oldjohnt Posted July 18, 2016 Report Share Posted July 18, 2016 Of course, I generally prefer the fresh water demand pump at or below the level of the tanks outlet so gravity feeds the pumps suction inlet and it don't have to lift any whatsoever. HOWEVER I'm installing an auxiliary fresh tank with no more then 3 feet of 1/2" inlet suction hose BUT THE PUMP WOULD BE ABOUT 6 INCHES HIGHER then the auxiliary tanks outlet, so the pump would have to lift about 6 inches max when the water level is near the bottom portion. QUESTIONS: Are those typical fresh water demand pumps (Mines a Shur Flo 35116 or something like that) capable of lifting maybe 6 inches???? Even if so, its not going to loose prime each time and have to pump back up each use???? Would an inline check valve on the suction side be required or of any use??? I guess once I hook it up (if mounted in current location) it will be easy to find out the answer lol. There's just no place to mount it so its higher then the pump grrrrrrrrrrrrrrrrr John T Plumbing just aint my cup o tea Link to comment Share on other sites More sharing options...
Darryl&Rita Posted July 18, 2016 Report Share Posted July 18, 2016 When the tank's full is the time to recharge any lost prime, so as long as the tank top is higher than the pump, I'd go for it. Once prime is established, water out has to pull water in. Other than the built in check, I'd stay away from any type of checks on the suction. The idea being that any check valve will introduce a restriction on the line, and increased restrictions will increase the chances of issues. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Dutch_12078 Posted July 18, 2016 Report Share Posted July 18, 2016 The ShurFlo Revolution pump is rated to dry prime up to 6'. ShurFlo Revolution 4008 Data Sheet Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Zulu Posted July 18, 2016 Report Share Posted July 18, 2016 If you need a new pump, I recommend the Remco Aquajet ARV it can prime up to 13 feet. SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
oldjohnt Posted July 19, 2016 Author Report Share Posted July 19, 2016 Thanks gang, no I don't need a new pump, mine works perfect and pumps to 50 PSI, I'm just wondering if it will LIFT 6 inches ???? and from what I see Ima thinking NO PROBLEM lets hope so, I will know in a few days once I hook up the auxiliary tank. MISTAKE ALERT my old RV had a Shur Flo, this one is a Flo Jet, works great so far. John T Link to comment Share on other sites More sharing options...
Ray,IN Posted July 24, 2016 Report Share Posted July 24, 2016 John, if it looses prime the diaphragm has a leak/hole. If the pump is ran dry and I then try to pump up to pressure without opening a faucet it will not prime. I must open a faucet first, then it primes easily. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
oldjohnt Posted July 24, 2016 Author Report Share Posted July 24, 2016 Good Neighbor Ray, as a matter of fact I just today 2 hours ago got the aux fresh water tank all hooked up and it primes, pumps and maintains good pressure, and is still working, even though it has to LIFT the water maybe 6 inches yayyyyyyyyyyyyyyyyyyyyy. HOWEVER as we already know there cant be even a teeny air leak in the suction side or it will drain back, loose prime and cant pick it back up. How do I know ?? I already did but find its still true lol. Earlier today I had a small leak grrrrrrrrrrrrrrrr. After I went back and refreshed and tightened and sealed all the suction side hose barb and hose clamp connections and tightened her all down, there's no more teeny air bubbles and she don't drain back out and holds its prime (suction inlet line stays full) and pumps fine. I added an auxiliary tank to my existing fresh water as my goal is to be able to dry camp at least 7 days before we have to dump and take on water as the case when were in the Colorado or Utah mountains on BLM or Natl Forest lands. Life is good We gotta visit sometime as we live so close. I go to Frank Baileys sometimes on Sundays to his Bluegrass jam, I take it you live southwest of Bloomington. John T Link to comment Share on other sites More sharing options...
