Apr 4 2010, 10:10 PM
Post
#1
![]() Senior Member Posts: 149 Joined: 4-April 10 From: Central Indiana SKP#: 105769
1993 International DTA360 with a 545 Allison, under 70,000 miles, Carpenter body, 65 pass. I'll give the quick tour
As bought ![]() Roof raised 18" ![]() New cap & skins (20 ga) ![]() 1-piece front door ![]() Extended rear door height (which will lead to a small deck) ![]() 3-layers of 3/4" polystyrene in walls ![]() Trusses for ceiling vault going in ![]() Battery bank storage (have one for firewood also, with inside doors to access wood to feed the stove. This means no carrying wood into the bus., load from outside, access from inside directly below the stove) ![]() Fast-forward a bit to the interior 75 gal FW tank under the couch, there will be an additional 108 gal on the roof. I have a 75 gallon gray tank under the bed. ![]() My stainless steel salad bowl sink & bar faucets ![]() ![]() 32" 1-piece shower stall. Trusses intruded a bit into the shower, so they were trimmed, which is why the angles ceiling. I'm 6'2-3" and the shower head is 6'5" off the shower floor. ![]() 20" gas range (with vented range hood) & 7 cu ft chest freezer which will be adapted for 'fridge use. The freezer is setting on top of the PV battery bank. ![]() Area for wood stove, access doors underneath go straight through to outside access door ![]() Flat screen TV to mount over drivers area. I've been trying to buy some old barn siding for 3 weeks now, 2 deals have fallen through, so I guess I'll replicate as best I can with new wood. Oh, ceiling will be corrugated tin barn panels. I have about a 6'9" ceiling. ![]() Table & seat (It's just me, so plenty of room) ![]() Smitty This post has been edited by Neon Moon: Apr 5 2010, 06:41 AM |
Apr 5 2010, 12:02 AM
Post
#2
Major Contributor Posts: 1,585 Joined: 28-February 08 From: Yukon in the summer, somewhere warmer in the winter, on the road in the shoulder seasons.
Looking good so far!
Neat idea using the freezer as a fridge; I've done some reading on the subject and know that this will be a significant energy saver for you. I have friends who put in a wood stove in their school bus. It had a removable chimney which made the bus look so whimsical! How big of a job was it to raise the roof? I understand that in your case this was definitely not a luxury! -------------------- |
Apr 5 2010, 06:49 AM
Post
#3
![]() Senior Member Posts: 331 Joined: 5-August 09
Very nice, looks like a fun project.
-------------------- ... Chrissi & Randi
2000 VNL-770 "RD-FLYR" 1957 M-274 Mule http://www.cozygirrrl.com/redflyer/redflyer.htm |
Apr 5 2010, 07:16 AM
Post
#4
Hi Rae & Cozy, thanks! The big thing on having a chest "fridge", was all the cold not pouring-out when the door was opened. I have a thermostat ordered, and a Kill-a-Watt so I can get some actual figures to order solar components.
I was trying to find one of these: http://www.homeelegancecenter.com/ProductD...;Show=TechSpecs but couldn't seem to find anyone who stocked them, so I gave-up. The complaints were the bottom drawer ("soft freeze") wouldn't freeze....perfect since I could have used it for the refrigerator, and still have a freezer for extended food storage. I figure with the water I can carry, as well as the food and other supplies, that I could boondock for right at a month before needing anything. I will also have a 24" removable section (with cap) which will be removed for travel, or during warm weather. I don't plan on having to use it a lot, but I've always liked a fire. I also added a line while running the LP to the cook stove, for a direct vent heater which can also set on the platform next to the wood stove. It would be handy to run a heater for 5 minutes to knock the chill off, as opposed to starting a fire in the stove. I was joking with someone about the insulation I've added, and I've have to switch to smaller light bulbs, because they made it too hot in the bus Roof raise was a piece of cake. The actual lifting was done with 2 chain hoists hanging from 2 steel structural beams that were part of the building where the bus is parked, they were spaced perfectly. ![]() I had 11 ga. pieces formed to weld into the window pillars ![]() ![]() Then there was steel added for strength ![]() ![]() Including window frames and battery bank & wood storage doors ![]() ![]() The initial plan was to have a completely flat ceiling. I'm 6'2" + and could just stand in the center of the bus,but I didn't want the exterior any higher than necessary. I knew I was cutting it close, but didn't quite make it. It worked-out for the best though after I decided to vault the ceiling, less wasted space in the "attic", and I still have all the insulation I wanted as well as all the overhead room I need. I'm really pleased with how things have went so far, and I'm anxious to get it finished, I'm ready to move-in! Oh, I grew-up spending nearly every weekend camping in one of the buses dad converted for him, mom, and us 5 kids Smitty
This post has been edited by Neon Moon: Apr 5 2010, 07:17 AM |
Apr 5 2010, 11:54 AM
Post
#5
![]() Major Contributor Posts: 1,069 Joined: 4-July 02 From: Socorro, NM until ?
