floncto Posted December 2, 2014 Report Share Posted December 2, 2014 My DW has a bad knee and has always found it hard to deal with the steps, in the entrance to our fifth wheel, but even more so getting into the bedroom. We are not fulltime and so we must load and unload whenever we travel. After unloading from a long Thanskgiving weekend trip, I also found myself very stiff. Has anyone modified the bedroom steps to make them shorter per step? 2005 F-250 6.0 Liter Diesel 2007 Coachmen Wyoming 325 RLTS 2 Shih Tzu's - Squirt (Mom), BeBe (Baby) Link to comment Share on other sites More sharing options...
HERO Maker Posted December 2, 2014 Report Share Posted December 2, 2014 You could do that and make them 1/2 as high, but that would almost make them close to twice as long and may come out into the kitchen / entry area. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Bob Cochran Posted December 3, 2014 Report Share Posted December 3, 2014 For sure don't want to mess with the tread width as you really need that to safely place your foot. So rebuilding the step tread rise will increase the run and it certainly wind up in the kitchen. On mine if I did it the bottom step would be in front of the doors so was not a consideration. Outside steps I had replaced when purchased the RV from 3 steps to 4 and it awesome for the wife but outside the run is not the problem but was a $'s decision. Although I have instances where the bottom step was flat on the ground. 2019 Thor Chateau 28E on a Ford E450 chassis. Maybe awhile but will get a new picture forgive one up there it is my old rig. Link to comment Share on other sites More sharing options...
Big Greg Posted December 3, 2014 Report Share Posted December 3, 2014 Not sure how the inside steps can be changed without causing other problems. Can you add better hand rails to help? As far as the outside steps we have a set of Port A Steps that we rally like. Greg http://rv-co.com/index.html Greg & Judy Bahnmiller Class of 2007 2014 F350 2007 HitchHiker Champagne Both sold 2/19, settled in Foley, AL after 12 years on the road http://bahnmilleradventure.blogspot.com/ Link to comment Share on other sites More sharing options...
Roadwarriror Posted December 3, 2014 Report Share Posted December 3, 2014 been looking for something to get in bus take a look at these lifts Fulltiming since 1989. No TLC's-- Accessing the internet with Wifi Evdo enabled mobile card from Verizon Wifi SSID r0adwarrior on the road for Access to Internet, ask for Key. Wifi SSID r0adwarrior for Access to Webpages in Bus. http://roadwarrior.free-man.com/ Link to comment Share on other sites More sharing options...
lakejumper Posted December 4, 2014 Report Share Posted December 4, 2014 I had two steep steps going up to the bedroom when I bought my RV. I modified them into three shorter steps by building a small Wooden removable box for a third/last step. I then added a 2x12 inch board on top of the second step. I held it in place with two L brackets and covered the 3rd step and 2x12 with carpet. I can remove the third "box" step so it doesn't interfere with the door to my water heater and so that my slide out doesn't hit it when I close it. I have done this in my last and current RV. I also added a wood grab rail by the steps? 2016 Winnebago Vista LX 30T Link to comment Share on other sites More sharing options...
