Dash Brake Valve
19 replies to this topic
#1 On The Road
On The Road
    Senior Member
  • Validated Members
  • 240 posts
Posted 09 November 2013 - 11:57 AM
I have searched our resource guide and the forum topics and have not come up with the procedure of replacing the dash brake valve (has the truck parking and trailer parking brakes, yellow and red knobs).  Mine is definitely leaking.  I think from the trailer brake valve.  Are these valves repairable or only replaceable. Has anyone took one apart to replace the o rings?  I came up with a volvo part number 85112212.  I have a 2001 volvo which I think would be a gen I  .   Which is the best way to remove the valve.  The volvo valve is kinda pricey.  Like around 250.00 , is there an aftermarket valve that is a replacement for this valve.
Jim
2001 610 Volvo -Volvo power 465HP/1650 -autoshift
2009 Smart Passion / cross loaded on Volvo
2014.5 Mobile Suite 41 RSSB4
VOLUNTEER CHRISTIAN BUILDERS
#2 Jack Mayer
Jack Mayer
    Major Contributor
  • Weekend Moderators
  • 20344 posts
  • SKP#:60376
Posted 09 November 2013 - 01:14 PM
There are a bunch of lined behind that integrated brake assembly that carries the parking and trailer knobs. When I replaced the one on my '99 I had to replace the entire assembly because off where the leak was. Your price is about right. I suppose your could tear it apart and rebuild portions of it if it was not the panel assembly leaking....but I was on the road and it was far easier to replace the entire thing. Volvo does not sell "pieces", or at least did not at the time. But all the "pieces" are pretty standard components and you should be able to find them if you have the time and the truck is not needed.
PLEASE no PM's. Email me.
2015 New Horizons 44.5' Custom 5er; New Horizons Ambassador
2009 Volvo 780,  D16 515/1850, 230" wb, I-Shift,  custom smart hauler deck by Herrin
2012 smart Passion, piggyback on the truck
www.jackdanmayer.com
#3 kkesp
kkesp
    Full Member
  • Validated Members
  • 67 posts
Posted 09 November 2013 - 02:37 PM
I had to replace mine this summer. I could not find the "orings" that could replace the ones that were in the part. They are not like a regular o ring I tried many different kinds but after a day or two they would start leaking. I finally just replace the entire valve.
#4 On The Road
On The Road
    Senior Member
  • Validated Members
  • 240 posts
Posted 09 November 2013 - 03:18 PM
What is the best access to the valve, is there access from the top or do I need to remove part or all of the dash in front of the valve?
#5 kkesp
kkesp
    Full Member
  • Validated Members
  • 67 posts
Posted 09 November 2013 - 03:45 PM
You can access from the top and front. Mine has a small triangular cover on top and then after you remove the red and yellow caps from the valve you can remove that access cover..
Edited by kkesp, 09 November 2013 - 03:46 PM.
#6 HERO Maker
HERO Maker
    Major Contributor
  • Validated Members
  • 2269 posts
  • SKP#:101410
Posted 09 November 2013 - 04:18 PM
Jim, I looked for my old thread when I did mine - I guess stuff just drops off after 1 year of no comments.
I thought I started at the far right side in the passenger area and started taking off the panels coming all the way to the brake valve assembly.???  Maybe not!  But the tough thing to do will be to punch out those "spring pins" to get the red and yellow knob off.  The replacement valve they sell you will be different than the one on your truck.  But you will be able to figure it out.
Good luck.
Hey brother, it was good to see you again at the Rally!
Edited by HERO Maker, 09 November 2013 - 04:18 PM.
Rocky & Sheri Rhoades
'01 Volvo 770
'05 Custom Teton Freedom Royal Stretch
HERO Makers Ministry
#7 SIBERNUT
SIBERNUT
    Major Contributor
  • Validated Members
  • 3087 posts
Posted 09 November 2013 - 04:52 PM
Even I wouldn't fool around with rebuilding one. Available used, and how often do they really go bad/leak?
"The Phoenix"
'03 KA 38KSWB
http://s918.photobuc.../?sort=6&page=1
Furkids- Sibe's CH. Nooka & CH. Sedona
#8 On The Road
On The Road
    Senior Member
  • Validated Members
  • 240 posts
Posted 09 November 2013 - 06:30 PM
Good luck.
Thanks Rock for the kind words.  Been looking for the air leak for a while, got new hearing aids and now can hear it...
Thanks Sibernut, I will not try to rebuild, thought there might be a replacement that was not a volvo part.  Kinda like the oil pressure sensor Jim Hicks was pricing , but I will replace with a new one , too much work to do it twice.
