Biker56 Posted May 9, 2017 Report Share Posted May 9, 2017 2 hours ago, SWharton said: Maybe someone can answer a question that we have always had. Why do people need to hook up the elec, water and sewer each night? Unless it is dumping day, we just use electricity each night and even if we are dumping we put everything away after dumping. I am not talking about small trailers but MHs and big trailers that have plenty of tank capacity. Maybe they don't want to carry the extra weight that may cost MPG loss? Myself when traveling for 4-5 days to a destination I only hook up electric overnight. If site is fairly level I don't even put my jacks down. And never put the slide out. I use the Prest-O-Fit hose for the ease of adding length if needed and changing the ends. I don't know how many years I have used the present hose. But it is more then 5. I only use it during my 5 month summer travel. The other 7 months I use a 1" Macerator hose at my winter spot that is uphill. I find it is too slow dumping to use in the summer and doesn't get you the Whooooose like the slinky. But the Macerator hose has never needed replaced for over a decade. Quote Full Time since Oct. 199999 Discovery 34Q DP | ISBDatastorm | VMSpc | Co-Pilot Live | Pressure Pro2014 MKS Twin Turbo V6 365 HP Toad Link to comment Share on other sites More sharing options...
SWharton Posted May 9, 2017 Report Share Posted May 9, 2017 Pound wise and penny foolish. I bill myself out at $10/hour, the time to clean the hose each day is more than what I would save. Especially if it rainy or 30 degrees or very windy............. Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted May 9, 2017 Report Share Posted May 9, 2017 1 hour ago, SWharton said: Pound wise and penny foolish. I bill myself out at $10/hour, the time to clean the hose each day is more than what I would save. Especially if it rainy or 30 degrees or very windy............. 10 bucks an hour ? That's cheap . Stop by our rig . I have a few things that need doing . Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
SWharton Posted May 9, 2017 Report Share Posted May 9, 2017 That's internal rate. External is significantly higher. I know it's cheap but it sure stops me from buying and doing all sorts of things. I've used that number for years and it has worked out well. Quote Link to comment Share on other sites More sharing options...
Pat & Pete Posted May 9, 2017 Report Share Posted May 9, 2017 7 hours ago, SWharton said: That's internal rate. External is significantly higher. I know it's cheap but it sure stops me from buying and doing all sorts of things. I've used that number for years and it has worked out well. Hmm , Conditions ... after the fact . I see how you are . LOL Quote Goes around , comes around . Link to comment Share on other sites More sharing options...
TXiceman Posted May 10, 2017 Report Share Posted May 10, 2017 I have had to replace my RhinoFlex more often now than the older ones I had. Seems the material quality has gone down and they do not last as long. Ken Quote Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
Dan & Belinda Posted October 25, 2019 Report Share Posted October 25, 2019 On 9/28/2016 at 10:09 AM, GR "Scott" Cundiff said: Thanks for all the responses - interesting. For anyone still following, do your hose failures generally happen as you are extending/collapsing the hose or while you are dumping? As you can guess, spewing contents would be worse than it just cracking while being stored. Mine has lasted 18 months, discovered whilst dumping a split and black water spraying out. Quickly shut off valve and sanitized affected area. Quote Link to comment Share on other sites More sharing options...
GR "Scott" Cundiff Posted October 25, 2019 Author Report Share Posted October 25, 2019 Interesting that this old thread was brought back to life by Dan (thanks). Just this week I had either a 1 1/2 or 2 1/2 year old hose (no sure which one it was at this point) spring a couple of leaks down close to the end. I cut the hose back and put the fitting back on. Going to keep an eye on it and see how it does. Quote Our "Here and There" Blog 2005 Safari Cheetah Motorhome Link to comment Share on other sites More sharing options...
Twotoes Posted October 25, 2019 Report Share Posted October 25, 2019 I have been using the Rhino hoses for 7 years now. I am full time and use the hose 24/7/365. My first Rhino Flex hose lasted 5 years but got a tiny pin hole from a thorn on the ground and had to be repalced. I replace it with the new Rhino Extream hose which is 2 years old and no problems. Quote 2015 Itasca Ellipse 42QD 2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition 2021 Harley Street Glide Special Fulltimer Link to comment Share on other sites More sharing options...
Ray,IN Posted October 25, 2019 Report Share Posted October 25, 2019 (edited) On 9/28/2016 at 12:30 PM, strawdog said: In the over 10 years we have been using RhinoFlex hoses we have never had one start leaking while it was hooked up except once when a park grass cutter went along it with a weed eater. Doesn't mean it might not happen the next time I open the dump valve.... All failures we have had were small cracks usually close to the fittings after the hose had been collapsed, stored then re-extended. That being said I have noticed that the quality (longevity) of the hoses (not the fittings) has gone down since Camco bought them out.... Dave That's my problem, over-paid weed whacker operators try to trim underneath my hose. Edited October 25, 2019 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
rynosback Posted October 26, 2019 Report Share Posted October 26, 2019 (edited) 3 years on one until it got stepped on. I cut out the crushed part and now when I have short runs or have to go to a dump station I have a short hose to use. I then bought a new one for longer runs. Plus I carry a 15” extension. Also a 90 & 45 degree clear elbows. The new heavy duty ones look very nice and long lasting. Edited October 26, 2019 by rynosback Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
Gabe1105 Posted November 1, 2019 Report Share Posted November 1, 2019 After a year use, why not just buy a new one? They're $29.99. Quote Link to comment Share on other sites More sharing options...
donh3236 Posted January 6, 2020 Report Share Posted January 6, 2020 We are fulltimers going on 3 1/2 yrs. We've used the same Rhino hoses and fittings during that period with no issues. It was worth the extra cost. Quote Link to comment Share on other sites More sharing options...
