RandyA Posted September 3, 2016 Report Share Posted September 3, 2016 The Trex decking is gone. It served me well for six years. In its place are 2” x 8” aluminum bleacher foot boards. Unlike bleacher seats they have squared edges and are physically stronger than the seat boards. You can see this in the cross section – 3/16” thick, hard aluminum. Right now nothing is screwed down and the boards have not been cleaned and the holes need to be filled. The boards were cut to the needed size from 12’ long pieces using a carbide blade on a 12” sliding miter saw. The two hatch doors have been made by bolting the aluminum together and riveting on a 1” x 1” angle edging. All fasteners, cleats, and hinges will be stainless steel. The 4” x 4” pressure treated sub frame I put on in 2010 is still in good condition and intact. There was no reason to replace it. A Smart is not in the future and the current framing carries a golf cart with no issues. The existing PVC side panels worked into the change from 5/4” Trex to the 2” aluminum by using a filler strip along the top edge and 2” x 2” aluminum angle to cover the edges of the thicker decking. This made the project a little easier and less expensive. Still a fair amount of work before I can call it done but I can now see what a finished project will look like and I am pleased. The rear, which was previously just painted, has been covered with diamond plate aluminum and new LED tail lights (which the Volvo LCM does not like). Everything was found in surplus outlets while in Goshen, IN in August. I bought the twelve 12’ long aluminum boards for $16.50 each ($198) – that is about $2.00 a square foot. I initially thought about putting a truck bed coating on the surface but have since decided to just clean them real good and leave the natural gray mill finish. I brought back more goodies but will save what they are and how I intend to use them for a later post. Right now I have the outer band of a hurricane with a forecast of 40 mph wind and lots of rain to prepare for (note the standard issue Volvo propeller - it may come in handy ) . I look forward to my now annual trek to the surplus places in and around Elkhart. They have so much to offer at pennies on the dollar if you just take the time to dig through everything and use a lot of imagination . Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
lovehamr Posted September 3, 2016 Report Share Posted September 3, 2016 Randy, that's turning out great! Quemadmoeum gladius neminem occidit, occidentis telum est. Link to comment Share on other sites More sharing options...
Refuzn-To-Grow-Up Posted September 3, 2016 Report Share Posted September 3, 2016 Very clever and frugal! I like it. Link to comment Share on other sites More sharing options...
Bob Cochran Posted September 3, 2016 Report Share Posted September 3, 2016 As usual will be fun to watch the progress and innovation as you go along. 2019 Thor Chateau 28E on a Ford E450 chassis. Maybe awhile but will get a new picture forgive one up there it is my old rig. Link to comment Share on other sites More sharing options...
Broncohauler Posted September 3, 2016 Report Share Posted September 3, 2016 Like it , nice job. Link to comment Share on other sites More sharing options...
dblr Posted September 3, 2016 Report Share Posted September 3, 2016 Randy, very nice looking. Glad you were able to get across the lake on the race track to find your goodies. Looking forward to next year to see what else you come up with. 2017 River Stone Legacy 38MB 2001 T2000 Kenworth 2009 Smart Passion ET Junior hitch Link to comment Share on other sites More sharing options...
sclord2002 Posted September 3, 2016 Report Share Posted September 3, 2016 Randy, wow......that is looking great. I am looking forward to seeing it in person. Charlie Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
Nuke-E Posted September 3, 2016 Report Share Posted September 3, 2016 Randy, Give me a call and I'll get you through the LCM issues if you don't already have it all figured out. 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
RandyA Posted September 4, 2016 Author Report Share Posted September 4, 2016 Randy, Give me a call and I'll get you through the LCM issues if you don't already have it all figured out. David, I have a couple of ways in mind to make the LCM happy but would still like to know what yours is - it's probably better. I would also like to talk with you about sourcing L-Ion batteries for another project I have in mind. I don't have your number - I guess I did but don't know where it is now. Please PM me or email professor95 at comcast dot net. I would like to talk with you. And Thanks! Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
MrSeas Posted September 4, 2016 Report Share Posted September 4, 2016 Found a "trick" on my truck that may also work on yours concerning the LED's and the LCM. It appears that the LCM can "learn" when a light configuration is changed..... When I swapped out some LED's the LCM threw some fault codes and I just ignored them. After a number of key cycles the faults went inactive and everything seemed to work as normal. I didn't really count the key cycles but I'm guessing it was between 5 and 10. Don't know if this works on all of the LCM's but might be worth a try. Link to comment Share on other sites More sharing options...
