Big5er Posted March 31, 2015 Report Share Posted March 31, 2015 I was just given a 50 amp twistlock cord. Like this one So, now I have a pair of identical cables. My 5er uses a twistlock connector just like each of the two cables I now own. Here is my question. Keep in mind that I do NOT want to alter either cord. Has anyone ever seen an adapter that would allow me to plug the cables together, ie use one like an extension cord. Sure, I know I could remove the twistlock and put on a female end but I do not want to. In case one cable goes bad, a fellow traveler forgets his etc, I want top leave the twistlock alone. Something like this 30amp one?? If no one has seen an adapter, can I just make one? Twistlock female on one end and a 50 amp receptical in on the other? Any reason I wouildn't want to do that? MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
shorts Posted March 31, 2015 Report Share Posted March 31, 2015 probably be pretty easy to build your own adapter, mount it on a board or better yet build it inside a plastic toolbox so the connections are weather resistant when you are using both cords for 100' length Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted March 31, 2015 Report Share Posted March 31, 2015 Marinco should build an adapter. Check the Marinco end of the cord- the yellow part, and see if it dissembles- 3-4 small screws. It might, then you could add a female cord end. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
trailertraveler Posted April 1, 2015 Report Share Posted April 1, 2015 I've switched to using a short 90 degree connector like this and then as many extention cords as needed. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted April 1, 2015 Report Share Posted April 1, 2015 One of these, in conjunction with a box, and a receptacle will connect the 2 cords. This one might have enough room to add the Marinco connector to the bottom. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
docj Posted April 1, 2015 Report Share Posted April 1, 2015 I assume you understand that when you connect two cords in series you have to derate them relative to the current they can safely handle. The power loss in an electric conductor is equal to I (current) squared times R (resistance). By doubling the cord length you have doubled the resistance; the voltage drop is doubled and the maximum safe current is reduced. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
dascom Posted April 1, 2015 Report Share Posted April 1, 2015 The expense of the connectors would make it a government project. Just put a 50A socket on one of the cords, under $25. That is what I carry, a long twist lock and additional 50A extension cord. Needed both many times. Yamaha V-Star2007 Kenworth T2000 tandem aircutterThermoKing TriPack2003 Holiday Rambler 36' Presidentialshort trips-88 Allegro on Astro Link to comment Share on other sites More sharing options...
sclord2002 Posted April 1, 2015 Report Share Posted April 1, 2015 BigFiver, you would need a MALE 50 amp twist-lock on one end and a 50 amp range recepticle on the other end. I don't know if anyone makes that adaptor but there is no reason you can't make your own. If you have 100 feet of cable you would need to watch your voltage drop if pulling anywhere near 50 amps. Most 50 amp RV cords are about 30 feet long and are 6/3,8/1 cables and are like wrestling a giant anaconda when very cold. I make up replacement cords using 6/4 SOOW cable and they are sooo much more flexible....a real joy to coil and handle....but that wasn't your question. If you make an adaptor, just be sure the wiring is correct. If you are coming to the ECR we could make up an adaptor there. The power inlet that Darryl linked to would be a good way to go for the twist-lock end. Charlie Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
NeverEasy Posted April 1, 2015 Report Share Posted April 1, 2015 I did not want to carry more or longer cables so I installed another MARINCO connector on the front of the 5er and ran it to a transfer switch rated for 70 amps. Makes it easier to run out of the generator on the truck, too. Chet Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
HERO Maker Posted April 1, 2015 Report Share Posted April 1, 2015 Guys, I don't think he is going to have 100 ft. of power cord. Didn't see that posted. He is either going to have two 20's or maybe two 25's. Phil, I like your idea of wanting to help a bud in need, and understand you wanting be able to use it as an extension when needed. I agree with some and just build your own connector and you have the most flexibility. I have found that several RV shops are willing to build what I want with quality parts. Good luck bro. Nice snag by the way. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Big5er Posted April 1, 2015 Author Report Share Posted April 1, 2015 LOL, Thanks Rocky. I was just in the right place at the right time and I haven't measured it but yeah, its either 20 or 25 ft. I think Charlie and Darryl are right on the money. I like that Home Depot box. With the cost of the plugs I should get away for around $50. That is a LOT cheaper than a 50 amp extension cord and this way I have an ambidextrous, multilingual, and dual purpose cord. I will never forget my 2nd HDT rally where I got all set up in the overflow area for the pre-rally and was 2 feet short of reaching the plug. Roger (of Roger&Debbie) said "don't you have an extension cord?" and then loaned me his for 2 days until we got into the campground area. With a homemade adapter box, I have an extension cord to loan, a twistlock cord to loan or an extension cord for my next "2 feet short" situation. Thanks for all the ideas guys. My local Home Depot doesn't have the box in stock, it'll take a week to deliver, but what the heck, I'm already hooked up and not planning to leave anytime soon, so I have a week to wait MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Livingillusions Posted April 1, 2015 Report Share Posted April 1, 2015 If I did my math right, voltage drop running 50 amps at roughly 140' of 6/3 wire would only be 2%. Stringing two 25' together is not even worth calculating it. For the record I carry 167' of 6/4. Kevin Ridgeway Kristen Johnson Indiana & Arizona Dodge 3500, HDT very soon Living Illusions http://www.livingillusions.com Lady Houdini http://www.ladyhoudini.com Link to comment Share on other sites More sharing options...
rdickinson Posted April 1, 2015 Report Share Posted April 1, 2015 Are you able to get one of the grey plastic outdoor boxes with the snap cover and an 'O' ring in the intake end of the box? Rather like a compression fitting. Electrical wholesalers carry them. Link to comment Share on other sites More sharing options...
