he was missing tuner 3?
A single coax cable in Dish Pro Plus supports two multiplexed signal streams. Ergo, one coax from the Dish to the Solo carries two of the three data streams while the second coax from the Dish to the Solo carries the third signal stream.
The Solo combines the three data streams from the Dish into the Coax from the Solo to the Hopper. That coax is using MOCA 8x multiplexing to get the three Dish data streams into the Hopper and the data streams out to the Joeys.
So without a Solo, only two tuners will be active. You might pass the Switch Check with a single cable and no Solo, but you won't work very well if you want to watch more than two satellites.
Mark & Dale
www.dmbruss.com
So just as I said, the Solo Node is needed to feed all three H2 tuners. And the lack of one answers why the OP's Hopper was not seeing the third tuner.
Dutch
Press menu
select setting
select diagnostics
line 'a' good
Of course it sees all two or three sats depending on which arc and which LNBF is in use. What doesn't work without the Node is all three H2 tuners.
Dutch
My experience with a missing satellite/tuner on our Hopper might be unique and it might be the OPs problem. It took several weeks and multiple onsite techs and visits to correct. It started with a Solo Node which failed. Once the solo node was replaced, the problems started. Every tech that saw the system insisted on putting new terminator hardware on the cables and reconnecting the solo node. One of those techs managed to install one of the antenna coax's so that the center connecter touched the housing of the solo node (effectively grounding it). Run all the check switches and system status checks you want, only 2 tuners were available. The Hopper was swapped out, same result. The last tech to visit decided to revisit every connection before he left. Voila, eureka, etc. - the problem cleared up instantly and everything has been working as intended for the past year.
Not an antenna problem, not a Hopper problem, just a human cabling error.
Roger & Mary
2014 Phaeton 36GH
2012 Honda Fit
Zoe (lab mix) and the cats (Sam & Milly)