Jack Mayer Posted September 4, 2016 Report Share Posted September 4, 2016 Randy, Give me a call and I'll get you through the LCM issues if you don't already have it all figured out. Well, I still have a Check on my new lights, and the LCM certainly should have trained itself by now. The lights went on at the Rally last year. The Check was not present when the lights were first installed, but then appeared after we left the Rally and has been present since. We should take a look at it at the Rally. They work great....best lights I have seen that were "stock"-like. (not add-ons to the grill). Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Nuke-E Posted September 4, 2016 Report Share Posted September 4, 2016 Well, I still have a Check on my new lights, and the LCM certainly should have trained itself by now. The lights went on at the Rally last year. The Check was not present when the lights were first installed, but then appeared after we left the Rally and has been present since. We should take a look at it at the Rally. They work great....best lights I have seen that were "stock"-like. (not add-ons to the grill). Definitely--if all goes according to plan, I'll be there right around 10/1. 2009 trucks are definitely the most stubborn/slow learners, but it's an easy fix. Randy--PM sent. 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
MrSeas Posted September 4, 2016 Report Share Posted September 4, 2016 Jack are you talking about "headlights"? Link to comment Share on other sites More sharing options...
rpsinc Posted September 4, 2016 Report Share Posted September 4, 2016 How does the aluminum foot board work in the heat? As a heat sink, I wonder about them getting hot, esp when you want to put your HANDS on it. OUCH! I really like the idea though. Great repurposing. Marcel Link to comment Share on other sites More sharing options...
GlennWest Posted September 4, 2016 Report Share Posted September 4, 2016 I know my black steel bed in direct sunlight gets so hot bare skin will burn if it touches it. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Refuzn-To-Grow-Up Posted September 4, 2016 Report Share Posted September 4, 2016 Another plus is that these foot boards were probably manufactured to survive the elements. Link to comment Share on other sites More sharing options...
Jim & Wilma Posted September 4, 2016 Report Share Posted September 4, 2016 2009 trucks are definitely the most stubborn/slow learners, but it's an easy fix. Agree they're stubborn so we opted for the lobotomy route. Timing was good for us because we installed your bi-xenon lights before we had Volvo make some necessary computer setting changes. When we took the truck in for removal of the 65 mph governor, we had some other settings we wanted to change and it was simple to also remove the LCM error message on low headlight current. Couldn't be more pleased with the lights David! Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
Randyretired Posted September 5, 2016 Report Share Posted September 5, 2016 I used stadium seat aluminum to make the cross sections on the ramps I use. It is not painted. The black steel bed is much hotter than the ramps in the sun. Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
RandyA Posted September 5, 2016 Author Report Share Posted September 5, 2016 How does the aluminum foot board work in the heat? As a heat sink, I wonder about them getting hot, esp when you want to put your HANDS on it. OUCH! I really like the idea though. Great repurposing. Don't know yet - but not deciding to put black bed coating on them was in part due to heat retention. The aluminum is sure to get hot but at least it is reflective and should stay a few degrees cooler underneath with the way it is made that will allow air flow. The old Trex composite decking would get hot too, hot enough that you did not want to put bare hands on it. The bad thing was the Trex would expand considerably and needed extra supports to prevent sag when exposed to 90+ degree heat and direct sunlight. It didn't rot, splinter or need sealing but there is only so much structural strength to a board made of recycled plastic milk jugs, sawdust and resin. The aluminum will do a much better job. I do have up some surplus fire sprinkler heads and piping. Thought I might convert one of the 150 gallon fuel tanks to water and put in a pump with a temperature sensor on the aluminum decking and run the sprinklers overhead. Now, when it gets hot the fire sprinklers will spray cool water over the aluminum. A second benefit is Nancy can use the sprinkler piping to hang laundry - even dry it as we drive down the road. OK - NOT TRUE. But I thought it would make a good story . Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
HERO Maker Posted September 5, 2016 Report Share Posted September 5, 2016 Your stories are usually good reading, but now I may need to start reading them a little closer and fact check a few! But Randy, instead of sprinklers, just make them misters! Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Jack Mayer Posted September 5, 2016 Report Share Posted September 5, 2016 Jack are you talking about "headlights"? Yes....I put on (actually David put on) all new housings with his bulbs. Definitely the way to go - polishing does not typically last long. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
RandyA Posted September 6, 2016 Author Report Share Posted September 6, 2016 Yes....I put on (actually David put on) all new housings with his bulbs. Definitely the way to go - polishing does not typically last long. Coat them with urethane clear coat after polishing - may need to get a paint & body shop to do that since the product does not come in rattle cans. All other coatings like acrylic, lacquer, product wipe on's are not going to hold up, but the urethane clear will last longer than the OEM coating and will not yellow. I have David's lamps as well and am very pleased with them. The LCM on my '04 adapted to the LED high beam replacements with no problems. I did have to put 6 ohm, 50 watt resistors on the LED tail lights and turn signals. It would not learn those without the resistance of a 1157 filament lamp. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
