Jimalberta Posted August 19, 2015 Report Share Posted August 19, 2015 Hi I am gonna ask on this site as well in case anyone has experienced this. Been driving all day and got to a Campground and I just noticed that my shift pad the the tranny is still lit up. I have no idea what to do...can anyone help? Jim <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
NoDirectionHome Posted August 19, 2015 Report Share Posted August 19, 2015 Do you know for sure that you are in neutral? If so, I'd do a battery disconnect to reboot everything. "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
Jimalberta Posted August 19, 2015 Author Report Share Posted August 19, 2015 I havent tried running the engine as it is dark and quiet here...dont want to wake up and piss off the neighbors. However I have never had this shift pad stay lit up before when the engine and ignition are off. I tried turning the ignition on and off a few times but that did not help. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Ronbo Posted August 19, 2015 Report Share Posted August 19, 2015 As Stekay says, disconnect the batteries for about 30 sec and reconnect. Make sure you remove all the negative cables large and small to ensure you cut power to the computers Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Jimalberta Posted August 20, 2015 Author Report Share Posted August 20, 2015 Update....woke up and the touchpad still lit up, engine started ok and the tranny functioned normally all day. Stopped for the night and the touchpad stayed lit up...for a while....it is now off. Wierd....oh well. Not gonna argue with a positive outcome. If it happens again ....someone suggested the chassis disconnect....its worth a try....cheers <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted August 20, 2015 Report Share Posted August 20, 2015 Do you still have anything plugged into your trailer light plug when this is happening? I ask this because when I pull my car dolly and leave it plugged in, I get 12v feed back from the small emergency braking battery on the dolly. It will back feed through the plug to the coach and cause my power step to not function properly. I unplug the dolly and all works fine. Link to comment Share on other sites More sharing options...
Jimalberta Posted August 21, 2015 Author Report Share Posted August 21, 2015 Hmmm.....by golly I believe I had my Jeep plugged in <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted August 21, 2015 Report Share Posted August 21, 2015 May not be the cause but worth a look. Link to comment Share on other sites More sharing options...
Broncohauler Posted August 23, 2015 Report Share Posted August 23, 2015 I had similar back feed problem into the truck. Not the shifter I have a manual transmission. Turned out I had a wire hooked up wrong on my Jackalopee. The trailer batteries were back feeding into the truck. Link to comment Share on other sites More sharing options...
