Removing interior panels, anyone at the HDT rally know how to do this?
mr. cob
Howdy All,
I have been looking for an dual stack setup for my Freightliner Columbia, ever since I bought it, I found a set in Idaho, the price is right and the salvage yard will install them so all is good. Cost of installation depends on how long it takes which brings me to my question, If I can remove the nessisary interior panels and then reinstall them myself I would save a pile of cash as I could have the truck ready to have the holes for the pipe mounting brackets drilled BEFORE I get to the shop and then reinstall the panels at my leisure when I get back home.
So if there is anyone at the rally who knows how to do this and wouldn't mind giving me some pointers on how its done, please contact me, I am in site #52. THANKS.
Dave
2001 Peterbilt, 379, Known As "Semi-Sane II", towing a 2014 Voltage 3818, 45 foot long toy hauler crammed full of motorcycles of all types.  Visit my photo web site where you will find thousands of photos of my motorcycle wanderings and other aspects of my life, click this link. http://mr-cob.smugmug.com/
Mr. Cobb, you shouldn't need to remove any interior panels for an exhaust install. The exhaust will come from the turbo, run under the cab, into a wye, then to each stack. The stacks normally have a couple of rubber mounts to hold them in place. We can discuss things tomorrow if you want.
Howdy Tom,
Holes will have to be drilled in the sides of the cab on both sides, the holes are needed to bolt the support brackets to the cab, the brackets then support the pipes. Looking at the same pipes that are mounted on Bill's truck, it looks like there are studs that go from the outside of the bracket through the cab and are then held in place with nuts and I am assuming a backing plate of some sort. So I can't see any way to do this without removing the interior panels on both sides of the cab. That said, I'll admit to NOT knowing what I am talking about just can't see any other way of doing this task.
Dave
Have you considered using blind steel Rivet Nuts? They can be set without a special tool - just use a grade 8 bolt with flat washers as spacers to pull the butt in. No need to remove internal panels. The holding power in sheet metal is impressive. I've used them in thread sizes ranging from 1/4" to 3/8" and have never had one pull out.
From Amazon.com:
WHAT IS A Rivet Nut?
A Rivet Nut fastener is a tubular rivet with internal threads. It can be installed in seconds form one side of the
work. Once installed, no finishing work is required on the Rivet Nut fastener. The added benefit of not only being a dependable fastener, they are ready to use with clean threads available for screw attachments. Blind thin sheet materials that are too thin for a tapped thread. Blind Rivet Nuts also are used when an application has little or no access to the backside as they can be installed from the front side of the work piece.
Randy, Nancy and Oscar
Dave;
The interior uses "Christmas" tree type of push pins. They slide in cutouts on each panel. If you get an automotive trim removal kit, this will allow you to pull the "soft" panels. Then you can access the fasteners for the hard shell outer trim.
Let me know if you need more help!
Curt
2001 Freightliner Century, 500hp Series 60, Gen 2 autoshift, 3.42 singled rear locker.
2004 Keystone Sprinter 299RLS (TT)
2 & 4 Wheelers!
2013 Polaris Ranger 800 midsize LE
Our motto "4 wheels move the body, 2 wheels move the soul!"
Howdy All,
Thanks for the replies and the suggestions, I'll pick up one of those trim tools.
Curt, thanks for your offer of help but if this deal goes through it will all be done before I get home from this trip.
Dave
Dave;
While your there you may want to check your insulation in those areas.
2 & 4 Wheelers!
