zenkate Posted July 10, 2017 Report Share Posted July 10, 2017 Ok so I'm getting ready to go FT and have just purchased a 2000i generator for occasional dry camping. I am travelling solo and wanted something i could lift! Anyway I am now wondering where to store it. I was delighted to find I could (barely) lift in in to the 'garage...' but am now wondering if i should be storing it so close to the house battery? and enclosed space? Not really wanting it in back of p/u for weather and theft exposure. advice? Link to comment Share on other sites More sharing options...
Yarome Posted July 10, 2017 Report Share Posted July 10, 2017 4 hours ago, zenkate said: ...but am now wondering if i should be storing it so close to the house battery? and enclosed space? As long as you have adequate venitlation space (6" or so) between your house battery and genny, you should be fine. It's not "ideal". Not that there is any ignition hazzard, but assuming your battery/ies are wet cells, some of the offgassing "could" potentially cause corrosion issues in your genny over time. Without knowing which rig you have or where your batteries are located I can't really recommend an alternative. One fairly inexpensive option may be to purchase a cover for your Honda. They can be had for around $20 at Home Depot or others that sell Honda's "off the shelf". Partioning the space might be another option. In the short term though.. you're fine.. and it may never "be" an issue, but you're little Honda ain't exactly cheap. I would consider it a worthwhile investment to pick up a cover if it's going to be riding with your battery/ies. Link to comment Share on other sites More sharing options...
Hot Rod Posted July 12, 2017 Report Share Posted July 12, 2017 I store my Honda 1000 in an overhead compartment in the the toyhauler garage. No problem and never had a fuel odor. Basement should be no different. Honda makes a cheap silver cover, and a nice "marine" canvas cover for not much more. Get the better one. Also, I can highly recommend the extended run fuel tanks you can buy on ebay and elsewhere. Basically a boat type gas can with a hose and special cap for the generator. When we used to do events we could run our 1000 for the entire work weekend (40-50 hours?) without a refuel on a 5 gallon extra tank. Beats going out and shutting down the generator and refueling a couple of times a day when it would conk out. If you already have a boat can you can just pick up the cap on ebay. Link to comment Share on other sites More sharing options...
tyates007 Posted July 12, 2017 Report Share Posted July 12, 2017 Not sure what your setup is but I carry 2 Honda eu2000i generators and 10 gallons of gas in a box that sits on a rear hitch carrier. Very convenient, secure and close to where I need them when I need them. Link to comment Share on other sites More sharing options...
gjhunter01 Posted July 12, 2017 Report Share Posted July 12, 2017 I carry a Honda eu3000i in the storage compartment near the middle since it is so heavy. I had it converted to LP gas and carry 2 extra 30lb bottles stored in the pickup bed on each side of the fifth wheel hitch. I've only used it once for about an hour in 5 years of full timing, but I always have it and it's ready to go if the need arises. Greg Link to comment Share on other sites More sharing options...
jjwicklund Posted July 12, 2017 Report Share Posted July 12, 2017 I bought a tool box for the truck. cut some 2x4's to divide the box to keep itens from shifting carries two yahama generators, two 5 gal diesel cans, 2 gal gas can and 5ton jack. You do need to climb up in to the bed to remove items but that's why I have the man step. John 2017 F350 King Ranch DRW 6.7 4.10 B&W hitch 2017 DRV MS 36RSSB3 Link to comment Share on other sites More sharing options...
Johns1959 Posted July 27, 2017 Report Share Posted July 27, 2017 On 7/11/2017 at 10:55 PM, jjwicklund said: I bought a tool box for the truck. cut some 2x4's to divide the box to keep itens from shifting carries two yahama generators, two 5 gal diesel cans, 2 gal gas can and 5ton jack. You do need to climb up in to the bed to remove items but that's why I have the man step. JJWicklund, That sounds like a great solution. Can you run the generators in the toolbox or do you remove them first? Can you provide a picture? Please advise. Regards, John Link to comment Share on other sites More sharing options...
jjwicklund Posted July 28, 2017 Report Share Posted July 28, 2017 I bought them for our trip to alaska in 15, never needed more than one 2000 watt to charge batteries and run the coffee pot and toaster in the morning. I have always taken one out to run never had the need to run both for AC. I also carry a couple 5 gal diesel fuel containers. 2 1/2 gal gas for the gens and rome for a couple 5t hydrolic jacks.. I saw on one of the forums someone had the 3600-4000 watt gen and built a box to hold the gen and run whle going down the road. John 2017 F350 King Ranch DRW 6.7 4.10 B&W hitch 2017 DRV MS 36RSSB3 Link to comment Share on other sites More sharing options...
gjhunter01 Posted July 29, 2017 Report Share Posted July 29, 2017 Something to consider is if the generator is mounted to the camper or even in the truck bed, you may get some vibration inside the camper when running the generator. For some people it is not a problem. Greg Link to comment Share on other sites More sharing options...
NTPA Announcer Posted July 31, 2017 Report Share Posted July 31, 2017 Mine is a 7000 Honda and is mounted very securely to the frame of the camper. It rocks us to sleep gently as our bed is in the front. but it also doesn't bother you any where else in the 5 ' r Denver and Ms Judy Geitgey 2006 VOLVO 780 41 ' Redwood NTPA Event Announcer dngeitgey@gmail.com Link to comment Share on other sites More sharing options...
