bigredhdt Posted April 3, 2015 Report Share Posted April 3, 2015 I'm pretty sure I found my leak, but need some advice. On my 630 underneath the cabin on the driver side, there is a plastic tube that many air lines go through. My choices seem to be cut the tube open or undo all the lines and pull them out of the tube. Link to comment Share on other sites More sharing options...
dascom Posted April 3, 2015 Report Share Posted April 3, 2015 Mess with it as little as possible. Split the carrier tube if is is not already split, much/most is. Do not try to do more than you need to, to fix the leak. Plastic can get real brittle in time, let sleeping dogs be. One good thing is that working with plastic tube is easy if you can get to it. Yamaha V-Star2007 Kenworth T2000 tandem aircutterThermoKing TriPack2003 Holiday Rambler 36' Presidentialshort trips-88 Allegro on Astro Link to comment Share on other sites More sharing options...
bigredhdt Posted April 3, 2015 Author Report Share Posted April 3, 2015 I don't know why Volvo chose to put in the unsplit plastic tube rather than split loom. Real hard to work with it opposed to split loom. Link to comment Share on other sites More sharing options...
