hemsteadc Posted May 2, 2016 Author Report Share Posted May 2, 2016 Pressure holding. I'll keep checking but looking good! 8 pm. not a drop of pressure loss! Thanks Pug and everyone! I'm goin' campin'! Link to comment Share on other sites More sharing options...
hemsteadc Posted May 3, 2016 Author Report Share Posted May 3, 2016 Spoke too soon. Pressure holds for many hours, but leaks out overnight. That doesn't make sense. Looks like it's a trip to the shop as I'm tired of working on it. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 3, 2016 Report Share Posted May 3, 2016 This is where one of these works great- http://www.amazon.com/dp/B000TRJA8M/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=1JOY56WRER6SQ&coliid=IGTJT29KVVYV9 Having the small leaks that aren't strong enough to produce a bubble, or to hear are tough to find. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Morelli Posted May 4, 2016 Report Share Posted May 4, 2016 Is it still leaking from the same spot ? Link to comment Share on other sites More sharing options...
hemsteadc Posted May 4, 2016 Author Report Share Posted May 4, 2016 I'm pretty sure that drain valve isn't leaking now, but I don't know where it's leaking from. I suppose I could clean the other drain valve that's on the tank for the rear bags, but they stay up just fine. Link to comment Share on other sites More sharing options...
skp51443 Posted May 4, 2016 Report Share Posted May 4, 2016 Maybe borrow an air-leak detector from one of the folks in the HDT forum if you are near someone that has one? First rule of computer consulting: Sell a customer a Linux computer and you'll eat for a day. Sell a customer a Windows computer and you'll eat for a lifetime. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted May 4, 2016 Report Share Posted May 4, 2016 I have a Whisperer that you can borrow if you are near the Chattanooga, TN area. I will also be in the Orlando and St Augustine, FL areas in the next two weeks. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
hemsteadc Posted May 4, 2016 Author Report Share Posted May 4, 2016 Central WA. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted May 4, 2016 Report Share Posted May 4, 2016 Just a bit of a drive... Ever thought of visiting the southeast? 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
MrSeas Posted May 4, 2016 Report Share Posted May 4, 2016 Central WA. Join us in Idaho for the WCR...plenty of whisperers to help you out! Link to comment Share on other sites More sharing options...
Randy and Helen Posted May 7, 2016 Report Share Posted May 7, 2016 New to the forumn..I have a 08 m2 with a 8.3 cummins. Had a severe air leak on the automatic bleed valve while in Florida this past winter. The compressor work hard and cycled on and off a lot. Finally pulled these two automatic bleed valves and replaced with manual pull. Local diesel shop said this is what the big boys use. Just pull the cable once a day and bleed. Cost is $15 each. The system does bleed down over 4-5 days. Noticed the rear air bags still up. Don't know where the air gauge taps into the system. Link to comment Share on other sites More sharing options...
Randy and Helen Posted May 7, 2016 Report Share Posted May 7, 2016 No air dryer on my 8.3 m2. Looked all over the truck. Local cummins dealer also looked and did not find. Just wonder if freightliner didn't install as this unit does not have air brakes Link to comment Share on other sites More sharing options...
Morelli Posted May 7, 2016 Report Share Posted May 7, 2016 Not all years did M2 have air dryers, it was an option. Do not understand why on a truck with air brakes they made that an option but then logic is always a mystery with when it comes to profits ! If you have air on the truck, think about adding a dryer, important and very useful item. They can be added after the fact. Link to comment Share on other sites More sharing options...
hemsteadc Posted May 7, 2016 Author Report Share Posted May 7, 2016 pulled these two automatic bleed valves and replaced with manual pull. Local diesel shop said this is what the big boys use. Just pull the cable once a day and bleed. Where are the cables? Link to comment Share on other sites More sharing options...
