Ray,IN Posted July 28, 2016 Report Share Posted July 28, 2016 This announcement appears to be classifying GM 3500, 3500HD trucks as medium-duty trucks, with a gasoline engine. It' confusing to me. Did the industry modify the age-old truck classifications? re: Light-duty = class 1,2, or 3; medium-duty = class 4,5, or 6; heavy-duty = cl 7 or 8. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Newt Posted July 29, 2016 Report Share Posted July 29, 2016 The insurance company called our Dodge 3500 a MH. Newt 2012 HitchHiker Discover America 345 LKSB 2009 Dodge/Cummins LIVINGSTON TX Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted July 29, 2016 Report Share Posted July 29, 2016 What's the problem? The Volvo plant that makes predominately Class 8 trucks also makes Class 7, 6, and 5 trucks. GM had dropped out of the MDT market (4500, 5500) trucks and is coming back in. Many of the components of 4500/5500 are also in the 3500HD. I think calling the plant a MDT plant is reasonable. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Chalkie Posted July 29, 2016 Report Share Posted July 29, 2016 I could be wrong here, but in looking at that announcement, the trucks they are talking about are based on the Isuzu N-series, and will not be a pickup truck. As to the actual classification as medium duty trucks, based on capacities, I do think that is misleading. Here is what I found for these new Chevy models: http://www.chevrolet.com/low-cab-forward-trucks.html Link to comment Share on other sites More sharing options...
skp51443 Posted July 29, 2016 Report Share Posted July 29, 2016 The rules on class assignment haven't changed and still mean very little to RV folks as they are a tax classification based on the weight a truck can carry not pull. RV folks are better off ignoring the class / tax classification numbers and dealing with the actual specifications of the truck that matter for RV use. First rule of computer consulting: Sell a customer a Linux computer and you'll eat for a day. Sell a customer a Windows computer and you'll eat for a lifetime. Link to comment Share on other sites More sharing options...
forxlr8n Posted August 15, 2016 Report Share Posted August 15, 2016 What's the problem? The Volvo plant that makes predominately Class 8 trucks also makes Class 7, 6, and 5 trucks. GM had dropped out of the MDT market (4500, 5500) trucks and is coming back in. Many of the components of 4500/5500 are also in the 3500HD. I think calling the plant a MDT plant is reasonable. We only build class 8 trucks. Mike Hayes, Volvo truck builder "If you can not measure it, you can not improve it." Lord Kelvin Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted August 15, 2016 Report Share Posted August 15, 2016 Unless you order with a lighter single rear axle. Like a VNL 200 with a 19,000 lb rear and a 11,000 lb front would be 30,000 GVWR Class 7. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted August 15, 2016 Report Share Posted August 15, 2016 None of the HDT plants will let you order a single axle in the rear less than 23 K. Even with a 23K rear, some of them (Kenworth and Peterbilt for certain) will limit the engine to 1650 on the available torque. Any front axle over a 10K rating will put you into class 8 territory. Ours has a 13.2K front and a 23K rear and is a class 8 for weight ratings. We tried very hard to get the factory to downgrade the weight ratings to get out of the extra taxes but it was a no go. The feds go by the rating of the installed components. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted August 15, 2016 Report Share Posted August 15, 2016 You are right about 1650 torque and 23 K rear axles. But there are smaller engines (D11 1250 torque) and 13.8K front axle is no way standard. My VNL 770 had a 12.2 K front axle. When I took off one of the 19K rear axles, that put Red Rover at 31.2, and was re-rated as Class 7. And while I had the bed built, the load capability of the bed can reduce the GVWR of the truck. Yes the Feds count components, all the components. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted August 15, 2016 Report Share Posted August 15, 2016 And while I had the bed built, the load capability of the bed can reduce the GVWR of the truck. Yes the Feds count components, all the components. No I am confused. Wouldn't the GVWR remain the same? Doesn't make any difference if the weight is pin weight, bed weight, drom box or anything else, the GVWR should be the same. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted August 15, 2016 Report Share Posted August 15, 2016 If I had asked, the bed builder would have set the GVWR at 26,000 based upon limitations of what weight could be placed on the bed. If I had that done and then carried a load that pushed the GVW over 26,000 then I would have to deal with the law if stopped. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Scrap Posted August 16, 2016 Report Share Posted August 16, 2016 That is probably a good conversation to have with Herrin. We made sure your truck was done as full truck/incomplete vehicle so maybe they can re-rate when they do their final certification? Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted August 16, 2016 Report Share Posted August 16, 2016 Scrap, makes no difference when paying the fee tax on the truck. They don't care what it is rated at only what it is equipped with as far as load ratings go when it is built. Georgia tags are cheap now (less than $100) so that is a wash. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted August 16, 2016 Report Share Posted August 16, 2016 Larry doesn't recertify anything, he just builds a bed and mine will be close to 33K or better when road ready. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Ray,IN Posted August 16, 2016 Author Report Share Posted August 16, 2016 Quote from the link Chalkie provided: 3500HD Low Cab ForwardEquipped with a DOHC 3.0L I-4 4J turbocharged diesel engine paired with a 6-speed transmission with double overdrive, the 3500HD delivers 150 hp and 282 lb-ft of torque. Available in Regular Cab configuration. 4500HD & 4500XD Low Cab ForwardFitted with a 5.2L I-4 4H turbocharged diesel engine and paired with a 6-speed transmission, the 4500HD and 4500XD deliver 215 hp and 452 lb-ft of torque. Both are available in a Regular Cab and Crew Cab configurations. 5500HD & 5500XD Low Cab ForwardEquipped with a 5.2L I-4 4H turbocharged diesel engine, the 5500HD and 5500XD produce 215 hp and 452 lb-ft of torque. The 5500HD is available in Regular Cab and Crew Cab configurations. The 5500XD is available in a Regular Cab configuration. None of those stats sound like they have enough power/torque to pull much of a load, nor is towing even mentioned. They will be just as under-powered as previous Isuzu trucks. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
forxlr8n Posted August 16, 2016 Report Share Posted August 16, 2016 My MDT is listed at 33k pounds 12k on the front and 21k rear so I guess it's a HDT with a small motor. "If you can not measure it, you can not improve it." Lord Kelvin Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted August 16, 2016 Report Share Posted August 16, 2016 You don't have a medium duty truck. A class 7 is 26,001 to 33,000 pounds and a class 8 is 33,001 and up. Any class 7 or 8 truck is considered a HDT and most will have air brakes as well. My older Freightliner was rated at 30,700 pounds despite have a 23K rear and a 12K front to avoid the fed tax at that time. As far as engines go, I still remember working on 250 Cummins back in the early 70's. The "250" designation was the HP rating and those were class 8 over the road tractors. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
