Tires on a Forest River Silverback
Tires
8 replies to this topic
#1 JKTexas
JKTexas
    New Member
  • All Members
  • 1 posts
Posted 23 September 2013 - 07:54 PM
I purchase a pristine used Cedar Creek 29 RE fifth wheel a year ago. The original owner used it for two trips and decided RV'ng wasn't for him. The tags were still on the Lazy Boy recliners.
Our first trip went well. On our second trip we had a blowout returning home. No problem...Good Sam roadside assistance fixed us up.
We were just departing on our third trip and we had another blowout 15 miles from home.This time the tire damaged the lower panel on the rig. We got fixed up and immediately went to my tire guy and said I wanted to replace all four tires with the best money could buy. We put Carlisle tires on it and have gone 10,000 + miles with no issues at all.
When the tires were being replaced I was informed that the 29 RE had Chinese tires on it.  My question is; Did the dealer switch out the OEM tires or does Cedar Creek put Chinese tires on $3,000 RV's.
Does anyone have a comment?
Thanks
#2 trailertraveler
trailertraveler
    Major Contributor
  • Validated Members
  • 851 posts
Posted 24 September 2013 - 07:41 AM
Most 5th wheels and travel trailers come with ST tires (special trailer tires) as OEM equipment. Many brands of ST  tires, even Goodyears, are manufactured in China. Some have better reputations than others. The country of manufacture for each brand changes from time to time, but when I shopped for tires this Spring, there were only a very few brands of ST tires that were not manufactured in China. If you read the RV forums, you will see a lot of recommendations and debate about using LT (light truck tires) versus ST tires.
There are a number of reasons in addition to tire quality that result in trailer tire failure. Many RV manufacturers use OEM tires that are rated very close to the maximum weight capacity of the axles. Many RVs, especially light weight trailers and 5th wheels are overloaded by their owners, so this results in the tires being overloaded. Low tire pressure can also result in overloading and tire failure. Many trailer owners do not realize that ST tires are speed rated at 65MPH and that operation above that speed can damage the integrity of the tire. Rubbing the sidewall, jumping curbs and other road hazards can also damage tires and result in blowouts. When a trailer tire blows out, the other tires and particularly the other tire on the same side is overloaded and quickly damaged. If not replaced, this tire will fail prematurely and the other tire of the pair will be damaged and a cycle of repeating failures results and often the tire manufacturer is blamed.
On edit: Welcome to the Escapees Forum!!!
Edited by trailertraveler, 24 September 2013 - 10:40 AM.
#3 Kirk
Kirk
    Major Contributor
  • Weekend Moderators
  • 23483 posts
  • SKP#:60541
Posted 24 September 2013 - 08:32 AM
If you buy tires based upon low price they will nearly always be made "off shore."   Most manufacturers use cheap everything! :huh:
#4 Jimalberta
Jimalberta
    Major Contributor
  • Validated Members
  • 1774 posts
Posted 24 September 2013 - 03:52 PM
They need to make fivers that can use the 22.5 tires that semis use ....then they might last.
....JIM and LINDA..He..retired Refrigeration , Heating and A/C tech for 44 years and counting. she ...retired bookkeeper.....2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well.
#5 Stanley P. Miller
Stanley P. Miller
    Major Contributor
  • 19371 posts
  • SKP#:51443
Posted 24 September 2013 - 04:57 PM
That would require an extra step up into the fiver, not going to move off the dealer's lot with a drawback like that.
#6 whj
whj
    Major Contributor
  • Validated Members
  • 1196 posts
  • SKP#:106033
Posted 27 September 2013 - 10:50 AM
I have been told that most all TT/fivers come with China made ST tires.
#7 hydehunter1
hydehunter1
    Senior Member
  • Validated Members
  • 110 posts
  • SKP#:110745
Posted 29 September 2013 - 12:25 PM
do like I did and fix the problem of 16" blow apart tires. 215/75-17.5 16 ply tires this will fix your blow out problem.aq friend jsut had his 9th 16" tire blow and it did 33,000 in damage to his rig he did not listen.
#8 TXiceman
TXiceman
    Major Contributor
  • Validated Members
  • 1402 posts
  • SKP#:108682
Posted 29 September 2013 - 01:07 PM
We went to the H rated 17.5' tires and new rims on our Cameo.  The little extra is not worth the chance of trailer damage that can far exceed the cost of good tires over cheap tires.
Ken
Amateur radio operator, 2013 HitchHiker Champagne 38 RLRSB, 2012 F350 6.7L, <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot
#9 SuiteSuccess
SuiteSuccess
    Major Contributor
  • Validated Members
  • 1906 posts
Posted 29 September 2013 - 02:00 PM
JK,
A majority of mid level trailers come with poor quality tires. As above the " better" solution is going to 17.5 inch tires either Goodyear G114s or Michellins. However, on my kids Jayco we took the "Mission" tires off and put 16 inch Maxxis on. A lot of blowouts are due to under inflation for the load and heat generation. I have had Maxxis on two trailers and never had a problem, knock on wood.
2005 Mobile Suites 36TK3
2008 Ford F450 "Big Boy"
Also tagged with one or more of these keywords: Tires