Deja vue! Hey Smitty, what are you doing here over on an RV board? And using a different name!!!
Welcome to Escapees! -------------------- |
Apr 5 2010, 12:06 PM
Post
#6
Senior Member Posts: 119 Joined: 7-November 09
smitty,great job. that perked up this forum some. about time.lol. so get it done so we can see it with you in it.
Outlaw -------------------- John an Colleen Weston
Bothell, WA 1990 chev 1 ton dually |
Apr 5 2010, 10:34 PM
Post
#7
Deja vue! Hey Smitty, what are you doing here over on an RV board? And using a different name!!! Welcome to Escapees! smitty,great job. that perked up this forum some. about time.lol. so get it done so we can see it with you in it. Outlaw Thanks Outlaw, trust me....it couldn't be done soon enough! I'm 53 staying with my 85 year-old parents Should have an update in a day or 2.... Smitty |
Apr 6 2010, 08:35 PM
Post
#8
![]() Senior Member Posts: 115 Joined: 4-August 06 From: USA SKP#: 10****
Looks great, smitty. Love the family pic, sooo cute!
-------------------- Kind regards
~Laughter is as essential as the air we breathe~ |
Apr 6 2010, 09:24 PM
Post
#9
I like your description of raising the roof. I'm sure it was a piece of cake if you know how to weld and whatnot! I'm still impressed!
Apr 6 2010, 10:31 PM
Post
#10
We got some trim painted and put on today, it's nice to start to see a little color coming to life. I'm putting corrugated tin (barn roofing) on the ceiling. I've been trying to buy some old barn siding for over a month now, and both deals went south.
I plan to use it on the entire head....to give the impression of setting in an old outhouse (lol, used to use one at grandmas). The rear wall will be back-lighted (behind the wall) so the moon & stars will light-up with the flip of a switch). ![]() The composting toilet, the small narrow doors on either side are for sawdust/peatmoss storage. ![]() Todays progress- window trim, wrapped the support post at the entry wall, and trimmed the table. ![]() ![]() ![]() Picked-up a 26" flat screen TV today which will mount over the drivers area, going tomorrow to order materials for the roof and rear decks, as well as trying to find someone to upholster some seat cushions for the bench at the table, and the couch. This wall is now finished (paneled and trimmed, I need to get a pic), and I plan to find someone to make a stained-glass panel for it for a little entry lighting, and conversation piece. It will be of....what else, the Neon Moon. ![]() Smitty This post has been edited by Neon Moon: Apr 6 2010, 10:38 PM |
Apr 7 2010, 12:11 AM
Post
#11
Love the outhouse idea.
Apr 7 2010, 03:58 AM
Post
#12
Senior Member Posts: 491 Joined: 2-April 02 SKP#: 31721 |
Very nice! One question, though...
QUOTE 75 gal FW tank under the couch, there will be an additional 108 gal on the roof. Since a gallon of water weighs about 8.3 lbs per gallon, your roof will have to support 620 lbs. If you have less than a completely full tank, the water will slosh back and forth over the width of the tank. For example, if the tank is 3/4 full, you'll have about 465 lbs sloshing back and forth. I'd think this could lead to stability and/or structural problems. This post has been edited by Lou Schneider: Apr 7 2010, 03:58 AM -------------------- Lou Schneider
#31721 |
Apr 7 2010, 10:31 AM
Post
#13
Major Contributor Posts: 9,473 Joined: 3-April 02 From: Woodland Park, CO for the summer SKP#: 60376
You may have thought of the issues Lou is speaking of. If not, be very careful. I have some experience with moving liquid loads....you could have some issues with this setup if you plan on traveling with water in it. If it is just for when in "camp" - no issues other than weight.
