Vertical antenna for portable use
No replies to this topic
#1 TXiceman
TXiceman
    Senior Member
  • Validated Members
  • 265 posts
  • SKP#:108682
Posted 13 March 2012 - 06:32 AM
I just got a JTV-680 (like the Comet CHA250B) antenna set up to work on my 5er. I used 1-1/4" EMT and mounted it off the rear ladder. Using a 1-1/4" exterior union or connector, I add 5 ' above the roof line and mount the antenna on top of this. The base of the antenna is roughly 18' above the ground.
I am running a Kenwoo TS480HX with an LDG AT200 Pro tuner. The Comet has mixed reviews ranging from sorry antenna to not so bad. I found that while tha antenna is not as good as a good dipole, it does work reasonably well. It is easy to store and asembly and can bu up in about 10 to 15 minutes.
While it is not the antenna of choice, it does work reasonably well for a compromise antenna.
Ken
KE5DFR
<i><b>Amateur radio operator, 2008 Carriage Cameo 35SB3, 2012 F350 6.7L, <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot<br /></b></i>
