Who has the lowest...... and who has the highest mile HDT.....
Dollytrolley
A recent post regarding a Mr Spooner and his original owner 1961 Pete with 6,500,000 miles on the clock begs the question....... who in the HDT forum has the least and who has the most miles on the clock...........
Dollytrolley has 1,031,991........
Grumps favorite 1955 KW long-logger had +3.7 M on the clock with a 300 HP Cummins (2 in-frames)with a 8-71 blower side mount with a 5 speed main and 4 speed brownie and mack boogies ......the old girl passed away high up in the Cascade mtns in a rock slide while waiting at a landing waiting for a load of logs..........Grumps has been gone for many years but had it not been for the rock slide the ole KW would likely still be behind the shop today with a few million more on the clock..........
Drive on..........( whats your miles???)
2 stroke diesel. Needed the blower to make any power. It could run backwards, but no HP to speak of.
The turbo was a kludge at best.
I spent quite a bit of time around 6v-53s, 4-71s, 6-71s, 6v-71s, 8v-71s and 12v-71s in the oilfield plus the odd 16v-149s on crewboats.
Oily beasts one and all.
George,
Suzuki Celerio 998cc
Yamaha NMAX scooter
Work ride is Western Star N2 Tri-Tri tanker at 56,500kg loaded
A lot of Detroit Diesels had turbos and super chargers, turbo for the high side and blower for the low side.
I had a 1978 KW K100 with an 8V92 Silver, the Cadillac of the loud motors.
John
Southern Nevada
2008 Volvo 780, D13, I-Shift
2017 Can-Am Maverick X3-RS
A lot of the later ones had turbos in an effort to get more power out of unit that was becoming less than competitive.
They all needed blowers due to the design constraints of that particular 2-stroke design.
Geo
George,
Yamaha NMAX scooter
Geez guys.......your asking me to clear out a lot of old geezer-cobb-webs.........
No the ole 300 cummins was 4 cycle mechanical injection I-6 with 3 heads (one head for each two cyl)
It had a mechanical injector pump on the drivers side of the engine and had hard steel lines that direct fed the ingectors and then a bridge rocker arm was the actual high-side of the injector system......
The 8-71 blower was mounted on the passenger side of the engine block with blower mounted side ways (on edge) unlike the top mount on a standard 8-71 Jimmie........the blower was direct driven off of a BIG gear drive on the front case of the engine (drive facing to the rear) . The gear drive had a big silent-chain sprocket and the blower had the same size sprocket and they were exactly nose to nose with .005" space face to face and then a 6" wide chain was wrapped around the sprocket and the pin-from-hell had to be threaded through at least 100 links of the chain-from-hell and then a tiny cotter pin secured the pin for another 500,000 mile and then you put a new chain and sprockets on (ya you did have to pull the itty-bitty blower off to change the sprockets)....
It seems that the 8-71 blower took about +100 HP at full throttle but it was fast on the acceleration unlike turbo-lag. no intercooler was needed because the large rotors and large housing did not tend to heat the intake charge as turbos did. Driving a full supercharged cummins was a far different beast from a 2 cycle jimmie, if you was too fast on the throttle the quick instant boost could break a u-joint or twist a driveline into a pretzel (don'ask & I won't tell).....
The best part was that unlike a turbo, the 8-71 supercharger was perfectly tuned to the engine at every RPM since the crank and the blower were precision matched to the desired charge and fuel delivery and you did not really need a pyro because the charge pressure was always the same at a given engine speed.
The ole girl was a hotrod and could be a bit of fun with a load because she could pull 10 to 12 mile steep grades with no heat problems due to the cool intake charge.
Now I am starting to feel geezer again.......pass the adult beverages........prune juice......
Drive on..........(Geezer days.........)
Wow...I didn't realize you could get a digital odometer to roll over. What'd it go up to?? couple'a billion miles???
Wait, what...oh new truck...Sorry
Paul & Paula + Daisy the amazing wiggle worm dog...
2001 Volvo 770 Autoshift, Singled, w/ Aluminum Bed - Toy Draggin
2013 395AMP XLR Thunderbolt Toy Hauler
2013 Smart Passion
2012 CanAm Spyder RT
2013 Harley Davidson Street Glide
Guess it wouldn't be fair to use the new work truck. :)79284AB9-2201-4DC8-9E5C-1A63B4393F28_zps
Eco-Roll........so don't coasting the ole truck down the hill tend the roll the mile-0-meter backwards..........
Too many moons ago when I was gonna get rich as a bird-boy...........I was flying for food scraps out in the middle of the pacific one pitch-black nite with a bunch of freight......when I was starting to doze off now and then........the 'old-geezer (Capt) was stretched out back in the engineers throne watching me taking longer and longer cat-naps..........after a hour or so he bumped into me and I bolted upright and he chuckled and said " Kid ya know we rip 10 hours out of your logbook for every 10 minutes ya sleep at the wheel...........and ya flop this thing into the pond we all lose our logs........
Drive on...........(Eco-roll on.........)
They keep a eye on us these days. The truck has sensors that set off a alarm if you drift over the fog line or center line and turn on the dash camera.
Some guys hate it But I kind of like it. And we use people net on board log books. To tell the truth I like it also it's a lot easier not having to do the math.
The only thing I don't like is that I have to take a 1/2 hour break after 8 hours on duty.
