LHS61 Posted June 25, 2015 Report Share Posted June 25, 2015 Re: 03 Newmar Mountain Air I'm stuck with my slides out dry camping.... put 'em out using the generator last night. Now the generator won't start The one RV service place recommended on the internet no longer does repairs, only parts. The Onan dealer can't help me until Monday. I told him the symptoms (coach DC voltage way low after using generator). He said it sounds like a charge control issue. The batteries have a "Global Technologies - ICP" charge controller on them with both the 'charge' and 'full' lights out. ANY ADVICE GREATLY APPRECIATED -- ESPECIALLY SOMEONE I COULD GET TO COME TO THE COUNTY FAIRGROUNDS PARK AND HELP ME WITH THIS -- THERE IS NO SHORE POWER IN THE PARK FOR NOW DAVE CEL 360-275-1853 Link to comment Share on other sites More sharing options...
2gypsies Posted June 25, 2015 Report Share Posted June 25, 2015 I don't know who you called but you might try this one: Flagstaff Service Center 928-526-6771. If they can't help, perhaps they can give you a name of a mobile mechanic. We had a tool where you could put in the slides manually, in an emergency. Do you have one? This sounds like a battery problem. Good luck! You're close to Munds RV park. Perhaps they could help with a mobile mechanic. Full-timed for 16 YearsTraveled 8 yr in a 2004 Newmar Dutch Star 40' Motorhome and 8 yr in a 33' Travel Supreme 5th Wheel Link to comment Share on other sites More sharing options...
Dutch_12078 Posted June 25, 2015 Report Share Posted June 25, 2015 Will the coach start? The coach alternator should also charge the house batteries. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
luvlabs Posted June 25, 2015 Report Share Posted June 25, 2015 Since you left no information about what type of equipment you have (Class A, Class C, 5th wheel) this is going to be an answer based on some general things found in a Class A which is what I own. Sounds like your house batteries are the problem. To put your slides in, try doing it with the engine running. Your slides can be powered by either the chassis batteries or the house batteries. Your generator is normally started off your house batteries. Since they are now too low as far as charge is concerned, you cannot start your generator. One work around is to start your engine and then hold the emergency start switch open (this connects your house and chassis batteries together) and let the engine start charging the house batteries. Give it 30 minutes are so and try and start the generator. IF the generator starts, then shut off your engine and let the generator run to charge your house batteries. Give it 6-8 hours of running to get them to a state of charge that is sufficient. If you have a Class A, you should have sufficient instrumentation to give you your battery voltages. But as an RVer, you should own and know how to use an electrical multi-meter to check voltages. Things that can and do go wrong: Converter/Inverter is not set properly or not working; charge relay (connects the two battery banks) is not working; batteries are just old and need to be replaced; battery electrolyte levels are too low (add water); high current fuses in house battery circuit are blown; and so on. Good luck and most mobile repair people should be able to troubleshoot these problems. Roger & Mary2014 Phaeton 36GH2012 Honda FitZoe (lab mix) and the cats (Sam & Milly) Link to comment Share on other sites More sharing options...
Bill Joyce Posted June 25, 2015 Report Share Posted June 25, 2015 Also make sure you have more than 1/4 tank of fuel, siince the generator fuel intake is normally at that level to always allow you to start the engine. 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
LHS61 Posted June 26, 2015 Author Report Share Posted June 26, 2015 Thanks Dick in Oregon for calling me about this...you gave me a bit of a primer on MH dc systems in a few minutes. Thanks tons. Turns out the batteries had to be replaced (2 years old). I'm on my "shake down" tour with this couch just started out 7 days ago from Phoenix. Trying to make those long 6-7% grades to reach the 7000 ft elevation of Flagstaff was a major struggle for my 8.1 chevy. Alls well now for the time being. This elevation is something else... but thanks to everyone for all the advice. Crisis solved for $300 worth of batteries. This is what Escapees is all about... amazing folks willing to help however they can. Thanks again dave Link to comment Share on other sites More sharing options...
Kirk W Posted June 26, 2015 Report Share Posted June 26, 2015 Have you been keeping the electrolyte levels in the batteries at proper level? Low electrolyte might explain their failure in only two years. You probably also have an "emergency start" switch or something similar that will cross connect the chassis battery with the coach battery in order to allow you to use the chassis battery to start the genset or the coach battery to start the chassis engine. In this case, you need to start the chassis engine and allow it to run for a minute or so, then hold down that switch for a minute or two, then while holding it down start the genset. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
jayco1 Posted June 26, 2015 Report Share Posted June 26, 2015 Also make sure you have more than 1/4 tank of fuel, siince the generator fuel intake is normally at that level to always allow you to start the engine. While probably not related to this person's problem, this is something that has bitten many RVers. Link to comment Share on other sites More sharing options...
kathydavidb Posted June 26, 2015 Report Share Posted June 26, 2015 Also Dave, don't let the beginning problems discourage you. We've all been there and later in your RV travels you'll look back & laugh. I can remember having to run my RV to charge my batteries so I could bring in my slides. The converter/charger had gone out. Best of luck to you. 2006 Coachmen Aurora 36ft. Class A motor home. 2009 Honda CRV toad. "Snowbirds" apprx. 6 mos. each year. Travelling to the SW each winter than returning to Wi. each summer. Retired and enjoying our travels along with Buddy the cat. Link to comment Share on other sites More sharing options...
LHS61 Posted June 29, 2015 Author Report Share Posted June 29, 2015 Case closed....thanks tons to all who responded. New batteries did the trick. BUT I have a question about batteries: Is it advisable to use bottled drinking water for the batteries (like from Walmart) ? Link to comment Share on other sites More sharing options...
