Guest THE TRAILERKING Posted August 5, 2015 Report Share Posted August 5, 2015 Seems like my 300-6058-02 inverter controller is fried. Gives out a "code 46" after 6-7 inches of rain(was not running at the time) but now will not start, dead at the control switches. Inverter searches show to be about $1,800.00 and up. Anyone have a line on these? Link to comment Share on other sites More sharing options...
Ranger Smith Posted August 5, 2015 Report Share Posted August 5, 2015 There was a thread either here or on the rv.net where someone sent one out to be repaired at a cost of about $250. When mine went I paid the 1700 for the new inverter. Steve and Joy Amateur Radio Operator WZ1T . . . Flex 6600 M, Flex PGXL, Flex TGXL, 2014 Itasca Suncruiser 38Q . . . Lincoln MKX Toad The Kids . . . Yogi the Yorkie passed 10/20/2018. . . Cookie the Chihuahua passed 11/30/2017 . . . Cooper the Aussie Doodle passed 3/10/2020 Abbie and Abel the Doodles . . . Brother and Sister Born 02/02/2020 . . . Lucy the Yorkie . . . and Axel . . .The Bernie Doodle Where We Are Now Link to comment Share on other sites More sharing options...
Kirk W Posted August 6, 2015 Report Share Posted August 6, 2015 This comes from the Onan operator's manual.... INVERTER POWER SUPPLY FAULT—CODE NO. 46 (Low battery voltage or power supply device failure) Corrective Action: 1. Avoid running the genset while cranking the vehicle engine in installations where the genset batteries are used to supplement the vehicle engine batteries. 2. Clean and tighten the positive (+) and negative (−) battery cable connections at the battery, vehicle frame and genset (Page 16). 3. Recharge or replace the battery. Refer to the battery manufacturer’s recommendations. 4. Install or service a battery charging system in the vehicle if the genset is not so equipped If you do not have a copy, you can download a copy of the owner's manual from this link. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted August 6, 2015 Report Share Posted August 6, 2015 INVERTER POWER SUPPLY FAULT—CODE NO. 46 (Low battery voltage or power supply device failure) Yes I am aware of this info. I am ruling out the "Low Battery Voltage" and considering the "Power Supply Device Failure". Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted August 7, 2015 Report Share Posted August 7, 2015 Any possibilities of used inverter/controllers around that anyone has heard of?? Link to comment Share on other sites More sharing options...
Ray,IN Posted August 9, 2015 Report Share Posted August 9, 2015 You may find a used one from a store on this list. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
OU812 Posted August 9, 2015 Report Share Posted August 9, 2015 I put a controlor on my Onan 8000 diesel.... at 1400 hr.... $1600 from Onan. for my model. It would run but no out put power. Easy to replace.. once I got the generator on the bench....2 hours. Once I got to it you could see the HOT spot.. Tried to get fixed.... several places.. .. ended up new. better in the long run. Good luck OU812 Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted September 20, 2015 Report Share Posted September 20, 2015 Well I ordered one from one of my suppliers for about $2,500.00. Be about two weeks from the manufacturer warehouse. Our local Cummins Onan up here wanted about $3,200.00 Once get it I can put the generator back into "running mode". Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted September 29, 2015 Report Share Posted September 29, 2015 Well for those interested..................Just fired up the Genny with the newly installed "NEW" Inverter Controller. Works just like brand new again. .......For a generator that had less than 600hrs on it. Now when re-install the Genny into the coach I will be doing a modification to deflect any rain water off the top of the Generator. A bad design from Fleetwood. All the rain comes off the roof. down the windshield, behind the cowl/hood,.........directly on the generator. This is something anyone should do that has a similar unit like the American Dream and the Eagle. Link to comment Share on other sites More sharing options...
