Shadow Catcher Posted April 24, 2017 Report Share Posted April 24, 2017 I am installing one and it is being installed using Quick Connect Shut-Off Couplings this will allow easy removal for winterizing and sanitizing. The shutoff allows removal with only a few drops of water spilling. Quote Link to comment Share on other sites More sharing options...
franco-bolli Posted August 14, 2020 Report Share Posted August 14, 2020 I installed one of these from Home Depot several months ago. https://www.homedepot.com/p/Everbilt-2-Gal-Thermal-Expansion-Tank-EF-TET-2T/304207414 I can flush the toilet 3X before the pump runs again. Northwood did a great job of putting the pump a long ways from the main sleeping area, so even if it does run, I can't hear it. The is a note in the care and feeding document for the expansion tank that says that chlorine "will influence the life of your product." I put it right next to the pump. Its nearly empty when I purged the system last to sanitize. Your experience may differ. Cheers FB Quote +++++++++++_____________________________________+++++++++++ 2021 Ram 3500 2017 Arctic Fox 25W(to be traded??) HAM guy (Ke7FIX), photography, woodworking (mostly sawdust), Electronics Technician, USAF DAV Going where everyone has gone before Link to comment Share on other sites More sharing options...
