lenp Posted December 5, 2015 Report Share Posted December 5, 2015 http://www.ktvz.com/news/money/what-is-5g/36799252 Interesting article Lenp USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
Max Signal Posted December 5, 2015 Report Share Posted December 5, 2015 http://www.ktvz.com/news/money/what-is-5g/36799252 Interesting article Lenp Carriers currently plan to implement 5G in 2021. 5G is truly not even defined yet. Keeping You ConnectedProud Commercial Member #129 http://www.maximumsignal.net/ Link to comment Share on other sites More sharing options...
KRum Posted December 5, 2015 Report Share Posted December 5, 2015 "The advantage of high-frequency signals is that they're capable of providing significantly faster data speeds. The disadvantage is that they travel much shorter distances and they can't easily penetrate walls. That means thousands -- perhaps even millions -- of mini cell towers, or "small cells" would need to be placed on top of every lamp post, every building, inside every home and potentially every room." Reading between the lines my guess is we will need to drill another hole in the roof of the RV... I've always been a tinkerer and a fixer... So what better way to stay active in my retirement than to buy an RV... Link to comment Share on other sites More sharing options...
Max Signal Posted December 5, 2015 Report Share Posted December 5, 2015 "The advantage of high-frequency signals is that they're capable of providing significantly faster data speeds. The disadvantage is that they travel much shorter distances and they can't easily penetrate walls. That means thousands -- perhaps even millions -- of mini cell towers, or "small cells" would need to be placed on top of every lamp post, every building, inside every home and potentially every room." Reading between the lines my guess is we will need to drill another hole in the roof of the RV... Doubt if you will even have the same RV by the time it is implemented . No telling at this point what frequency it will be assigned to. Keeping You ConnectedProud Commercial Member #129 http://www.maximumsignal.net/ Link to comment Share on other sites More sharing options...
