EagleEye Posted March 28, 2015 Report Share Posted March 28, 2015 I have a 2005 M2-106. The air conditioner just quit working (no cold air) The blower works, the heat works, but no cold air. the cluch on the compresser doesn't kick in. I thought it might be a fuse but I can't find one for the air. does anyone know if there is one and if so where it is? I'm currently in Florida and air is needed. Dave and Marge 2010 Phaeton Motor Home Previous Mobile Suites 36 RSSB3 (for sale) and 2005 FL M2-106 Sport (for sale after 5er sells) Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted March 29, 2015 Report Share Posted March 29, 2015 Several things can cause it to quit including low refrigerant level, bad clutch, control switch and others, On my 2012, the fuses are virtual but you should be able to look at the fuse box cover to see which one is for the AC unit 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
stolpsaddles Posted March 30, 2015 Report Share Posted March 30, 2015 If you have a volt meter test and see if you get power to the plug connection on the compressor with the engine running and AC on. If no power there find the low pressure switch and try there.Could also use a test light on the plugs as well as the fuses to find if it is electrical or low refrigerant . 2005 Western Star, MDE 4000 ,singled mid, 12' deck with Smart CarBison Stratus 3 horse with 16' short wall 12' slide out http://www.spottedhorsegallery.com/http://www.campingandhorses.com/ Link to comment Share on other sites More sharing options...
