cadonnelly Posted July 1, 2017 Report Share Posted July 1, 2017 I want to put in a Pioneer AppRadio a double din running off of apps, seems cool to me. Now the install instructions are straight forward except!!: It wants a signal for when the emergency brake is actuated, is there such a signal and where, if not how do I do a work around. The second is a signal for reverse gear, any one have a wire number and location for that? Thanks Chuckd Stillwater mn Link to comment Share on other sites More sharing options...
Steve from SoCal Posted July 1, 2017 Report Share Posted July 1, 2017 There should be a light on the dash for parking brake, the back up lights are the reverse signal. Both of these should be easy to locate. Steve 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
bluflame11 Posted July 2, 2017 Report Share Posted July 2, 2017 I just installed pioneer 4200 in my 730... solved both issues.... 1. Parking brake.... there is a small adapter that i bought to bypass the parking brake signal. Just search "pioneer parking brake bypass" on Amazon. It's like 8 bucks. 2. Reverse....i did run a wire from the taillights up to the dash. I am sure there is a wire under the dash somewhere, but I thought for the time I would spend looking for it, I could just run a wire to the back as I ran the cables for the back up cams. I did 2 back up cams, one at the fifth wheel hitch and one low at the bumper. Now, after all that was done, I ended up not using the reverse signal anyway.... on my unit the reverse signal triggered the radio to go to the back up camera, but I wanted to be able to switch between the 2 cameras back there depending on the situation, so I did not use the reverse trigger. Link to comment Share on other sites More sharing options...
Yarome Posted July 2, 2017 Report Share Posted July 2, 2017 Parking brake by-pass? Just ground the signal wire to the chassis. Bada-bing!! No additional equipment or expense required. Link to comment Share on other sites More sharing options...
cadonnelly Posted July 2, 2017 Author Report Share Posted July 2, 2017 Thanks to all of you for your replies, I was having a brain burp or something when I looked at the instructions. Should be fun install, never done one. Trying to do more of the work myself this time, just so I can have a little fun making myself look like an idiot Something I do on a regular basis. Thanks again Chuckd Link to comment Share on other sites More sharing options...
Pete Kildow Posted August 18, 2017 Report Share Posted August 18, 2017 How did your install go? Did you tie cameras and GPS into your double Din? Pete Link to comment Share on other sites More sharing options...
