Velos Posted September 21, 2015 Report Share Posted September 21, 2015 We had a window seat installed last summer and unfortunately our kitchen floor was stained/marked with ??? in the process. I had tried floor cleaner, hand scrubbing and nothing worked. A friend that owns a campground unfortunately has permanent marker graffiti in the bathrooms occasionally and she used Mr Clean Magic Eraser. It sounded to good to be true; but nothing ventured nothing gained I picked up a trial size in the dollar store and it worked. I was amazed. You just dip in water then rub over the spot till clean. I am thinking of trying it on the outside of the RV? Has anyone else tried Mr Clean Magic Eraser? If so what did you use it on and were you happy with the results? Link to comment Share on other sites More sharing options...
nana25k Posted September 21, 2015 Report Share Posted September 21, 2015 I would not use it on the outside of the rig. Tried it in a small area of our last one the was painted aluminum. Not a good result. Marred the finish. Ron & LindaClass of 20072000 Monaco Diplomat 2005 Honda Element"Do what you can, with what you have, where you are" Theodore Roosevelt"We can't control the wind, but we can adjust our sail""When man gave up his freedom to roam the earth, he gave up his soul for a conditioned ego that is bound by time and the fear of losing its attachments." Link to comment Share on other sites More sharing options...
Velos Posted September 21, 2015 Author Report Share Posted September 21, 2015 I would not use it on the outside of the rig. Tried it in a small area of our last one the was painted aluminum. Not a good result. Marred the finish. Thank you. Link to comment Share on other sites More sharing options...
Yarome Posted September 22, 2015 Report Share Posted September 22, 2015 I am thinking of trying it on the outside of the RV? I most definitely would not. I 'do' use them and always keep some on board, but they work by abrasion. Basically very fine flexible micro sandpaper with the ability to 'wisk' dirt and such up into their micro-structure. If used on the outside of your rig it will also take away any top coat, and eventually the paint. Link to comment Share on other sites More sharing options...
roy67ss Posted September 22, 2015 Report Share Posted September 22, 2015 Maybe they would work at removing uv damage, if you polished afterward. Roy 2011 GMC 3500 SRW CC, SB, Duramax/Allison 2008 HitchHiker LS 29.5 FKTG, 7000lb axles, Glide Ride, HD brakes, dual pane windows, 40" Panasonic, Magnadyne HTS, PD surge protector, etc. Mods: 5 gal pressure tank, Motosat dish, plumbing reworked, inside steps storage, SeeLevel tank gauges, Rear view camera, major changes to basement. Link to comment Share on other sites More sharing options...
Yarome Posted September 22, 2015 Report Share Posted September 22, 2015 Maybe they would work at removing uv damage, if you polished afterward. I would stick with a good quality rubbing compound over a Mr. eraser. Too much overkill for the job. Link to comment Share on other sites More sharing options...
Mariner Posted September 22, 2015 Report Share Posted September 22, 2015 The one place the Mr. Clean Magic Eraser Mop is outstanding, is on the roof. I wouldn't use one of the small erasers though too much on your knees rubbing. I just wet down the roof, squirt some dish washing liquid around, and use the mop. Then rinse. My 15yr. old roof looks like new. Another thing I found that the small eraser works great on is cleaning the screens on the exhaust fans in the bathroom & kitchen. I turn the fans on, and then lightly rub the eraser across the screens and the gunk will stick to the eraser. With the fans on nothing falls on the floor. It's held up against the screen. A lot easier than unscrewing the screens and washing them. Fulltiming since 2010 2000 Dutch Star 2009 Saturn Vue Myrtle Beach, SC Link to comment Share on other sites More sharing options...
Velos Posted September 22, 2015 Author Report Share Posted September 22, 2015 Thank you for all the advice and suggestions....Much appreciated. Link to comment Share on other sites More sharing options...
homelesshartshorns Posted September 22, 2015 Report Share Posted September 22, 2015 Turtle Wax OXY Power Out Upholstery Cleaner. We got it at O Reilly's auto parts. Used it on carpet Still seeing Places we have never seen before and others that we thought we would never see again! . homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com) George Hartshorn | Facebook Link to comment Share on other sites More sharing options...
Coleen Posted September 23, 2015 Report Share Posted September 23, 2015 I've found the Magic Erasers good for removing stains on the lower part of a door; dog slobber that dried on, I think. They also work well to remove the water mineral build-up in our shower. I use them on the bottoms of baking pans and casseroles, too. Handy little buggers, once you get to using them! Coleen Sykora Escapees Life Member #19747 Workers On Wheels Link to comment Share on other sites More sharing options...
rocksbride Posted October 19, 2015 Report Share Posted October 19, 2015 Hi JM. Magic Eraser works great for all the baked on/grilled on stuff on the plate in your microwave. It will get as clean as you have the patience to work on it. Like Colleen, I use it in the shower from time to time. Sometimes the shower head hose rubs on the fiberglass shower walls and leaves marks when we travel. The Eraser erases them, too. Before we sold the stick and bricks, it made the rings around the burners on the stove top look brand new. It's an appropriately named product. Magic Eraser. Link to comment Share on other sites More sharing options...
sandsys Posted October 19, 2015 Report Share Posted October 19, 2015 Just remember that Magic Eraser is fine grain sand paper when you are deciding where to use it. I bought one but it had so many warnings on the package i decided I didn't want all those fine scratches in my things. Linda Sand Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
