Another T2000 question
chevy3500
How do you remove the inner door panel? I removed all the torx head screws from the perimeter but something still holding tight up on top edge. Exterior door handle is not working on passenger side, and it sounds like a rod flopping around inside, thinking it must have came unhooked from mechanism. Any thoughts?
Thanks again
Does the top piece (the one with the door lock and mirror control) have to come off too. Its just been to cold around here to mess with it much (negative 20) this am but weekend is supposed to be warmer, but would like to get it fixed asap.
Thanks
The trim strip between the upper and lower door trim panels (On VIT interior trucks -- those with woodgrain trim on the instrument panel -- it's a strip of matching woodgrain. On lower level trim models I would assume that it's black, which would, likewise, match the IP trim.) pulls off. It's held on with hook and loop (Velcro-like) fasteners. There are screws behind it.
Phil
2002 Teton Royal Aspen
2003 Kenworth T2000 - Cat C12 380/430 1450/1650, FreedomLine, 3.36 - TOTO . . . he's not in Kansas anymore.
ET Air Hitch
Been awhile, but, on top of the screws Phil mentioned, is a collection of plastic "pine trees" holding the panel on.
2007 32.5' Fleetwood Quantum
Please e-mail us here.
I just had mine off two weeks ago.
Remove all torx screws
Remove door handle
Remove trim piece between upper window sill piece and main door panel (as Phil described)
Remove additional torx screws and bolts under trim piece
Loosen upper trim piece
Disconnect wiring to door light in lower corner of panel
Remove panel
To get at the back side of the door handle, you now have to remove the interior panel that holds the window mechanism in place
Put window all the way down
Unscrew all the torx screws holding panel in place
Pop the bottom of the panel out and slowly lower the panel out of the door
Remove handle rod from back side of door handle to door latch (I removed the rod from the latch side on removal, but had to connect this side first and leave the door handle side free on re-installation)
Once the top of the window glass is out of the track, you can fully remove the panel and window mechanism as one piece
Disconnect wires to electric window motor if equipped
Reassembly is the reverse of above. It isn't that hard and can be done with one person.
My passenger door handle was gunked up and sticking, so I pulled everything apart and cleaned and lubed the mechanism two weeks ago
My First Solar Install Thread
Remove door handle
Remove panel
THANK YOU for those detailed instructions!
Thanks to al! have a Blessed Day