#9 lou10
lou10
    Major Contributor
  • Validated Members
  • 509 posts
Posted 09 November 2013 - 07:27 PM
if you come up with the NON volvo part number (usually a Bendix branded ones in the first gens ive seen) , there 100ish brand new on ebay..
and bendix doesnt have a rebuild guide for those, i looked when i replaced mine.
good Luck with your project
SunCatalyst
Fulltimer Class of 2007
1998 Volvo VNL64T610 Detroit Series 60 12.7 470HP/1650TQ Eaton 18spd 228"WB Tandem
2006 40' ToyHauler 3 slides and a 14' Toybox
#10 tyates007
tyates007
    Senior Member
  • Validated Members
  • 355 posts
Posted 09 November 2013 - 08:00 PM
Mine is leaking on my 99 as well. I contacted Chad at class 8 truck parts and gave him my vin # This I the part for my truck and possibly yours. It is $223.
http://www.class8tru...e/dp/B00294UKVE
Edited by tyates007, 09 November 2013 - 08:01 PM.
#11 On The Road
On The Road
    Senior Member
  • Validated Members
  • 240 posts
Posted 09 November 2013 - 08:14 PM
Yea, that is the volvo part number I came up with.  #85112212  Not sure if this part will work
#12 On The Road
On The Road
    Senior Member
  • Validated Members
  • 240 posts
Posted 09 November 2013 - 08:15 PM
Trying to post link to this on ebay but will not let me post link.  This is the title on ebay
Volvo Dash Brake Valve KN-20607
Edited by On The Road, 09 November 2013 - 08:17 PM.
#13 Softail
Softail
    Major Contributor
  • Validated Members
  • 551 posts
Posted 10 November 2013 - 09:33 AM
http://www.napaonlin...31BP_0069926666  Something like this work?
Choosing an HDT is similar to many things in life. The options are: good, cheap, and easy. Pick two.
"Hulk Smash Puny Mountain" : 2000 Freightliner Century -Cummins N14+ 460HP, 13 speed, 3.58 rears -Work in progress
2004 Fleetwood Terry Quantum 38'
Posted Image
#14 Bob Cochran
Bob Cochran
    Major Contributor
  • Validated Members
  • 2298 posts
  • SKP#:105438
Posted 10 November 2013 - 09:36 PM
I don't know about Volvo but Freightliner remember which lines go where and at what angle. Not much room back there and need them right or it just won't fit back in place. B)
Own a 37 foot 2014 Keystone Fuzion pulling with 1998 Freightliner Century. Fortunate to retire early intending to full time but circumstances prevents this at the present time. Living in a sticks and bricks home all paid off DW has to have roots some place and this works.
#15 GypsyProgrammer
GypsyProgrammer
    Full Member
  • Validated Members
  • 86 posts
Posted 11 November 2013 - 11:21 AM
KN20607 is the Haldex part number.  http://epi.hbsna.com...07&dept_id=3181
I don't see a direct x-ref to 85112212, but the link above to Class8TruckParts says it crosses to 8085430, which does cross to KN20607.  You may be able to order it through NAPA.  Their web site shows it but they don't stock it.  I do know that they can order pretty much anything they want from Haldex.  It would shipped to the NAPA jobber from KCMo.
Then of course there is that eBay auction for $112 + $10 shipping.....
#16 On The Road
On The Road
    Senior Member
  • Validated Members
  • 240 posts
Posted 11 November 2013 - 08:43 PM
Thanks to everyone , boy this has got to be some of the most knowledgeable group of folks. The knowledge and the help that is received on this forum is great.  Thanks, now to get that valve removed.
#17 porky69
porky69
    Full Member
  • Validated Members
  • 83 posts
Posted 12 November 2013 - 06:03 AM
If you are going with an non-OEM valve be forewarned that yes it will work but the line hook ups may very well be in different positions, making hook up challenging. Seen it happen at a dealership, oem valve not available but book says this one "crosses over", took them 8hours to do a 2hour job
#18 HERO Maker
HERO Maker
    Major Contributor
  • Validated Members
  • 2269 posts
  • SKP#:101410
Posted 12 November 2013 - 08:33 AM
Unless your valve had been changed sometime in the past, the new one will be different, and they have instructions at the Volvo dealer for install.
'01 Volvo 770
#19 Jack Mayer
Jack Mayer
    Major Contributor
  • 20344 posts
  • SKP#:60376
Posted 12 November 2013 - 11:21 AM
Nice new picture, Rocky.....
#20 rickeieio
rickeieio
    Major Contributor
  • Validated Members
  • 1482 posts
  • SKP#:108492
Posted 12 November 2013 - 04:14 PM
Wow.  That rig is so long you can actually see the curvature of the earth. :lol:
Volvo 770, ISX 500, 10 spd. auto
Overland 5th w/ garage in back
Lots of old motorcycles
Young enough to play in the dirt as a semi-retired farmer.
