dan412 Posted March 11, 2017 Report Share Posted March 11, 2017 I need to get my 780 fridge out is there anything that you have to take off to get it out. I'm thinking maybe a slide hammer would work. 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
SuiteSuccess Posted March 11, 2017 Report Share Posted March 11, 2017 Apparently has a slide/bracket at the bottom that gums up and makes it difficult. There are some discussions on the forum about this somewhere if you use the search function. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
alan0043 Posted March 11, 2017 Report Share Posted March 11, 2017 9 minutes ago, dan412 said: I need to get my 780 fridge out is there anything that you have to take off to get it out. I'm thinking maybe a slide hammer would work. Hi Dan, This is just an idea for you. It might help to remove the driver's seat to give you more room to work with. If you do remove the seat be very careful because of the weight of the seat. Don't ask me how I know this. The seat can be taken apart. You can removed the seat from the seat base. This helps a lot. Good luck, Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Big5er Posted March 11, 2017 Report Share Posted March 11, 2017 Isn't there a post in the resource guide about this? I'm on my phone and not my computer but I thought there was. But I do know that the seat does not need to come out. The refrigerator is in the cabinet. All removing the seat will get you is access to the side of the cabinet. Taking the drawers out will get you more access to the refrigerator. MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
dan412 Posted March 11, 2017 Author Report Share Posted March 11, 2017 Got it out took the drawer out above it remove the screw at the top two screws at the bottom used my small snap-on slide hammer came right out. Thanks for all the help 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
NTPA Announcer Posted March 11, 2017 Report Share Posted March 11, 2017 Once ours came out to replace it. ( And they will go thru the passengers door...) I just placed two 2x4's on the floor and one in the back to give it an air space and shoved the new one in. Works just right ... Denver and Ms Judy Geitgey 2006 VOLVO 780 41 ' Redwood NTPA Event Announcer dngeitgey@gmail.com Link to comment Share on other sites More sharing options...
dan412 Posted March 12, 2017 Author Report Share Posted March 12, 2017 Do I try to get my fridge fixed or buy a new one. looks like it has been fixed before and new ones are not cheep. I want to stay with the original if I buy a new one because it looks better. 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
SuiteSuccess Posted March 12, 2017 Report Share Posted March 12, 2017 4 hours ago, dan412 said: Do I try to get my fridge fixed or buy a new one. looks like it has been fixed before and new ones are not cheep. I want to stay with the original if I buy a new one because it looks better. Dan, Depends on your use and what you want. The Volvo replacement would probably be $700-800 or more. Lost the link but JeffB had an aftermarket 12 volt that looked good and was rugged. It was around $600. Google 12volt semi frigs and I'll bet you can find it. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Nigel Posted March 12, 2017 Report Share Posted March 12, 2017 I think truckfridge.com may have a direct replacement. Nigel 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
SuiteSuccess Posted March 12, 2017 Report Share Posted March 12, 2017 1 hour ago, Nigel said: I think truckfridge.com may have a direct replacement. Nigel Nigel, Thanks that's the site. I'll bookmark it. BTW you gonna be able to make the ECR? 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Nigel Posted March 13, 2017 Report Share Posted March 13, 2017 That's the plan. But that was the plan for the last two years as well. Kim has a deposit and I'll fill out your registration in a few days. Nigel 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
SuiteSuccess Posted March 13, 2017 Report Share Posted March 13, 2017 9 minutes ago, Nigel said: That's the plan. But that was the plan for the last two years as well. Kim has a deposit and I'll fill out your registration in a few days. Nigel No worries. Just saw you on her list and was hoping it would be possible. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
NTPA Announcer Posted March 13, 2017 Report Share Posted March 13, 2017 Hey there Fellas.... I didn't spend anymore than $125.00 on mine and it works just fine. Just my .02 Denver and Ms Judy Geitgey 2006 VOLVO 780 41 ' Redwood NTPA Event Announcer dngeitgey@gmail.com Link to comment Share on other sites More sharing options...
