dan412 Posted March 18, 2016 Report Share Posted March 18, 2016 I'm looking at a used 2010 Volvo 780 with 13 speed. I downloaded the check list from this forum how important is the dyno test and what I'm looking for when I see it? Anything else I need to look for. Thanks, Dan 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted March 18, 2016 Report Share Posted March 18, 2016 Dyno will tell you how beat up the engine is. Is it making full power or what % has it lost. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
spindrift Posted March 18, 2016 Report Share Posted March 18, 2016 It can often make something break that was about to break...and that's a good thing. 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
ray.service Posted March 18, 2016 Report Share Posted March 18, 2016 Dyno will tell you how beat up the engine is. Is it making full power or what % has it lost. And blowby and injector function. Ray & Deb - Shelbi the Aussie & Lexington the cat2004 Volvo 630 500HP ISX "Bertha D" - 10 Speed-MaxBrake -ET hitch.SOLD2009 Designer 35RLSA SOLDFulltiming since '07 - stopped 2016 Link to comment Share on other sites More sharing options...
Big5er Posted March 18, 2016 Report Share Posted March 18, 2016 Get your dyno done, and then take the results somewhere else and have it read for you. I bought my truck from a dealer in Minnesota and had them do a dyno on it for me. They emailed me the results and I took it to a local dealer to get it interpreted. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
JPL Posted March 19, 2016 Report Share Posted March 19, 2016 Big5er, My truck came from Minn but it was already MH. The winters are hard on the frames. I'm busting some rust trying to get it ready for the ECR. It spent 9 years up there. I've had it for 5 years. Time sure flies when you start to realize you are getting older. At least I am getting older!! Take care. Pat The Old Sailor Link to comment Share on other sites More sharing options...
Star Dreamer Posted March 19, 2016 Report Share Posted March 19, 2016 We did the opposite, we are from MN but bought our truck in Texas. It had the cleanest looking frame we had seen on a truck. We have been lucky to not have had to drive it in winter so hopefully we are keeping the rust away. The truck had been a southern truck. (No engine block heater or fuel heaters) Back to the OP question, you might be able to get away without a dyno, but you would have to look at the condition of the truck, miles, how it drives and what maintenance records it has. When we bought our truck, we could not find a local place that could do the dyno because of the Ultrashift transmission. It should not be an issue with the 13 speed you are looking at. We ended up buying it without but did still have a VIS check done, which found a few items that we worked out with the previous owner prior to purchasing. The truck had low miles on it at under 450k, had been in RV use for a few years already, had good maintenance records and ran good. Yes, it is a chance but it was one we felt comfortable making. We still recommend other get dyno's done especially if mileage is over 500k. Dave 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
dan412 Posted March 19, 2016 Author Report Share Posted March 19, 2016 The truck has 810000 miles on it. should I get extended warranty up to 1 million miles or two years for 6K dollars. Don't know if it will be worth it to spend that much money on warranty when the two years will be up way before the miles. Dan 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
NoDirectionHome Posted March 19, 2016 Report Share Posted March 19, 2016 The dyno run, a VIS check and negotiating anything that it needs from the results would be a better warranty to me. "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
dan412 Posted March 23, 2016 Author Report Share Posted March 23, 2016 Got my oil sample back all is good. dyno is Thursday almost done. 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
dan412 Posted March 24, 2016 Author Report Share Posted March 24, 2016 Well we are going to pick up our new to us 2010 Volvo 780 cummins ISX 400hp13 speed next week. All the tests and inspections came back good. Thanks to all the info from this forum. Can hardly wait to start installing the ET hitch. 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
Chad Heiser Posted March 24, 2016 Report Share Posted March 24, 2016 Congratulations. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
MrSeas Posted March 24, 2016 Report Share Posted March 24, 2016 YEA another "non" Volvo motor! Congrats! Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 24, 2016 Report Share Posted March 24, 2016 You will like that ISX!!! Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Imurphy907 Posted March 24, 2016 Report Share Posted March 24, 2016 YEA another "non" Volvo motor! Congrats! I love my Cummins N14. Not sure I would have purchased a truck with a Volvo plant. 2016 Road Warrior 420 2001 Volvo VNL 660 Alaska Based. Link to comment Share on other sites More sharing options...
dan412 Posted June 29, 2016 Author Report Share Posted June 29, 2016 Well that deal didn't work out But I found a 2011 780 with 13 speed it has a Volvo D13 485HP. Dyno and inspection looks great has 8 new drive tires. We didn't like the color so it is getting painted should be out of the booth today. Planing on picking it up middle of July. Already have my ET hitch, jackalope and brake control ready to install. 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
oldride Posted June 29, 2016 Report Share Posted June 29, 2016 OK second time is a charm. Hope it works out for you. Keep us posted on build can't wait to get some good ideas. 2011 CAN-AM Spyder Rt SE5, 2010 Alpine 5th wheel, 1998 Vovlo VNL610 Hopefully 2 years 6 month till full time retirement. Link to comment Share on other sites More sharing options...
dan412 Posted August 19, 2016 Author Report Share Posted August 19, 2016 Finally going to pick up the truck tomorrow I can hardly wait 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
dan412 Posted August 21, 2016 Author Report Share Posted August 21, 2016 Got my new to me truck home last night if I knew how I would post pics 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
Big5er Posted August 21, 2016 Report Share Posted August 21, 2016 YEA!!! Congrats. Can't wait to see it. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
sdixon747 Posted August 21, 2016 Report Share Posted August 21, 2016 Got my new to me truck home last night if I knew how I would post pics Better yet, come and show it off at the National HDT Rally! Steve & Gail 2000 Volvo VNL660 Autoshift Detroit 60 12.7 "Semi Crazy" 2016 smart "Lil Crazy" 2018 Space Craft 48' TT "The Nut House" KJ4YGY & KK4CTE Link to comment Share on other sites More sharing options...
Jim & Wilma Posted August 22, 2016 Report Share Posted August 22, 2016 Congrats Dan! Let the fun begin. Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
dan412 Posted August 22, 2016 Author Report Share Posted August 22, 2016 Going get hitch put on this week hope it doesn't take to long. Spent all day today cleaning and fixing little things. 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
RichardS-VA Posted August 23, 2016 Report Share Posted August 23, 2016 sounds great! Link to comment Share on other sites More sharing options...
dan412 Posted August 23, 2016 Author Report Share Posted August 23, 2016 Can some one tell me exactly what to wright on the certificate of fact paper that I printed off the WA DOL web site don't want any problems at the DOL. and do I need to have it inspected by state patrol. I know that I need a weight ticket Thanks 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
