Tandem and duals
cadonnelly
Let me add some metallurgical science.  A 10% reduction in load equates to a 50% increase in life.  Wrknrvr is undoughtingly increasing his hub and wheel bearing load but, it was never near the load limit to begin with, so it works.
           Personally:
I would never do it because I just have this respect thing for machinery, but you do see people do things (redneck engineering) everyday and get away with it. (if it ain't Boeing, we ain't going)  You can thank the margins engineers build in.  It isn't efficient, but it goes to the rule that every time we make something idiot proof, someone finds a better idiot.
SpaceCraft S-470
SKP #131740
  • Replies 52
1 hour ago, barlyn1 said:
Ive done it for 5years on two differnt trucks, just removed inside wheel/tire on each position.  A tandem tractor rides smoother than a single axle on rough roads.  I went to singles on the outside so i could get up my driveway (18% grade).  Weight on rear tandem are 13 to 14 thousand only.  About 50k miles is all.
But 13-14k on the rear tandem is getting up towards the load limit of the tires. Sure, the axles and suspension are good for 34k, but if you cut the tire count in half, you're now at (or slightly above) 17k.
Singles are rated for more than half of duals.  That is why front axle can be 13000 or 12000 or so.  Tires should be ok for at least 24 k on two axles, 6k each.
Axle rating with only one tire is something else.
98 379 with 12.7 DD
LG Dodge w/5.9 CTD
Chrome habit I’m trying to kick.
 https://www.meritor.com/productsandservices/truckproducts/rearsingleaxles.aspx
https://www.google.com/search?q=semi+truck+axle+photo&client=safari&channel=ipad_bm&prmd=isnv&tbm=isch&tbo=u&source=univ&fir=0P7MymE-XIMgiM%3A%2CMxKpWk9e4u82-M%2C_%3B7OojAkz-eiT4MM%3A%2C7s1XcmwS56ozBM%2C_%3BnWEO_ZslPjU3jM%3A%2CGixNsRCZVSsTLM%2C_%3Bm_G9vAssH6ozyM%3A%2CfsNXPyKFDZYH7M%2C_%3Bm7VxQe9X8Uz17M%3A%2CDd-NL3d_NuHAbM%2C_%3BMaDmGDt0TeSgKM%3A%2Cvt-U21Nozim2RM%2C_%3Bsw3VpA9VA6JrXM%3A%2CKYnzIUzaXw_IfM%2C_%3B-f2vwupVt4EK6M%3A%2ChugCGqq9RW1qIM%2C_%3BaWs_Kx0bxPCOqM%3A%2CsKQq8wnX7fp_eM%2C_%3BeyoLkJKHdT6WAM%3A%2CwyITpbFkN5dXdM%2C_&usg=__kNNGBQSjlMVt_xV52rQfB9jyipE%3D&sa=X&ved=0ahUKEwjtg-ysruHSAhUU72MKHTZQAVsQ7AkIMg&biw=795&bih=566&dpr=2#q=semi+truck+axle+photo&tbm=isch&tbs=rimg:CT-OINlVp2I4IqABhFYwJHZKnj-lyH4dWDyWgcMzdT1BJ2Y9YQOMQER_1mrVEp_1-yNBQFQkxmRO5MBBElzxkBL1jmxXt8RVfAJy6-kc4rBd3EjDYJ9Ffpup4Jjw5VHh6zapmvIQ9wGZchc1pgQazKi4V3vx2lef5nJ66JFRO8MN6OGQ-D-qHBzQvIfh4a39PVQUDH60gCfWq8tzV_14O9TvTYQfZGX4dXdgfk8tCoSCYRWMCR2Sp4_1EUZ8NXERKZUmKhIJpch-HVg8loERqj0geGDZKlkqEgnDM3U9QSdmPRGPsRxh3FJVdioSCWEDjEBEf5q1EdSnqhkuHtMyKhIJRKf_1sjQUBUIRW9lSRXw6HoEqEglMZkTuTAQRJREAi3BOs0WKbCoSCc8ZAS9Y5sV7EcqctHVdQMYTKhIJfEVXwCcuvpER0WyiIOyLUm4qEgnOKwXdxIw2CRHx5AvHyVgTByoSCfRX6bqeCY8OEQS6S91b8uM7KhIJVR4es2qZryERyOaIJFnuHWsqEgkPcBmXIXNaYBFIZIU9eUd79CoSCUGsyouFd78dEZ2mRKNorASHKhIJpXn-ZyeuiRURpuwga-rS2_1sqEgkTvDDejhkPgxEArlY0D8bLjCoSCfqhwc0LyH4eEUstLl3xTV_1TKhIJGt_1T1UFAx-sRsxojqjF65zkqEglIAn1qvLc1fxFuctkkLeF4MyoSCeDvU702EH2RETVV1UHG2FajKhIJl-HV3YH5PLQR92e2OXGoL2U%3D&*&imgrc=t1oP_2yfXNuJ4M:
 just wanted to have a picture to show where the bearings are located on a rear axle .
 I am searching for a better picture to show where the bearings are located but it may take some time for a good reference picture.
 Notice where the hub assembly ends.
