Toad Charge and Amp-L-Start
SWharton
None of those but I have and use one of the Battery Minder products. With our motorhome I permanently connected one like this to the chassis battery such that anytime that we were connected to shore power it was operating. I attribute the use of it to having been the reason that battery was still capable of passing a load test after 8 years of service. I also use one of their 48V versions on our golfcart when we are traveling.
Brake Buddy makes a $25 battery maintainer that will work with any braking system - http://www.brakebuddy.com/Products/Accessories/Towed-Vehicle-Battery-Maintainer.
Installed a Toad Charge in July 2013. It worked great for about a year before I started having problems with dead toad battery again. I have tinkered with it a lot since then, and talked to them about it to get their suggestions. It has worked a few times in the past year, but most of the time it shows that it is connected, but it does not keep the toad battery charged. I am ready to toss it at this point. I am now traveling with a battery charger under the hood, plugged into the motorhome via extension cord so I can run the generator and not have a dead toad on arrival.
'05 Honda Odyssey
Escapees, FMCA, WIT, SMART
http://www.pjrider.com
Don't you guys have a live wire in your umbilical to keep the toad battery up while its being towed? My MH has a dedicated circuit that is powered up as soon as I start the MH engine for just that.....its on a 30 amp fuse and works great. As it runs through a relay I dont have to worry about the Toad draining the MH batteries when not driving. My toads never have a drained battery from towing.
I ran the Trikle-L-Start for over a year and it did it's job. When I discovered the bigger Amp-L-Start I replaced the smaller unit which was working fine. The reason I did that was that the defective OEM unit was a 15 amp and I just thought that having the same rating would be extra insurance. I have since had a converter/charger problem that was flipping between charge to equalize at 16.4 volts. This went on for some 12 to 24 hours before I discovered it. The Amp-L-Start survived and I can only say I am very happy with their products.
Good luck, good health and safe travels!
