Chillbilly Posted January 11, 2015 Report Share Posted January 11, 2015 I have old concrete in southern Florida which is pitted and full of small cracks. It does have character. I want to paint it with an inexpensive coating. I don’t want to spend the money for the epoxy coverings. Paint dealers claim their concrete will not chip, although there are many in this park with painted patios which are very chipped. I will take the chance, even if I have to touch it up every couple of years. My problem is, over the summer when no one is here, the concrete gets very dirty. It gets mildew and mold. Will the paint seal the concrete? Or, should the concrete be sealed before painting? If so, with what? What paint would you suggest? Any help will be appreciated. Chillbilly "Campgrounds In And Around The Great Smoky Mountains National Park" "Knowledge Gained - Known, Found, Borrowed, and Stolen" Knoxville, TN Winnebago Adventurer 31Y - Jeep Liberty Semper Fi Preview Books Link to comment Share on other sites More sharing options...
WeBeFulltimers Posted January 11, 2015 Report Share Posted January 11, 2015 You want the best and want it cheap? Fulltiming since September 1, 2010 2012 Ford F-350 PSD SRW Lariat Crew Cab 2012 Montana 3585SA Link to comment Share on other sites More sharing options...
Devilishjim Posted January 11, 2015 Report Share Posted January 11, 2015 You need to pressure wash it and make sure it's totally dry and then apply two coats of paint at least 24 hrs between coats and then repeat the same with two coats of sealer.Home Depot or equivalent should have what you need. Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
lappir Posted January 11, 2015 Report Share Posted January 11, 2015 Not an expert but there is most likely always going to be moisture in concrete in Florida. Either 80% humidity, the morning dew (also from humidity) or the rain. You will have to be very patient and lucky to be home and ready to paint at a moments notice when everything is as dry as can be. You could try one of the products they sell for "basement' walls that is supposed to prevent moisture from outside to come in, but then I am not sure if the paint would adhere. I can't remember what they call it but the round pebbles embedded in an epoxy is what I had on my lanai and an annual pressure wash with a bit of bleach would kill the grass around it and keep it looking good for almost a year. Was a full day job though 20 x 30 ft. Rod White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
lartross Posted January 11, 2015 Report Share Posted January 11, 2015 You may want to consider staining it. Lasts longer, but doesn't seal it...Good sealant is expensive. 2003 Coachman Chaparal 276 RLS 2000 F250, 7.3l auto ext. cab 4x4 Link to comment Share on other sites More sharing options...
Bobq21 Posted January 11, 2015 Report Share Posted January 11, 2015 Hi, there is always moisture in concrete unless there is a good vapor barrier between it and mother earth.BobQ Bob and Snookie Quinn 2006 F-550 CC Custom Bed 2012 Mobile Suite 38 Rssb3 Fulltiming it!! SKP#96210 30 years Retired USARMY Link to comment Share on other sites More sharing options...
CookieMon Posted January 11, 2015 Report Share Posted January 11, 2015 In my opinion painting is not a good solution in your situation. 1. You do not know if there was a vapor barrier put down be for the concrete was laid. 2. I am assuming the concrete has been there for some time. Based on your comments about moisture and mildew, I would either do it right or not do it at all, or you will just be wasting your time and money. Doing it right will involve etching the concrete first to open the pores and make it penetrable with a product such as this: http://www.hcconcrete.com/products/shark-grip-prep-products/Etching_Solution/index.jsp Then following with a good quality concrete sealer such as this: http://www.hcconcrete.com/products/solid-color-stains/solvent-based-sealer/ You can read and decide for yourself whether you want to paint or seal. In either case you will need to etch the concrete first to have any chance of a decent result with either method you choose. I only mention the brand above as I had experience with them in my career as General Superintendent in concrete construction. There are undoubtedly other equally good products out there. When I was still working, H&C products were available through Sherwin Williams among others. Link to comment Share on other sites More sharing options...
Devilishjim Posted January 11, 2015 Report Share Posted January 11, 2015 I'm BAD and my memory is worse Yes you do have to etch it or your wasting your time...How about artificial turf Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
rwp48 Posted January 12, 2015 Report Share Posted January 12, 2015 Acid wash the concrete. Pressure wash thoroughly to get any dirt off and to remove all the acid. If there is significant cracking, DAP and others make a gun grade caulking-type product to fill the cracks. Do not paint. Use a concrete stain like the H&C product. This is a penetrating stain and sealer. Porter Paint is usually a good source. If they have a water-based stain, it's easier to handle and probably a bit more moisture tolerant. Check with the paint store to see if they recommend a texture additive like Shark-Grip or something similar. Above all, enjoy yourself. You are going to have a ball! Link to comment Share on other sites More sharing options...
StarDreamers.us Posted January 12, 2015 Report Share Posted January 12, 2015 You could plan a party, invite some friends to share the fun. Safe Travels! SKP #89742 - Lifetime membership - Member of the SKP Class of 2007Good Sam Club - Lifetime MemberDataStorm #5423Passport America - Lifetime MemberSons Of The American Revolution (SAR) - Lifetime MemberAmerican Legion - USAF - Lifetime MemberRotary Club Member - 30 years Escapee CARE Supporter National Wildlife Refuge Volunteer Link to comment Share on other sites More sharing options...
