John Laninga Posted February 4, 2015 Report Share Posted February 4, 2015 Saw all the benefits of the new Phantom firmware update and that sure looks good. So I updated my Go2 with WFRBoost, and the process went perfectly. So my initial response is that the update works for a MacBook computer driven Go2. All the new menus (except one) work as expected. The only exception so far is that the "Usage" tab comes up OK but usage never gets updated. I get a continuous icon show that it s working but nothing shows after an hour of trying. There are a lot of new features and it will take some time to work it all out. So far, so good... == John 2015 Entegra Aspire 44B diesel pusher with 2017 GMC Acadia Denali toad Web site, albums, blog and more here Link to comment Share on other sites More sharing options...
docj Posted February 4, 2015 Report Share Posted February 4, 2015 John: The Usage tab does take several minutes before it will begin to show data, but an hour is definitely way too long. I assume that you have checked the boxes under the graph at the top, the ones that are labeled: Show Internal WiFi WAN and Show WFRControl? If those are checked and you're still not seeing anything, I suggest you reboot the system to see if that fixes the problem. Joel Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
John Laninga Posted February 4, 2015 Author Report Share Posted February 4, 2015 Joel, a reboot of the WR did bring up the Usage tab, showing usage. Now I better look for a detailed user manual, as there are a lot of very good features on this update. == John 2015 Entegra Aspire 44B diesel pusher with 2017 GMC Acadia Denali toad Web site, albums, blog and more here Link to comment Share on other sites More sharing options...
docj Posted February 4, 2015 Report Share Posted February 4, 2015 John: If you go to the https://www.wifiranger.com/support website there are quite a few new FAQs and Knowledge Base articles as well as instructional videos covering the features of the new firmware. Joel Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