Chad Heiser Posted April 1, 2015 Report Share Posted April 1, 2015 Phil, I would go buy one male and one female 50 amp cord ends. I would then cut the new (to you) cord about two or three feet from the twist lock end. Put the new male 50 amp plug on the new short cord and the female 50 amp plug on the longer piece. This gives you a long extension cord for use with your existing cord and a twist lock cord you can loan out (if needed) to be used with the (new) extension cord. This does away with all the extra boxes and funky connections and should be fairly cheap. It is what I did with an extra cord I had. I often use the short twist lock pigtail to plug my portable generator into my trailer without a bunch of extra cord laying on the ground. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Jack Mayer Posted April 1, 2015 Report Share Posted April 1, 2015 Having a short cord like Chad describes is helpful. As he said, it can serve dual purposes. I've used mine a number of times - but honestly, it is not something that is used every day. HOWEVER, when stuck in my brother-in-laws drive recently (with 30 amp service "nearby") I did use 55' of 50 amp cord, a 50' length of 10 ga contractor extension cord, and then TWO 30 amp extensions of 25' each. That got me 30 amps at the rig with no real voltage drop. So sometimes the stuff comes in handy. My biggest issue seems to be that these cords that are not used much are in the drom box, and the car always seems to be on the truck when I need them - conveniently blocking the drom Danielle says I should stop carrying so much "junk". Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted April 1, 2015 Report Share Posted April 1, 2015 Phil I like Chads idea but I believe they make an adaptor that will do what you want but it is about $80. Bill B has a 90 degree that screws into his rig and then the regular cord screws to that. This just makes the cord hang straight down instead of sticking straight out from the rig and drooping down putting pressure on the plug. Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
peety3 Posted April 1, 2015 Report Share Posted April 1, 2015 I have to ask: why do you want to keep two cords unaltered? That said, I think your adapter could be as simple as the proper opposites of the connectors you want to mate, and either a 1' section of cord (knowing that you'll trim it back to 6" by the time it's built) or a longer section of cord (if you have two 20' cords and they're both of sufficient gauge for a 50' total run @50A, why not use 11' of cord knowing it'll end up closer to 10' once you're done). Have someone else verify for safety, but the green wire goes to the green screw terminal, white wire goes to the silver screw, and the remaining two colors (probably black and red) go to the two remaining screws. Ideally, you'd make sure you don't cross the red/black wires (Ghostbusters: "Don't cross the streams!"), but as long as you only have one cable going to your trailer, it doesn't matter. Link to comment Share on other sites More sharing options...
CDR Posted April 1, 2015 Report Share Posted April 1, 2015 Big5ver; Marinco makes an adapter. By modifying the cord you will have lost the molded weather proofing, that's why it is best to not disturb the covering unless you truly know what your doing. Corrosion is the "1" factor in the degredation of an electrical system. Just sayin. Curt 2001 Freightliner Century, 500hp Series 60, Gen 2 autoshift, 3.42 singled rear locker. 2004 Keystone Sprinter 299RLS (TT) 2 & 4 Wheelers! 2013 Polaris Ranger 800 midsize LE Our motto "4 wheels move the body, 2 wheels move the soul!" Link to comment Share on other sites More sharing options...
Big5er Posted April 1, 2015 Author Report Share Posted April 1, 2015 By modifying the cord you will have lost the molded weather proofing, that's why it is best to not disturb the covering unless you truly know what your doing. Corrosion is the "1" factor in the degredation of an electrical system. Curt's answer pretty well covered why I wanted to leave the cords unaltered...NOW, having said that, and pricing the different connections, I can do like Chad, Jack and Brad all said for less that $20...so I bought the connectors. I will check with my guys next door at the RV repair facility for the best way to seal the connections to avoid as much corrosion as possible. Jack, luckily for me, DRV has a small dedicated compartment for the electric inlet that is just big enough to hold both cables so the smart will never be blocking the cable access....now that doesn't mean that I can get to my drom any better than you, it just means that ONE thing won't be there. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
shorts Posted April 1, 2015 Report Share Posted April 1, 2015 Use the grease like compound for the actual wire to terminal connections in the plugs, available @ the big box store. you can use bath tub caulk to seal the plug housings to the cable and at the seam where they bolt together. I would still consider a plastic tool box or similar to put the adapter and extension cord end p[ug connections in to protect them from weather and dirt when in use instead of just plugging everything together and leaving it in the open. Link to comment Share on other sites More sharing options...
