spindrift Posted October 18, 2016 Report Share Posted October 18, 2016 Drove Freightliner to work today. Didn't go over well. Told me not to bring it back in there Some kinda' union rule? 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted October 19, 2016 Report Share Posted October 19, 2016 Don't you have rental car insurance? And why do they care what you drive as you came to work after a tragic accident. Roger Link to comment Share on other sites More sharing options...
GlennWest Posted October 19, 2016 Author Report Share Posted October 19, 2016 Sorry outfit. Really wish the company I usually work with would get some work. As far as rental insurance, don't think so. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rdickinson Posted October 19, 2016 Report Share Posted October 19, 2016 GH, There are lots of vinyl products out there so there's a good chance something close can be found. It's like cutting the lawn go one way and it is one color reverse the path and it's different. Anyway, mine is predominantly red with a black safety cage. Red is being changed to white and the black cage is going to be red with some reversals in some areas inside and out. Looks like you came under the muffler. Sean said the pull point as he was going to make it was midway up the rear bumper so it looks close to your 13". I'm a little concerned about leverage. I'm told were using grade 12 bolts or something close and the bolts will go right thru with nuts on the back. Tomorrow the touch screen radio with Garmin GPS, Sirius radio, hands free phone and backup camera go in. All one unit. Dash cam is in the works for both the truck and car. Link to comment Share on other sites More sharing options...
peety3 Posted October 19, 2016 Report Share Posted October 19, 2016 Drove Freightliner to work today. Didn't go over well. Told me not to bring it back in there Time for a rental car then, apparently. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted October 19, 2016 Report Share Posted October 19, 2016 GH, There are lots of vinyl products out there so there's a good chance something close can be found. It's like cutting the lawn go one way and it is one color reverse the path and it's different. Anyway, mine is predominantly red with a black safety cage. Red is being changed to white and the black cage is going to be red with some reversals in some areas inside and out. Looks like you came under the muffler. Sean said the pull point as he was going to make it was midway up the rear bumper so it looks close to your 13". I'm a little concerned about leverage. I'm told were using grade 12 bolts or something close and the bolts will go right thru with nuts on the back. Tomorrow the touch screen radio with Garmin GPS, Sirius radio, hands free phone and backup camera go in. All one unit. Dash cam is in the works for both the truck and car. Roger, No worries about the load on the moment arm of the hitch. The bottom bar is 1/2"x2 1/2" bar stock with a 1 1/2" bar channel as a stiffener on the bottom and the 3 sided bolt boxes on the end are from 3/8"x2" bar stock. (3) grade 10.9 bolts in each end holds it in place. Remember that you are pulling a value of less than 1,000 pounds due to the ramp angles. Mine is WAY overbuilt for what is required. I thought that ground clearance was going to be an issue but the hitch is just a little lower than the exhaust and with the location being that close to the axle centerline, so far it has not been an issue at all. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
rdickinson Posted October 20, 2016 Report Share Posted October 20, 2016 Why the jump from 8 to 13", for the cable to miss the deck when starting to load? Better to overbuild than under. Would not look good on my resume if hitch broke, car rolled down and T boned someone's AMG. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted October 20, 2016 Report Share Posted October 20, 2016 13" will match up to the height of the riser on the winch pulleys. I don't come close to the deck as I back up up almost halfway up the ramp to start with. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
rdickinson Posted October 20, 2016 Report Share Posted October 20, 2016 Big first step getting out of the car halfway up the ramp. I use a plastic load protector on the corner to prevent wear on the deck or Kevlar cable. Out of curiosity I'll back a foot up the ramp and see how much higher the cable needs to be at the pull point to miss the deck. Current pull point is correct vertically but off a couple of inches laterally. With the car being wider and the rt side of the car staying pretty much where it is in relation to the fairings the drivers side will be further to the rear of the truck. The new pull point will be several inches off center laterally. Will be loading new Smart Saturday from a raised bank in the RV park to work out new chock positions and tie down locations. Wrapping and trick radio should be done by then. This will be one trick pony when done. Link to comment Share on other sites More sharing options...
GlennWest Posted October 21, 2016 Author Report Share Posted October 21, 2016 I will be in a new Smart later this week. Deep blue, almost black and white passion. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted October 21, 2016 Report Share Posted October 21, 2016 I will be in a new Smart later this week. Deep blue, almost black and white passion. That's good news Glen! Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
billr Posted October 21, 2016 Report Share Posted October 21, 2016 ???????? Bill and Joan and 3 Collie pups 2001 Volvo VNL 770 "The Doghouse" Singled short, "ET" hItch VED12 465HP Gen 1 Autoshift 3.58 ratio 2005 Mobile Suite 38RL3 2011 Smart Passion loaded piggybacK Weigh-It Portable RV Scales http://www.weighitrv.com/ Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted October 21, 2016 Report Share Posted October 21, 2016 Glenn a cruise control is $500 and it is pretty easy to install. Brad Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
GlennWest Posted October 21, 2016 Author Report Share Posted October 21, 2016 It is a Passion and loaded. JV sound with amp. Heated mirrors, sunroof, mags, long list of options. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted October 22, 2016 Author Report Share Posted October 22, 2016 Got it last night. Left work early. It is black and silver. Black interior. Had stated I would never own a black car. Ate those words. This was their demo. Had 1900 miles. Never titled. Got nice radio, JVC with amp. Power is nice. Truck area seems smaller. Does have a divider in there. May take that out. Tranission is a pleasant change. Kept expecting a pause between shifts. Rides is much improved. Has alloy wheels and Continental tires. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rdickinson Posted October 22, 2016 Report Share Posted October 22, 2016 You can change the exterior color. I am, I said I would never own another red vehicle. Where your old one was white and black, my new one is being switched from red and black to white body and red safety cage. Grill is being painted red and the top half of the mirror is switching over to red. The plastic rings and other interior plastic removable parts are coming off and being painted red to break up the oppressive black interior. There is a kit to re upholster the seats. They are being switched to red perimeter with off white inserts. Parts of the door panel is being re-done in red. The new one you have is a quantum leap ahead of the Diesel or Gen 1 Smart. Link to comment Share on other sites More sharing options...
rocksbride Posted October 27, 2016 Report Share Posted October 27, 2016 Glenn a cruise control is $500 and it is pretty easy to install. Brad Uh, wasn't that $500 and a CASE OF BEER? Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted October 27, 2016 Report Share Posted October 27, 2016 Almost forgot that part. Brad Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
rocksbride Posted October 28, 2016 Report Share Posted October 28, 2016 Worth every can. Thanks for the install! ;^D Link to comment Share on other sites More sharing options...
Big5er Posted October 28, 2016 Report Share Posted October 28, 2016 A case of beer? And you didn't share? I woulda watched if I had known there was beer. I woulda cheered you on for a Dr. Pepper. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted October 30, 2016 Report Share Posted October 30, 2016 Phil, I believe that you were in La. with Jay and Jim at the time I was installing the cruises. I was wishing you were there because Ian needed walking (and the rig needed greasing). Brad Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
