Best way to air up dually tires?
jpcoll01
I had valve extensions installed which made it super easy to check/air up tires, never experienced any air loss.  However, I had a blowout on Monday and the tire ripped the extender off of the good tire taking the valve stem with it (leaving two flats on one side).  Wondering what people are using to easily gain access to their valves.
Thanks in advance.
I use long air tools....both the guage and the chuck are long enough to reach the inner valve straight on. They are available at places like napa
How do you get the caps off the valve stems? or do you leave them off?
That's where having a wife with small hands works good. I would not leave the caps off, you could get mud or dirt in the valve or even water that might freeze and open or corrode the schrader valve. Valve caps were used and installed by the manufacture for a purpose. Check with any auto parts store for a proper air chuck.
Greg
There are valve stem caps called " Gator Cap" they are flow through caps that protect your stems threads but also allow you to air up without removing cap.
Bob & Karen Ritchie
Chase, BC when we are not RV'ing & chasing trains
'06 29.5 LKTG Hitch Hiker 2 LS
'07 GMC 2500HD Classic sb/srw
SKP# 96746
They also make a tool to reach and remove the caps. It looks like a screwdriver, but the end has a small cup on it that fits over the valve cap.  The end holds the cap through friction and allows you to unscrew the cap and remove it, then reinstall when done.  Any auto parts store that carries heavy duty truck parts will have one (or most truck stops also).
22 hours ago, jpcoll01 said:
I just had a schrader valve (standard tire valve) ripped in two because a blowout ripped the braided valve extender off of it, don't really want to go that path.
Maybe that is why the web page's author stated using metal valves with a braided extension is the better way to go.
My tires have the double seal caps on ...sometimes known as gator caps. They work very well and allow me to use the long air tools that I described without having to reach in to remove caps.
15 minutes ago, gjhunter01 said:
I wonder if you could use a 1/4" rubber hose (size?) for removing the valve caps. Just push the hose on over the cap and twist it off?
Greg
I had a piece of vinyl hose stuck onto a large nail to remove the valve caps.  So yes you can!
Back on the road again in a 2011 Roadtrek 210P
2011 Tahoe 4x4, 2006 Lexus GX470, 2018 Ranger XP1000, 2013 RZR 570LE
http://finallynewellin.blogspot.com/
I really enjoy my linked dual wheels/tires. One place to check and air up each of my six sets. The tell tale color change makes en-route checks a breeze too. Still use the infrared on the tires, wheels, U joints and differential. It makes me actually look at them to make sure the light is hitting the correct spot.
2007 Honda GL 1800