Wizard Posted March 22, 2017 Report Share Posted March 22, 2017 Where did you get your $125 fridge? Need one for our 770. Jim 2000 Volvo 770 with 2016 Smart 2008 Newmar X-aire toyhauler 2017 Bmw R1200gs 2014 Honda Cb500x rally raid Link to comment Share on other sites More sharing options...
dan412 Posted March 23, 2017 Author Report Share Posted March 23, 2017 The least expensive Volvo fridge I can find is $1000 bucks. 2011 Volvo D13 485/1750 Eaton 13 Speed 2016 Montana 3820FK Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 23, 2017 Report Share Posted March 23, 2017 The smaller 120 volt dorm refrigerators will generally fit the opening if you are looking for a low-priced refrigerator replacement. You have to use an inverter with it. And it will not look "built in" in the same way the Volvo fridge does. Truckfridge is the place to go for aftermarket alternatives that are 12-volt. They have good stuff at pretty good prices. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
NTPA Announcer Posted March 25, 2017 Report Share Posted March 25, 2017 I bought it at Walmart. Just compared the dimensions and got as close as we could. It works well and in fact its running off the inverter overnight to see just how much juice it pulls from the batteries . Denver and Ms Judy Geitgey 2006 VOLVO 780 41 ' Redwood NTPA Event Announcer dngeitgey@gmail.com Link to comment Share on other sites More sharing options...
SuiteSuccess Posted March 25, 2017 Report Share Posted March 25, 2017 9 hours ago, NTPA Announcer said: I bought it at Walmart. Just compared the dimensions and got as close as we could. It works well and in fact its running off the inverter overnight to see just how much juice it pulls from the batteries . Denver, We had done the same with a Whirlpool dorm size from Lowes. According to RandyA (who everybody knows can be trusted for electrical stuff) they are very sensitive to heat. Ours lasted a little over three years then pooped out. Since we use ours only occasionally, I'm going to buy the same one from a local warehouse who has them on sale for $99. I also have two 12 volt fans from a Xantrex inverter that I'm going to wire up in the compartment where the fridge is located to increase circulation. I figure if I get another three years it will be only $33/year, worth it in my opinion. BTW going to have the fans on a dash switch so I can turn off when not in use. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
rpsinc Posted March 26, 2017 Report Share Posted March 26, 2017 On 3/25/2017 at 5:00 AM, SuiteSuccess said: Denver, We had done the same with a Whirlpool dorm size from Lowes. According to RandyA (who everybody knows can be trusted for electrical stuff) they are very sensitive to heat. Ours lasted a little over three years then pooped out. Since we use ours only occasionally, I'm going to buy the same one from a local warehouse who has them on sale for $99. I also have two 12 volt fans from a Xantrex inverter that I'm going to wire up in the compartment where the fridge is located to increase circulation. I figure if I get another three years it will be only $33/year, worth it in my opinion. BTW going to have the fans on a dash switch so I can turn off when not in use. What about using a 12V programmable timer like this:http://www.ebay.com/bhp/programmable-timer-12v, to cycle it when in use and the timer could be wired to that dash switch.. If the fridge isnt being opened, then cycling it every few hours should keep thing cold and not drain the batteries to nothing. Also, a 100W solar panel would offset that too. Marcel Link to comment Share on other sites More sharing options...
SuiteSuccess Posted March 27, 2017 Report Share Posted March 27, 2017 50 minutes ago, rpsinc said: What about using a 12V programmable timer like this:http://www.ebay.com/bhp/programmable-timer-12v, to cycle it when in use and the timer could be wired to that dash switch.. If the fridge isnt being opened, then cycling it every few hours should keep thing cold and not drain the batteries to nothing. Also, a 100W solar panel would offset that too. Good thought, thanks. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Darryl&Rita Posted March 27, 2017 Report Share Posted March 27, 2017 On 3/25/2017 at 6:00 AM, SuiteSuccess said: Denver, We had done the same with a Whirlpool dorm size from Lowes. According to RandyA (who everybody knows can be trusted for electrical stuff) they are very sensitive to heat. Ours lasted a little over three years then pooped out. Since we use ours only occasionally, I'm going to buy the same one from a local warehouse who has them on sale for $99. I also have two 12 volt fans from a Xantrex inverter that I'm going to wire up in the compartment where the fridge is located to increase circulation. I figure if I get another three years it will be only $33/year, worth it in my opinion. BTW going to have the fans on a dash switch so I can turn off when not in use. Use 120v fans, fed from the inverter output. Use thermostats like this to control the the fans. The first time you forget to turn off the dash switch, you'll thank me. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
VegasFlyer Posted March 27, 2017 Report Share Posted March 27, 2017 Or wire the fans on an ignition hot circuit, then you don't need a switch. John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
SuiteSuccess Posted March 27, 2017 Report Share Posted March 27, 2017 7 hours ago, Darryl&Rita said: Use 120v fans, fed from the inverter output. Use thermostats like this to control the the fans. The first time you forget to turn off the dash switch, you'll thank me. 6 hours ago, VegasFlyer said: Or wire the fans on an ignition hot circuit, then you don't need a switch. Thanks for the options. 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
