MIKE&GRANNY Posted February 6, 2015 Report Share Posted February 6, 2015 ANYBODY OUT THERE HAVING PROBLEMS WITH NEW HORIZONS FIVERS HAVING STRESS CRACKS IN THE CORNER OF THE BEDROOM SLIDE. I HAVE TALKED TO A FEW FOLKS AND THIS SEEMS TO BE A FAIRLY COMMON CONCERN. I AM EXPERIENCING THIS AND NEED A LITTLE ADVICE. THANKS EVERYONE FOR YOUR HELP Link to comment Share on other sites More sharing options...
Jack Mayer Posted February 7, 2015 Report Share Posted February 7, 2015 If the crack is from the corner of the bed slide down to the edge of the compartment door then that is a very common crack. Not just on a New Horizons, but common on many coaches. It usually occurs when the distance between the two is not very great. The only real "fix" is a relief cut and a trim strip. That will take care of it. That is the same fix most manufacturers use for this kind of crack. In fact, some manufacturers put this strip in preemptively. This applies to most of these situations, but there are some cracks that are not of this type. I'd have to see it to be sure. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
budeneighe Posted February 7, 2015 Report Share Posted February 7, 2015 My 1999 King of the Road has it, too, as has a later model KOTR which I have also seen it happen on. I have seen the gap change just with temperature so I think this implies it is just the surface material that has fatigued. Main thing is to seal is so water does not penetrate. RVBuddys Journal Our progress into full-timing.Budd & Merrily ===-> SKP# 088936 Other Websites:---> Hub of all my blogsClifford - 2000 VNL64T770 :: DakotR - 1999 C40KS King of the Road :: $PRITE - 2013 Smart Passion w/cruise Link to comment Share on other sites More sharing options...
GlennWest Posted February 9, 2015 Report Share Posted February 9, 2015 If I owned a New Horizons and it had cracks I would be yelling. lol 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
bigjim Posted February 10, 2015 Report Share Posted February 10, 2015 I thought it sometimes meant emphasis of something vs (yelling) but what do I know. This isn't a big deal in the scheme of life but I might have waited to see if they did it more than once or twice. They may be as ignorant of the proper ettiquette in the internet as me but I doubt it. Without even knowing them, I give them more credit. Link to comment Share on other sites More sharing options...
nana25k Posted February 10, 2015 Report Share Posted February 10, 2015 OK folks. Back on topic. In our case our Holiday Rambler developed a downward slanting crack from the front bottom corner. When the aluminum skin was opened up it we discovered that the aluminum upright frame stud closest to the slide opening had a bad weld at the bottom which broke. HR did a wonderful repair. Ron & LindaClass of 20072000 Monaco Diplomat 2005 Honda Element"Do what you can, with what you have, where you are" Theodore Roosevelt"We can't control the wind, but we can adjust our sail""When man gave up his freedom to roam the earth, he gave up his soul for a conditioned ego that is bound by time and the fear of losing its attachments." Link to comment Share on other sites More sharing options...
Hopbikers Posted February 11, 2015 Report Share Posted February 11, 2015 We have a 2010 New Horizons and this crack appeared in the last year. It could be considered a design issue when any fifth wheel is built with a short distance along a potential stress area. As Jack stated, the only repair would be a trim piece to allow the give and go of the stress. Link to comment Share on other sites More sharing options...
Rick & Alana Posted February 11, 2015 Report Share Posted February 11, 2015 I have a similar crack, same place on our 2009 DRV Mobile Suites. I have been watching it for 3 years with no change. Rick and Alana Fulltimers 2018 Newmar Ventana 4037 2020 Jeep Gladiator 1997 Jeep TJ 2009 Mobile Suites 36RSSB3 formerly owned 2000 Volvo 770, 600 Cummins ISX,18 speed autoshift, 14 foot "garage" ET,Jackalopee,MaxBrake,Pressure Pro pro www.rickandalanasgreatadventures.blogspot.com Link to comment Share on other sites More sharing options...
Jack Mayer Posted February 11, 2015 Report Share Posted February 11, 2015 We have a 2010 New Horizons and this crack appeared in the last year. It could be considered a design issue when any fifth wheel is built with a short distance along a potential stress area. As Jack stated, the only repair would be a trim piece to allow the give and go of the stress. Well I suppose you could eliminate the bedroom slide, OR eliminate the compartment door. That would - and does - resolve the issue. OR youcan build a longer coach that does not have the doors located in that area. Like ours. But given the size of the coach there is not much you can do if you want basement doors and a slide. The newer structure - starting in 2015 - will likely resolve this issue. At least that is my opinion. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
spindrift Posted February 12, 2015 Report Share Posted February 12, 2015 We have a 2010 New Horizons and this crack appeared in the last year. It could be considered a design issue when any fifth wheel is built with a short distance along a potential stress area. As Jack stated, the only repair would be a trim piece to allow the give and go of the stress. I hope you're planning a visit to the factory in the near future. 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