Randy and Helen Posted May 7, 2016 Report Share Posted May 7, 2016 Thanks pug..Probably be selling my rig next year as we are looking at a more permanent place south for winter and doing some over seas travel. Truck will have less than 44k miles. Truck has been great. No problems with wind or hills. Most mountains that we have been over have been above 45. Now we're talking about here to Alaska and back over the cassiar highway. Several 6-10 percent grades. Here in Idaho the roads have a lot of curves so you can't get much of a run at. Still above 45. Old truck pulling 12k less weight might be at 30-35 at top. Very happy with setup. Link to comment Share on other sites More sharing options...
Randy and Helen Posted May 7, 2016 Report Share Posted May 7, 2016 Earlier there was a post concerning aaccelator lag. I have noticed the same on my cummins. Took into local cummins shop for oil and fuel filters change and asked service dept/mgr about this. They test drove and made a statement that if you have petal to the metal when you start off, that all the fuel dumped into injectors that the air/fuel mixture would probably be too rich and maybe some black smoke. Suggested to try half throttle and see if there is a difference. Also called Sports Chassis and talked with sales mgr and he said to push the mode button which is suppose to change the transmission shift points when starting out. He said to do this prior to even turning truck ignition on. Don't know. I do push the mode button so to start off in first but the truck is already running. Have to try when we head out Link to comment Share on other sites More sharing options...
Bobi and Dick McKee Posted May 7, 2016 Report Share Posted May 7, 2016 Old Man, even though we have the auto bleed system, we still have the manual system with the cable. On ours the cable is located between the cab and bed on the drivers side. Link to comment Share on other sites More sharing options...
Bobi and Dick McKee Posted May 7, 2016 Report Share Posted May 7, 2016 Randy, in what part of Idaho do you live. We will spend 2 weeks in August in one of our favorite Idaho towns, McCall. Dick Link to comment Share on other sites More sharing options...
Randy and Helen Posted May 7, 2016 Report Share Posted May 7, 2016 Old Man, even though we have the auto bleed system, we still have the manual system with the cable. On ours the cable is located between the cab and bed on the drivers side. Link to comment Share on other sites More sharing options...
Randy and Helen Posted May 7, 2016 Report Share Posted May 7, 2016 Thats where I installed mine for the forward tank. The rear tank I was able to run the cable up through a hole on the installed factory plate. Link to comment Share on other sites More sharing options...
hemsteadc Posted May 11, 2016 Author Report Share Posted May 11, 2016 Well, I'm not sure what to do now. I can't find a leak, but she's dropping to 50-60lb overnight which, according to a guy at Sportchassis, says that's within FL specs. Another guy at SC says that, because of the drop and hold at 60, check to the seats and cab airbags. Done that. I just hate the thought of having to leave her at a shop for days while they try to find it. Link to comment Share on other sites More sharing options...
Nigel Posted May 11, 2016 Report Share Posted May 11, 2016 Oldman You're worrying over nothing. On an air brake straight truck more than 3 psi per minute would put you out of service. I've seen brand new trucks from the factory that won't hold air overnight. I agree it would be nice if your truck would hold air for days on end but most don't. Nigel 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
Morelli Posted May 11, 2016 Report Share Posted May 11, 2016 A little feedback based on Nigel input ... I do not hold air overnight either. Everything is working right and when I park and leave the truck overnight, I am at 50 to 60 PSI on the tank. Everything deflates ... seats, cab, and axle. -Roberto Link to comment Share on other sites More sharing options...
Randy and Helen Posted May 11, 2016 Report Share Posted May 11, 2016 When I start my truck and let the air pressure build to 115-125 lbs. I then shut off and the air pressure will hold for 3-4 days. It stays at about 25-35 lbs. The rear tank seems to retain a lot more air pressure though and the rear air bags stay inflated. I can pull the manual air release back and have lots of air pressure. Not sure if these two tanks have a blocking valve/check valve installed between the two tanks hence the rear tank holds pressure for a lot longer time than the front tank Link to comment Share on other sites More sharing options...
hemsteadc Posted May 11, 2016 Author Report Share Posted May 11, 2016 Nothing deflates overnight with the pressure drop. The rear was falling, but I jimmied the rear water release valve and now that holds. Yeah, maybe I should just let this be. Link to comment Share on other sites More sharing options...