 Vern
SpaceCraft S-470
SKP #131740
 Stekay, your photo that you posted has a good view of where the bearings are located in the hub assembly. On the second photo it shows the inner bearing is located at about where the studs end on the inside.
 Now with the offset wheels, one facing out and one facing in that puts the center of the two rims at about where the inner bearing is located.
 The next posting you have is somewhat not true for what most of us have as our rear axle. Now one can say different but just saying what you normally see on out trucks.
 If you look at the pictures that I posted you can see where the hub assembly is located on the axle. If you look at the axle pictures it shows the brake assembly where the inner wheel is located. So it looks like the brake shoes are located about where the tread is located on the inner wheel assembly.
 Take a look and think about it.   Safe Travels,.  Vern
They make axles designed for using a single wheels on each side, and they make axles for using two wheels on each side. They are not the same axle. I'm not an engineer or even a mechanic but I just have to wonder by the people that design, engineer and build them bother to make them differently if they can be used either way.
2014 smart Fortwo
And they make front tires with wider tires too, because there's a law about weight per inch of tread width.
why bother ?
maximum loads ?
which we are not - usually   far from it ,is what wrknrvr is getting at.
Its tough for truckers to make that 18 gear mental downshift to what we do - bububu I driven 1,000,000 miles............
2005 volvo 670 freedomline singled
Newmar Torrey Pine 34rsks
woot woot
But have you stayed in a Holiday in Express lately.
I understand completely what WE do and we alter these trucks by removing axles and in other ways that are completely understandable. But if you are going to alter the way an axle is designed to be used, then why not replace it with an axle designed to be used with single tires? If you take both tandem to single tires, why not just single the axles? It will have damn near the same capacity as two axles using single tires without any questionable stress on the bearings or anything else. If in our usage, that extra bit for weight distribution is required, you are pushing the limits that you claim we aren't close to.
Maybe that is why it illegal in Texas?
2014 smart Fortwo
The wheel flange (which the wheels bolt to) is at the mid point between the inner and outer hub bearings.  Using either the inner or outer dual offset wheel alone will asymmetrically load these bearings.
I slept in my own bed last night, but my diploma says Mechanical Engineer.
Av8r3400
 Av8r3400
 I see the drawing. Have you ever taken apart a rear axle and looked at what is there.
If you look at the picture of the bearing assembly that stekay posted it shows a real life assembly. And what I posted on axles you can see where the normal hubs are located.
 The drawing that you show is not really representing what our standard hubs are
Now back a few years ago I did wear a suit and tie to work at an engineering firm. But that was not what I really liked doing.
 There will be pictures of a rear axle being disassembled on Thursday or Friday. Hopefully if the shop gets the truck in there.
 Safe Travels,.  Vern
Bearing wear should be the least of any RV haulers concern. The only time bearings go bad is if they run dry or are mounted/torqued improperly. Otherwise they go a million miles hauling commercial heavy loads and just aren't a truckers main worry. Ask a trucker when was the last time he/she had a wheel bearing go bad and you will probably get a blank stare. Ask that trucker when was his last bad tire experience and you will get a lot of stories.
Greg
Vern, your linked photos/drawings agree completely with my posted drawings, only my drawings also show the placement of the wheel and tire in comparison to the bearings.  These are views of standard Meritor type Semi-Tractor rear ends, not automotive LDT parts.
I'm happy for you that you have had no mechanical issues in your many, many miles with this type of arrangement.  I hope your success continues.
Speaking for myself alone, I won't follow your example.  We will need to agree to disagree at this point.
Av8r3400
To put numbers to it:  Most all highway trucks will have a Type R drive hub (572/592A bearings).  Everything about them is a SAE standard.  Hub offset below is going to be 1.31".  Average cast drum is going to be 0.48" thick.  Aluminum wheel thickness is going to be 0.865".  Type R hub is 4.31" between bearings (LMS/PreSet spacer height below).  Y'all can do the math but yea it's a bit off of center.  Then again, the bearings aren't the same size either.
For the average cast brake drum you are going to end up with the centerline of the shoes at 6.75" from the hub mounting face.  Centerline of a normal aluminum rim is 6.6".
You don't change hub offset for wide single wheels as you change axle track instead.  That's all part of spec'ing the truck.  LMS/Preset hubs are only good to 600K.  After that you are supposed to either rebuild them for another 600K or dial indicator them yearly like all the other regular hubs out there.  Hubs are all fatigue tested per SAE standard too so it isn't like one brand can do it and another can't.  Iron hubs, however, can generally handle abuse and heat better and could make the difference.
Yea Scrap....
2013 Smart Passion
2012 CanAm Spyder RT
So, I'll ask again.  IF one were to stay tandem but run just the outside tires, would we still be within design loads on the hub bearings with a rear axle weight of roughly 18k?
I'm thinking, with such light weights, the fact that the loads are off center is moot.
18k total weight for both axles or 18k per axle for a total of 36k?
Alie & Jim + 8 paws
2017 DRV Memphis
BART- 1998 Volvo 610
Lil'ole 6cyl Cummins
Duh.  I should write what my brain is trying to say.........  I meant a total of 18k on the rear of the truck.  I picked that number out of the air, as it's close to what a singled truck would normally be rated, w/ the back half of a 38k tandem.  We're nowhere near that figure, but some are over a bit.
