Repack wheel bearings, How often?
9 replies to this topic
#1 Mr. Dave
Mr. Dave
    Major Contributor
  • Validated Members
  • 585 posts
  • SKP#:105185
Posted 12 July 2011 - 05:04 PM
I've heard that your trailer wheel bearings need to be repacked. However, I've never heard how often. I've got a car tow dolly that had the bearings repacked 2 years ago with apprx. 9,000 mi. use since. They seem OK with no extra free play or anything. Should I have them repacked again? One shop told me every 10,000 mi. and another every 30,000 mi. What do you think? Please advise as to what you do with your trailers. Thank you.
2006 Coachmen Class A, Aurora, 36ft. motorhome. Gas engine, Ford V-10. 2007 Toyota Matrix toad. "Snow birds", apprx. 6 mos. ea. year. Travelling to the SW US. in winter then returning to Wis. for summer. -  Buddy & Ringo, our 2 feline friends along. Retired & enjoying our RV lifestyles.
#2 richfaa
richfaa
    Major Contributor
  • Validated Members
  • 3584 posts
Posted 12 July 2011 - 05:15 PM
Have over 40K miles on the 5th wheel. Had the wheel bearings repacked today for the 3rd time. They are the original bearings and they were in perfect condition.
#3 nana25k
nana25k
    Major Contributor
  • Validated Members
  • 2921 posts
  • SKP#:97338
Posted 12 July 2011 - 07:17 PM
Ron does ours on the 5th wheel every summer. Doesn't take very long andit also give him a chance to get a good look see at lother wheel related stuff.
Ron & Linda
Class of 2007
2007 Dodge Quad cab Dually
2000 Holiday Rambler 32RKT
"Do what you can, with what you have, where you are" Theodore Roosevelt
"We can't control the wind, but we can adjust our sail"
"When man gave up his freedom to roam the earth, he gave up his soul for a conditioned ego that is bound by time and the fear of losing its attachments.
Ed Conley http://www.wyde-angle.com/?p=933 (A short editorial written about us by Ed when we hit the road.)
#4 Charlie P
Charlie P
    Major Contributor
  • Validated Members
  • 541 posts
  • SKP#:SKP 85684
Posted 12 July 2011 - 07:29 PM
We have a 96 HR 5th wheel. They say to repack at 10,000 miles, so that is what we do.
There is nothing worse than having a frozen up and burnt up wheel bearing, and being stuck on the side of the road!
Charlie and Yvonne
2005 Silverado Duramax - 1996 Holiday Rambler 5th Wheel
Visit My Website
Our Weather Location Profile Page
#5 Stanley P. Miller
Stanley P. Miller
    Major Contributor
  • Weekend Moderators
  • 14432 posts
  • SKP#:51443
Posted 13 July 2011 - 12:57 AM
We did it every winter, it doesn't take long and gives you a chance to check and adjust the brakes at the same time.
The function of weekend moderators: We hide spam posts and put a hold on known spammers making more posts. We aren't even allowed to delete the spam posts! That is the beginning and end of our powers.
#6 LindaH
LindaH
    Major Contributor
  • 5303 posts
  • SKP#:49643
Posted 13 July 2011 - 09:42 AM
Every fifth wheel we've had recommended repacking the bearings every year or 12,000 miles, whichever came first.
LindaH
2007 Excel Classic 30RKE
2007 Dodge Ram 3500 DRW w/5.9 Cummins
#7 Lady Fitzgerald
Lady Fitzgerald
    Senior Member
  • Validated Members
  • 235 posts
Posted 13 July 2011 - 01:38 PM
I would think time interval would be as critical as number of miles rolled since moisture could get in and cause corrosion problems and heat could dry out the grease. When I get my TT, I seriously doubt I will tow it more than 300-400 miles a year. If I waited 'til, say. 12,000 miles, it would be over 30 years before I packed the little buggers! No lube, even a synthetic, is going to last that long (heck, I probably won't). Stanley has the right idea about doing it yearly. If I didn't plan on jacking up the axles so the wheels could be spun every so often while the TT sets for 4-8 months at a time, I would be tempted to do them just prior to each move.
#8 RV Tamer
RV Tamer
    Senior Member
  • Validated Members
  • 142 posts
  • SKP#:21884
Posted 13 July 2011 - 06:20 PM
Kathydavidb,
We usually advised customers to have their trailer wheel bearings repacked every 12,000 miles or yearly.
Not only were the bearings and races checked, but all of the brakes componets. Even the wheels and tires were inspected due to possible alignment issues . More than what you would think, we would find brakes shoes that had been glazed over due to excessive heat. Also on occasion, we would find brake shoes that were cracked, and on other occasions, some of the brake parts had come loose and were spinning in the drum area causing additional damage.
If the rv had been not used in quite some time, or it's parked for some time near the ocean , we would find corrosion build up, even though the customer might have only had maybe only a thousand miles on the rv since the last time the hubs and brakes were serviced.
I guess what I 'm trying to tell you that it's not just a mileage or time thing, it's also a safety check .
I hope this helps................................tim
#9 Stanley P. Miller
Stanley P. Miller
    Major Contributor
  • 14432 posts
  • SKP#:51443
Posted 13 July 2011 - 10:27 PM
Annual repacking is also a good time to check for broken or worn suspension parts, much cheaper to find and fix before they break.
#10 RayIN
RayIN
    Major Contributor
  • Validated Members
  • 3854 posts
Posted 15 July 2011 - 07:40 PM
That is exactly what the Dexter service manual states for standard bearings. Even with EZ-Lube axles, which I do not use, the hubs must be removed to inspect the brakes on the same schedule.
"As nightfall does not come at once, neither does oppression. In both instances there is a twilight where everything remains seemingly unchanged. And it is in such twilight that we all must be aware of change in the air - however slight - lest we become unwitting victims of darkness."___Supreme Court Justice William Douglas