Can the bus take the weights you are adding to it....? I don't know much about School Bus frames... -------------------- Jack & Danielle Mayer #60376 Lifetime Member
2010 New Horizons 42' Custom 5er; New Horizons Ambassador 1999 Volvo 610, ISM 400/1450, 182" wb, Autoshift 2003 Jeep Wrangler Rubicon behind the 5er HDT Conversion Site and Solar Info |
Apr 7 2010, 04:07 PM
Post
#14
I think Smitty plans on traveling with the tank on the roof empty. I'm pretty sure he already addressed that over on the skoolie.net forum.
Apr 8 2010, 06:46 AM
Post
#15
The roof rack will support the tank, and I intentionally got a "flat" tank (only 9" tall) to spread the weight over a larger footprint.
Bus specs: Empty Weight: 14,300 pounds GAVW 27,500 pounds 10,000 front 17,500 rear Granted, some weight has been removed from the bus (seats, interior panels, windows, flooring, lighting, miles of wiring), and much has been added. I'll weight it once it's done to know exactly what it is. Lorna is correct. The roof tank will not be used during travel, it's strictly a boondocking tank. I'll get close to my final destination, then fill it (as well as top-off the interior tank). I can fill it while filling the lower tank (or not) and I can use it to refill the lower tank by gravity (or not). Smitty |
Apr 8 2010, 09:30 AM
Post
#16
![]() Senior Member Posts: 142 Joined: 18-June 09 From: Lakeport NY -Central NY
Smitty,
Welcome aboard! great rig you're building there, cant' wait to see the progress as you go along. Though it is almost looking 'done' now, you've got a whole lot accomplished! One minor question, with the raised section on the front, have you given any thought to some sort of wind diverter or are you just going to put that big flat vertical surface into the wind and mpg be darned? It's large enough, I bet if you found a nose cone from a semi-trailer that it would fit! -------------------- 2B1ASK1 -Amicable #664 New Hartford NY
Apr 8 2010, 08:21 PM
Post
#17
Hi Ned, and thanks! I'm getting closer
Yesterday I got the ball rolling on having cushions made for the furniture (we cut the plywood backing for them today), and ordered some steel for the roof deck, and deck plate to cover the platform under the wood stove. I also ordered 4 security cameras (infra-red) which will point out each side of the bus (and double as a back-up camera), and a new in-dash stereo & speakers. UPS brought my Winegard (RS 2000) antenna today. Today was spent on the pantry face (which is directly across from the bed) and doors, along with the wood storage doors. My sister had the idea of putting cork on the front of the pantry doors as a bulletin board. I think I may do that on the uppers, and leave the lowers the way they are. I was going to put X's in them, and paint them to resemble barn doors, but like sis's idea better. ![]() ![]() Here is the stairwell light.....now I just need to find someone to make a stained glass window for it. ![]() And boxed-in one of the 24" plane-jane light fixtures and cut a lens to hide it. It will get painted & trimmed-out. Oh, I still have 6'5" of height under the light.
Apr 8 2010, 10:54 PM
Post
#18
New Member Posts: 9 Joined: 27-December 08 From: Northern California
I am lovin this thread...keep the pics and info comming........looks great
DAVEF |
Apr 10 2010, 01:20 PM
Post
#19
![]() Senior Member Posts: 154 Joined: 6-July 02 From: Pace, FL - 0n the Sunny Gulf Coast across Escambia Bay From Pensacola
I'd like more information about your composting toilet.
Rick -------------------- "Before you criticize someone, walk a mile in their shoes.
That way, when you criticize them, you're a mile away AND, you have their shoes!" |
Apr 10 2010, 01:43 PM
Post
#20
I'd like more information about your composting toilet. Rick If you go to www.skoolie.net and peruse the forum there, you will find several are using the composting toilets. There is a lot of discussion on them. This post has been edited by David & Lorna Schinske: Apr 10 2010, 01:45 PM -------------------- |
Lo-Fi Version | Time is now: 9th September 2010 - 03:01 PM |
