Cleaning Black Water Level Indicators
#1
Posted 18 January 2012 - 09:25 AM
I saw one suggestion about filling with 1/2 clear water then adding a bag of crushed ice to use as a cleaning method... Then drive for an hour or so making plenty of stops and up/down hill routes so that the ice "scrapes" the gunk off the sensors...
Any other suggestion that you have found that will work???
#2
Posted 18 January 2012 - 09:36 AM
#3
Posted 18 January 2012 - 10:20 AM
W5SUF
2009 Optima 42' Truck Conversion
Freightliner Columbia
#4
Posted 18 January 2012 - 10:39 AM
Many of us full timers or long timers just learn about how long we can go before dumping. That, and the bubble upon flushing when the tank is almost full, are the only true indicators.
#5
Posted 18 January 2012 - 10:45 AM
What most of us do is to learn to know when the tank is near full and just ignore the level indicators. There are more reliable level monitor systems that can be added to an RV but very few of the manufacturers bother to use them because they cost more.
One thing that I should mention is that dish detergent is not a good choice. It creates suds when agitated. Friends or ours tried that as a cleaner and when they went to flush the toilet, the bowl filled with foam! It took several rinses to completely get rid of the result.
Edited by Kirk, 19 January 2012 - 09:24 AM.
Author & Escapee's Magazine contributor
Full-time 11 years...... Now seasonal travelers again.
8 yr, submarine service, 9 cold war missile patrols
#6
Posted 18 January 2012 - 11:30 AM
Without the wand we dumped in a quarter cup of dish detergent and dumped the hot water heater into the tank, that helped but the wand worked better. If you have a long dump pipe you'll want to add the water first or all your cleaner will end up in the pipe.
If you have access to cold water the ice can do some good, warm water and the ice will be gone in a couple minutes. Starts and stops, just driving around the park are enough to get the ice sloshing, no need to go out looking for hills and soon is good or the ice will be melted.
#7
Posted 18 January 2012 - 12:30 PM
#8
Posted 18 January 2012 - 12:51 PM
This will not only clean the sensors but the whole black tank and make it very easy to flush out at the next dump. Then do it again at that next dump.
I do not have a sensor problem and never did but I do this as it is a very good tank cleaner.
2006 New Horizons 30' 5th wheel Solar
2006 Chevy 3500 8.1/Allison
#9
Posted 28 January 2012 - 06:56 AM
Dump and flush thoroughly. Put in 5 gallons of water. Put in one cup of laundry detergent and one cup of water softner. Do this just before traveling.
#10
Posted 28 January 2012 - 07:05 AM
This is the stuff I used, Calgon Water Softener. It's a powder, I found it at the local Walmart in the laundry detergent section.
#11
Posted 28 January 2012 - 08:23 AM
There are things which help for a while, mostly cleaning products. Most fulltimers eventually just learn when to dump and ignore the indicators. There are a couple of tank level indicator products that do seem to work. I have read positive reports on RV Probes and a much better gauge system than most RVs come with is the one from SeeLevel, both of which can be retrofitted. I have not used either of these.
If you want there are many ways to spend more money on the problem but their greatest effect of most is to lighten the wallet!
#12
Posted 28 January 2012 - 09:14 AM
First year I spent/wasted a lot of $$ money on chemicals, etc, and home fixes.
I full time and what has worked for me is to dump(40 Gal tank) every 12 days when sitting. More often when traveling, maybe every 4-5 days, just to cut on weight carried.
I Close Gray tank two days before Black dumps.
I have the schedule in a MS Office calendar in my Desktop that also has reminders when to check water in batteries and exercise generator.
99 Discovery 34Q DP | ISB Banks PowerPack
"08" LT2 HHR Toad
#13
Posted 28 January 2012 - 10:07 AM
PLEASE no PM's. Email me.
2012 New Horizons 42.5' Custom 5er; New Horizons Ambassador
1999 Volvo 610, ISM 400/1450, 182" wb, Autoshift
2009 Volvo 780, D16 515/1850, 230" wb, I-Shift, smart deck
2003 Jeep Wrangler Rubicon behind the 5er
#14
Posted 28 January 2012 - 04:40 PM
I gave up worrying about it years ago. As previously said, after you use your RV for a long time, you get a good feel for the tank levels. With us, the grey tank fills first so if the grey tank is filled, it's time to dump. If we're running off the fresh water tank, as we almost always do(we basically never hook up to the city water connection ), we'll run out of water before the black tank is full. When it's time to add water, it's time to dump the tanks. So, I dump if out of water or if the grey tank is full; whichever comes first.
If it's really important to you, go with the SeeLevel system as mentioned. You can get a nice system professionally installed for about $800.
ed
Edited by ed ed, 28 January 2012 - 04:42 PM.
#15
Posted 05 February 2012 - 02:33 PM
There are lots of ways to clean the interior sensors. All the methods have one thing in common. They will work until the very next time you use the black tank then the sensors will foul again.
ed
#16
Posted 05 February 2012 - 02:42 PM
RV'r and gave me this advice. Use RID-X in the RV but not in the home septic system. His claim is that it introduces a bacteria that is a digestor of the black "stuff". Not needed in a home system of 1500 gallons. He leaves enough in it to re-start itself.
I dump using a see-thru section of hose and find absolutely NO solids or paper when I dump. As for the sensors, I ignore the problem and listen for the tanks indegestional "burp".
I use about a 1/4 cup after each dump. I find that it satifys my anxiety of build up phobia. I also keep the tank with an amount of water in it after dumping. The amount is purely a guess each time but I feel it is ample.
Good luck in clean sensors.
#17
Posted 05 February 2012 - 09:51 PM
We did use Rid-X when we came back to our RV spot after several months away, a dump of the gray tanks, then the black freshened the septic contents and a scoop of Rid-X gave the bugs a head start.
#18
Posted 05 February 2012 - 10:20 PM
They must of fixed the slow acting Rid-X since you used it Stanley. Rid-X FAQRid-X is great for anxiety attacks, the stuff in it works too slowly to do much if any good in an RV tank that gets dumped every couple weeks.
I have used it all winter in my winter spot for over 12 years that uses a home septic system. It never cleans the sensors. But it does break every thing down in the 12 days before each dump.
That every thing goes through a 3/4" sewer solution hose 35-40' uphill from the MH.
How soon does RID-X® begin work? A: The enzymes in RID-X® begin working as soon as they come in contact with water. The bacteria take 2-4 hours to germinate and then begin to break down solid waste. If the temperature and conditions are favorable, then the bacteria will multiply to the maximum level that the environment will allow in about 2-4 days. Since septic systems vary, the speed at which the bacteria and enzymes break down waste varies.
"08" LT2 HHR Toad
#19
Posted 06 February 2012 - 09:35 AM
I doubt Rid-X would do anything to help sensors, though. Possibly it might help prolong intervals between "problems". But even that is doubtful. The only real solution to sensor problems is external sensors.
I would never use any of the advertised "chemicals". They are totally a waste of money, IMO, and not necessary.
Edited by Jack Mayer, 06 February 2012 - 09:38 AM.
#20
Posted 06 February 2012 - 10:00 AM
This topic is locked