Nuke-E Posted September 6, 2016 Report Share Posted September 6, 2016 When they were $500+ each from the dealer (not that many years ago), I'd be in the camp of polishing them until there were holes in the plastic, and urethane definitely prolongs the life of the polishing job as Randy points out (not doing anything afterwards will be an exercise in frustration). At least on my housings (2004 vintage Volvo housings, presumably original), the rubber trim had deteriorated, and one of the adjusters was broken. I limped along for a while with a wedge holding the movable part of the internals, and used a window molding of some sort for a while. But with new housings a lot more affordable in the aftermarket, that's what I'd probably do now. If you go to Advantage Truck Parts, you can order Depo housings (like what Jack has) for $340+shipping, which should be good for a few years at least. If there's interest, I suppose I could coordinate a group buy with Advantage Truck Parts for the national rally like we did at the ECR. So long as we don't tip Gregg's Smart over in the process! Everybody--whether Volvo, KW, Pete, Toyota, etc., or aftermarket--uses polycarbonate with a UV-inhibiting coating. All of the name-brand stuff should meet FMVSS108 standards against yellowing (3 years in AZ and FL), and there are some coatings that go above and beyond. But the standard addresses UV weathering assuming no physical wear or abrasion (a separate test). With enough miles, those coatings get scrubbed away, and the unprotected polycarbonate then quickly degrades--either hazing with UV exposure, or stress corrosion cracking from salt water exposure. Particularly on trucks that see a lot of mileage, and particularly on the very large gen-2 Volvo headlights, it's not uncommon to have lights the color of something you'd order at Starbucks by the time the trucks are 3-5 years old, and that's without saying anything about internal degradation, which is one of the Volvos' acute weak spots. A plastic projector in close proximity to a halogen bulb doesn't last long, particularly when the lens acts as a magnifying glass in direct sunlight. While I had pretty good experience with urethane, it would seem that there's some reason it isn't used as original equipment--I might try to dig a little more on that. Randy--With those resistors, make sure you get them in good thermal contact with something metal to help dissipate the heat, ideally with some thermal grease. There are guys out there that try to use those without a good bond, and they'll go up in smoke at a nice long red light. 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
Pete Kildow Posted September 8, 2016 Report Share Posted September 8, 2016 The Trex decking is gone. It served me well for six years. In its place are 2” x 8” aluminum bleacher foot boards. Unlike bleacher seats they have squared edges and are physically stronger than the seat boards. You can see this in the cross section – 3/16” thick, hard aluminum. Right now nothing is screwed down and the boards have not been cleaned and the holes need to be filled. The boards were cut to the needed size from 12’ long pieces using a carbide blade on a 12” sliding miter saw. The two hatch doors have been made by bolting the aluminum together and riveting on a 1” x 1” angle edging. All fasteners, cleats, and hinges will be stainless steel. The 4” x 4” pressure treated sub frame I put on in 2010 is still in good condition and intact. There was no reason to replace it. A Smart is not in the future and the current framing carries a golf cart with no issues. The existing PVC side panels worked into the change from 5/4” Trex to the 2” aluminum by using a filler strip along the top edge and 2” x 2” aluminum angle to cover the edges of the thicker decking. This made the project a little easier and less expensive. Still a fair amount of work before I can call it done but I can now see what a finished project will look like and I am pleased. The rear, which was previously just painted, has been covered with diamond plate aluminum and new LED tail lights (which the Volvo LCM does not like). Everything was found in surplus outlets while in Goshen, IN in August. I bought the twelve 12’ long aluminum boards for $16.50 each ($198) – that is about $2.00 a square foot. I initially thought about putting a truck bed coating on the surface but have since decided to just clean them real good and leave the natural gray mill finish. I brought back more goodies but will save what they are and how I intend to use them for a later post. Right now I have the outer band of a hurricane with a forecast of 40 mph wind and lots of rain to prepare for (note the standard issue Volvo propeller - it may come in handy ) . I look forward to my now annual trek to the surplus places in and around Elkhart. They have so much to offer at pennies on the dollar if you just take the time to dig through everything and use a lot of imagination . Great ideal and makes for a nice bed. That will out last the wood for sure. Pete Link to comment Share on other sites More sharing options...
Nuke-E Posted September 9, 2016 Report Share Posted September 9, 2016 On the subject of polishing, the 3M kit that you can get at the auto parts store for $15-20 is on sale on Amazon today, and there's a $5 rebate from 3M to make the cost about $4. 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
