Dish Network - Non-HD channel selection
2 replies to this topic
#1 Rick_W
Rick_W
    Full Member
  • Validated Members
  • 97 posts
Posted 12 June 2013 - 10:04 AM
Two of our three TV's are 1080p, but the other is 720p.
Is there a way, when using a Joey, to select non-HD channels on the 720p TV?
Or should there be a setting in the TV to "fit-to-screen"?
Otherwise, the edges of the screen are cut off.
Rick_W
CPO-USN(Ret)
You don't know what you don't know!
#2 Mark & Dale Bruss
Mark & Dale Bruss
    Major Contributor
  • Validated Members
  • 5610 posts
Posted 12 June 2013 - 10:27 AM
If the channel is available in both SD and HD, then they are both in the director.  Just as an example Foc News is 205 SD and 205 HD.  If you look at All channels, you will see 205 SD first and then 205HD then 206.....  The default for My Channels is to show only the HD is both are available.
So the answer is to build a favorites list and select the SD versions.  The lists are unique to the Hopper or Joey, i.e. a list on a Jpey is not present on the Hopper.
We build list just to get rid of the stuff we will never look at (Shopping, Latino, etc.)
Please Emails only
Mark & Dale
Red Rover - 2000 Volvo 770, Tige - 2006 40' Travel Supreme
Sparky II - 2014 Chevy Equinox, Living on the Road since 2006
www.dmbruss.com
#3 Jer
Jer
    Senior Member
  • Validated Members
  • 175 posts
  • SKP#:59287
Posted 12 June 2013 - 11:32 AM
Use the "Format" button, lower left of control, to format the picture to the desired width to match the program you are viewing.
Jer
International 4700LP (2000)
Travel Supreme (36RLTSOA)
Fulltimer
