victorino545 Posted April 1, 2015 Report Share Posted April 1, 2015 Have a Discovery Class A and having problem with generator not starting unless the engine is on. Can anyone give me some suggestions and what to look for. Newbie to this so any help appreciated. Link to comment Share on other sites More sharing options...
scouserl41 Posted April 1, 2015 Report Share Posted April 1, 2015 A little more information would help. I'm guessing you are cranking and cranking it with the engine running to get it started, but have you primed it before you start? There is usually a button alongside the generator start button which you hold down for around 30 seconds which primes the carburetor on the generator before starting. Are you using that button? The generator isn't used very much so the fuel can evaporate over time and leave the carburetor dry. It takes time to get fuel to the carb. As it obviously starts when the engine runs I'm guessing that might be the problem. If the chassis battery is strong enough to start the engine then I would think it's not a voltage problem. Once it starts for the first time does it start easily after that? If so then it is a lack of priming IMHO. That's one of the reasons for starting the generator once a month and letting it run against a load (Usually and AC running) for an hour or two. Hope this helps. BnB 2009 Monaco Cayman DP 38' bnbrv.blogspot.com/ Link to comment Share on other sites More sharing options...
Jim & Alice Posted April 1, 2015 Report Share Posted April 1, 2015 Any problem with running the generator monthly... and staying hooked up to shore power? Never tried it, always took precaution of shutting off power at the pedestal. HB 2007 Dolphin Safe-T-Plus Steering Bar Our Blog: Click Here Link to comment Share on other sites More sharing options...
socaltoolguy Posted April 1, 2015 Report Share Posted April 1, 2015 I'm sure you already know this but if not, make sure you have more than a 1/4 tank of gas. If it gets below that it won't start and continue running. Ray 2001 Fleetwood Southwind 32V 2011 Scion XB toad Link to comment Share on other sites More sharing options...
don&penny Posted April 1, 2015 Report Share Posted April 1, 2015 I'm not sure what having the engine running has to do with it not starting but - I had some friends with a problem where they could not start their generator in their Class A. It turned out to be the battery disconnect switch having been placed in the "disconnect" position. The switch did not have any visible indicators to show which position it was in. Don Link to comment Share on other sites More sharing options...
Kirk W Posted April 1, 2015 Report Share Posted April 1, 2015 Since your generator starter draws power from the coach batteries and the chassis starter from the chassis battery, running the chassis engine gives you additional power because once the engine comes up to speed there is a relay that closes to supply any excess power available from your chassis alternator to the coach battery, or in this case to the starter for your generator. I'd suspect that you have a problem either with the coach batteries or the charging of them. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
horizon36 Posted April 2, 2015 Report Share Posted April 2, 2015 To prime a diesel generator press and hold the stop switch for 30 seconds. Also, if you press and hold the stop switch for about 10 seconds you will get a blinking error code from the switch which you can look up in your manual. Full time since August 2010 2002 Itasca Horizon One fur kid - a Shih-Tsu rescue Jeep Grand Cherokee Ltd Link to comment Share on other sites More sharing options...
Smitty77_7 Posted April 2, 2015 Report Share Posted April 2, 2015 Have you tried starting the generator with only the boost battery switch helping out? If it starts that way, as well as when the engine is running, then I'd take a good look at the battery and the feeds to the generator. May just need some wire/ground connections cleaning, that the extra juice of the engine running compensates for... Best of luck to you! Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
NJ-Ron Posted April 2, 2015 Report Share Posted April 2, 2015 When ever I had trouble starting my gas operated generator (not turning over) it was usually the coach battery (deep cycle) that didn't have enough juice to start the genny. As Kirk stated starting the engine supply's the power to start the generator. Sometimes my deep cycle battery would not get charged because a 175 amp for that circuit had blown. Since I learned that was the issue I always carried 2 spare 175 amp fuses, one for the house battery and another for the chassis battery. Ron Ron 2008 Newmar Kountry Star 36232008 Honda CRVCurrently Snowbirds - Ft. Myers Beach - Florida Keys Link to comment Share on other sites More sharing options...
Keelandb Posted April 8, 2015 Report Share Posted April 8, 2015 I have to agree with Kirk. In our Class C if the coach battery is at all low the generator will not start. In that case we start the engine and then start the generator. BobK Link to comment Share on other sites More sharing options...
oldjohnt Posted April 9, 2015 Report Share Posted April 9, 2015 I'm with Kirk on this also. On many RV's I've owned the genset starts via the house batteries. However, if they are discharged and cant crank the genset over, once the engine starts and the alternator and engine battery are then in parallel with the house batteries, theres enough power to crank the genset over. If the genset starts fine if your connected to shore power I think the same, because then (or at least after some time elapses) the RV's Converter/Charger has had time to bring the house batteries up sufficient to crank the genny over. I think tis time to have your house batteries checked for state of charge and specific gravity and load tested as it doesn't take that much capacity to crank the genset NOTE the above assumes your house batteries is what cranks the genset and your engines alternator and engine battery is connected in parallel with your house batteries once the engine is up and running and any time delay has passed. If that's NOT your configuration I will have to change my thinking. John T Link to comment Share on other sites More sharing options...