Rif Posted June 29, 2015 Report Share Posted June 29, 2015 Case closed....thanks tons to all who responded. New batteries did the trick. BUT I have a question about batteries: Is it advisable to use bottled drinking water for the batteries (like from Walmart) ? No. Use distilled water only. It too can be purchased at Wal-Mart or most any market. 2000 Volvo 770, 500HP/1650FP Cummins N14 and 10 Speed Autoshift 3.58 Rear 202" WB, 2002 Teton Aspen Royal 43 Foot, Burgman 650 Scooter Link to comment Share on other sites More sharing options...
kathydavidb Posted June 29, 2015 Report Share Posted June 29, 2015 No. Use distilled water only. It too can be purchased at Wal-Mart or most any market. X2. I get my distilled water at WalMart for my batteries. I usually by a gallon for around $1. and split it up into smaller bottles for easier pouring. 2006 Coachmen Aurora 36ft. Class A motor home. 2009 Honda CRV toad. "Snowbirds" apprx. 6 mos. each year. Travelling to the SW each winter than returning to Wi. each summer. Retired and enjoying our travels along with Buddy the cat. Link to comment Share on other sites More sharing options...
Kirk W Posted June 29, 2015 Report Share Posted June 29, 2015 Case closed....thanks tons to all who responded. New batteries did the trick. BUT I have a question about batteries: Is it advisable to use bottled drinking water for the batteries (like from Walmart) ? If you do not use distilled water it will shorten the life of the batteries. Demineralized water is not the same as it has had the calcium and iron removed but does have salt in it, just as softened water does. Distilled is the only kind of water that will not have a negative impact upon your batteries. I use a long, tapered funnel to put the water in and just pour from a gallon jug, also usually from Walmart. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Chris-n-Dennis Posted June 30, 2015 Report Share Posted June 30, 2015 Distilled only. I'm curious though, 2 year old batteries shouldn't fail that horribly. I recommend beginning a regular inspection/maintenance routine on your new batteries and either use the above recommended methods for fill or snag and install a Flow Rite system. Berkshire XL 40QL Camphosting and touring Our blog: cndtravels.blogspot.com Link to comment Share on other sites More sharing options...
mohamer Posted June 30, 2015 Report Share Posted June 30, 2015 Kirk, I use a squeeze bottle, works great. Southwind 35P ARS KB0OU EX Submarine driver Link to comment Share on other sites More sharing options...
mickhoss Posted July 3, 2015 Report Share Posted July 3, 2015 out here where I live all we ever use in batteries is tank water collected from the house roof, I have had up to 6 years service out of start batteries doing this. 2years seems a bit short of a life span but it depends a bit on how the have been used, charged, left standing ect, you always seem to get some that cark it earlier than others. mick Link to comment Share on other sites More sharing options...
StarDreamers.us Posted July 3, 2015 Report Share Posted July 3, 2015 I use a kitchen baster for adding water to batteries. Works great and I do not have to worry about flooding the area. Lots of good ideas - thanks for sharing. Safe Travels! SKP #89742 - Lifetime membership - Member of the SKP Class of 2007Good Sam Club - Lifetime MemberDataStorm #5423Passport America - Lifetime MemberSons Of The American Revolution (SAR) - Lifetime MemberAmerican Legion - USAF - Lifetime MemberRotary Club Member - 30 years Escapee CARE Supporter National Wildlife Refuge Volunteer Link to comment Share on other sites More sharing options...
Rif Posted July 4, 2015 Report Share Posted July 4, 2015 I've tried turkey basters, funnels, and battery fill devices. All work but I was never happy with any of them. Finally I bought an outboard fuel priming bulb and attached about a 10 inch clear plastic hose to the discharge side, and a three foot hose to the suction side. It's the best system ever. I can sit the gallon jug of distilled water on the ground or wherever and just pump the exact amount of water I need by squeezing the bulb. No issue with overfilling and no spills. 2000 Volvo 770, 500HP/1650FP Cummins N14 and 10 Speed Autoshift 3.58 Rear 202" WB, 2002 Teton Aspen Royal 43 Foot, Burgman 650 Scooter Link to comment Share on other sites More sharing options...
Biker56 Posted July 4, 2015 Report Share Posted July 4, 2015 Pro Fill watering system has worked for me. Easy to do. Full Time since Oct. 199999 Discovery 34Q DP | ISBDatastorm | VMSpc | Co-Pilot Live | Pressure Pro2014 MKS Twin Turbo V6 365 HP Toad Link to comment Share on other sites More sharing options...
JC and Angie Posted July 4, 2015 Report Share Posted July 4, 2015 X 2 on pro fill. Works great. 1st of every month I jus top of all my batteries in about 5 minutes. 2009 Volvo 780. D-16 500hp 1850 torque with a Herrin hauler bed. 2015 Continental Coach 2008 650cc Suzuki Bergman 2013 Mustang GT 500 convertible 2014 Smartcar convertible WWW.Hollyfab.com. (Metal Fabrication Company) Jamesc@hollyfab.com (preferred contact method) Link to comment Share on other sites More sharing options...
mscans Posted July 6, 2015 Report Share Posted July 6, 2015 look carefully at the converter charging system. some of the older ones do a poor job of charging but are great at cooking the water out of the batteries. you need a 3 or 4 stage charging system. of course keep the fluid level up as mentioned above. Happy Trails, Florida Mike EXPERTS AREN'T!! Link to comment Share on other sites More sharing options...
