dubldart Posted January 23, 2015 Report Share Posted January 23, 2015 Yes we are! The love of fabrication and machining. Link to comment Share on other sites More sharing options...
jkennell Posted January 23, 2015 Report Share Posted January 23, 2015 "Jeff-C, the trapezoid piece is very close to 10 square feet. 1/4 inch plate weighs 11.25 lb per square foot, so you have 112.5 pounds before you calculate the "lightening holes" subtraction. I can calculate that for you, but I'm gonna need a bunch of "atta-boys". I'm sure others could use atta-boys too. :ph34r:" Please don't strain yourself...gotta save your energy for those Swami battles! The surface area of the plate as shown is pretty close to 1200 sq in.= 8.33 sq ft. @11.25 lb/ft....94 lbs. Hmmmm---maybe I shoulda lasered a few more holes in it! A UTV isn't a HDT---don't need extra weight on the back end! Actually I've been enjoying your description of the project above immensely. I loved working with the old mills and lathes...just wish I still had access to a Bridgeport! I'd hadn't realized that the jaws were speced that tight to the pin---but that does explain why I had to use a file to remove all the burrs on my kingpin and radius the edges on the jaws before I could get the Binkley (new) to latch! No camper at present. Way too many farm machines to maintain. Link to comment Share on other sites More sharing options...
dubldart Posted January 24, 2015 Report Share Posted January 24, 2015 If I knew how to load a picture I'd show off what I get to run everyday Link to comment Share on other sites More sharing options...
Refuzn-To-Grow-Up Posted January 24, 2015 Report Share Posted January 24, 2015 If I knew how to load a picture I'd show off what I get to run everyday I see lots of folks using something called picaso. But I have not a clue how they do it. Maybe someone will step in here and explain. Link to comment Share on other sites More sharing options...
phoenix2013 Posted January 24, 2015 Author Report Share Posted January 24, 2015 Set up Picassa account and create a file with the pictures you want to share. There is some "manipulation" how to make it public but more on it later. Pull the picture you want to post in the forum post and here are the steps. I can supply more detail but got to run right now, busy, busy, busy, living in Paradise, it's a Saturday in late January, warm (70's), no snow, life is good. Link to comment Share on other sites More sharing options...
Jack Mayer Posted January 24, 2015 Report Share Posted January 24, 2015 Phoenix, WAY warmer down your way than in Mayo, FL. We are in the 50's. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
jkennell Posted January 24, 2015 Report Share Posted January 24, 2015 If I knew how to load a picture I'd show off what I get to run everyday First hit "reply", then if you hit the "More Reply Options" button in the lower right corner, it gives you a direct upload option. See attached Snip 1 below. Hit "Choose files" and use the file browser to select the picture you want (must be less than 100KB...use a compress or resize function in a picture manager to reduce if necessary). The uploaded file appears just above the "attach Files" bar. See attached Snip 2 above. Move your typing cursor to where you want the picture in your post, and then hit "Add to Post" on the right side. For more than one picture, just repeat the process. The only thing is the total size of ALL pictures must be less than 100KB. When you are done, "Preview Post" or "Add Reply" Quick and doesn't require any outside picture storage. No camper at present. Way too many farm machines to maintain. Link to comment Share on other sites More sharing options...
phoenix2013 Posted January 24, 2015 Author Report Share Posted January 24, 2015 Jack, by Monday it will not be so nice here, but still much much better than everywhere else. The 100K limit for attached pictures is pretty pity fool, good for text, some pdf's and very small or very grainy pictures Link to comment Share on other sites More sharing options...
dubldart Posted January 26, 2015 Report Share Posted January 26, 2015 Sorry about that, got little distracted. Link to comment Share on other sites More sharing options...
jkennell Posted January 27, 2015 Report Share Posted January 27, 2015 Sorry about that, got little distracted. So, which one do you typically run...the lathe or the mug? Anyway that looks interesting...! No camper at present. Way too many farm machines to maintain. Link to comment Share on other sites More sharing options...
dubldart Posted January 27, 2015 Report Share Posted January 27, 2015 Little bit of both. Depends on cycle time. Primarily I'm a mill guy but if need be I'll go work on a lathe. Conversational programming IMHO is the easiest Link to comment Share on other sites More sharing options...
PEIFamily Posted January 30, 2015 Report Share Posted January 30, 2015 This shows you how heavy and well built Henrys hitches are, this one was put too far ahead in the trailer before hooking up 2006 Volvo 670 singled long 2011 Heartland Sundance 3300CK 2006 Smart passion 2001 F350 DRW CREWCAB Link to comment Share on other sites More sharing options...
