Five Wood Posted May 1, 2015 Report Share Posted May 1, 2015 What bandwidth meter do you recommend for a PC using Windows 8? Thanks JimSKP: 99693If you think you can, or you think you can't. . . you are probably right (Henry Ford)2014 Dodge 4WD Dually1998 Carriage LS-341 Link to comment Share on other sites More sharing options...
Bill Joyce Posted May 1, 2015 Report Share Posted May 1, 2015 I used Networx, https://www.softperfect.com/products/networx/, before I owned a Pepwave Surf SOHO router that tracked bandwidth. 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
Five Wood Posted May 1, 2015 Author Report Share Posted May 1, 2015 I used Networx, https://www.softperfect.com/products/networx/, before I owned a Pepwave Surf SOHO router that tracked bandwidth. Thanks Bill. That looks like just what I need. Jim JimSKP: 99693If you think you can, or you think you can't. . . you are probably right (Henry Ford)2014 Dodge 4WD Dually1998 Carriage LS-341 Link to comment Share on other sites More sharing options...
chirakawa Posted May 1, 2015 Report Share Posted May 1, 2015 I use Networx also. Bear in mind, it measures all network activity, not just internet. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Dutch_12078 Posted May 2, 2015 Report Share Posted May 2, 2015 I use Networx also. Bear in mind, it measures all network activity, not just internet. But Networx can be set to ignore LAN traffic... Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
chirakawa Posted May 2, 2015 Report Share Posted May 2, 2015 But Networx can be set to ignore LAN traffic... I'd appreciate a "how to" on that please. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Dutch_12078 Posted May 2, 2015 Report Share Posted May 2, 2015 I'd appreciate a "how to" on that please. Right click on the systray icon and select "settings". In the "Main" window, check the "Ignore local traffic within the LAN" box at the bottom, and click on the "Setup" button to make sure the IP range for your LAN is listed. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
chirakawa Posted May 2, 2015 Report Share Posted May 2, 2015 Right click on the systray icon and select "settings". In the "Main" window, check the "Ignore local traffic within the LAN" box at the bottom, and click on the "Setup" button to make sure the IP range for your LAN is listed. Thanks. I bet I've looked at that screen 20 times and never have seen that option. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Five Wood Posted May 2, 2015 Author Report Share Posted May 2, 2015 I tried to download Networx and got a warning from Norton security that it was unsafe. I assume you guy's that are using it have not had security issues with it?? JimSKP: 99693If you think you can, or you think you can't. . . you are probably right (Henry Ford)2014 Dodge 4WD Dually1998 Carriage LS-341 Link to comment Share on other sites More sharing options...
Bill Joyce Posted May 2, 2015 Report Share Posted May 2, 2015 5Wood: Some of the download sites bring extras with them. Try http://www.majorgeeks.com/files/details/networx.html, they seem to keep things clean. 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
Chris-n-Dennis Posted May 2, 2015 Report Share Posted May 2, 2015 I tried to download Networx and got a warning from Norton security that it was unsafe. I assume you guy's that are using it have not had security issues with it?? The Norton warning is based on program history and since this program was updated on April 19th, there simply is not enough users/history to it for Norton to have the data to qualify it as "safe". Get the program from the source: https://www.softperfect.com/products/networx/ Berkshire XL 40QL Camphosting and touring Our blog: cndtravels.blogspot.com Link to comment Share on other sites More sharing options...
Five Wood Posted May 2, 2015 Author Report Share Posted May 2, 2015 5Wood: Some of the download sites bring extras with them. Try http://www.majorgeeks.com/files/details/networx.html, they seem to keep things clean. Bill, That worked. . . thanks Jim JimSKP: 99693If you think you can, or you think you can't. . . you are probably right (Henry Ford)2014 Dodge 4WD Dually1998 Carriage LS-341 Link to comment Share on other sites More sharing options...
